Help with Ford Transit...damsel in distress!
Bonsoir
Hi
I have a Ford transit camper van 1996 LWB
Her side sliding door wont shut... the door bounces back....Ive taken the door panel off... the lock looks to be working ok...moves with key etc. WD40 on everything!!
The door slides along track ok....but wont go all way in and bounces back
I think the Latch has jammed in lock position..and wont go over the keep.... Ive tried to get to the latch via the door panel but can only see where the cable goes into the frame... Ive tried to take the latch off the door... with the correct screwdriver bit!..but it wont budge! Ive tried to force the latch open...but will only go backwards not forwards to release position...
My Haynes manual is good but doesnt show the latch
I dont want to take the door off completely as it is too heavy for me to get it back on the runners again on my own...and I cant get her to a garage so will have to do it on my own
Any advice.... for a damsel in distress in deepest rural France
Many Thanks...in antisipation
Trundlelin
Hi
Trundlelin
Bonsoir
I opened the door in the normal way with no problems....I went to close it after and it bounced back...Ive tried with the Lock...Locked with key & Unlocked with key... lock moves ok... the Ive taken the panel off...lock moving ok... the latch on the other end of the door is not moving at all with the key/lock... the latch will not go over the keep to pull the door in to closed. I have tried to force the latch to "open" so it can go over the keep...but it only will move backwards... I can not see if the cable from the lock to the latch is moving etc...
Ive tried to take the latch off the door but can not get the "fixings" to undo...even with the correct bit and an electric screwdriver...you can not see from the door panel...
Any advice...
Many Thanks
Trundlelin
Any advice...
Many Thanks
Trundlelin
Bonsoir
Hi
Yes..I thought that...how do I unjamme it...?
Ive taken the panel off.... the cable from the lock to the latch is free at the lock end.... I can not see the connection at the latch end as goes through a metal panel to the latch. I have tired to unscrew the fixings to the latch on the outside of the panel..but it wont budge...
Any advice...??
Bientot
Trundlelin
Hi
Any advice...??
Bientot
Trundlelin
Can you take some pictures so we can see what you're dealing with? They're not too complicated fortunately enough.
The torx screws will be loctited in so you will need the same bit but for a ratchet.
Bonjour
Hi
Ill take some pics later and get back to you
I have a bit that fits the torx srew... but my electric screwdriver will not turn it...
I also have a allen key that fits it but I dont have enough strength in my hands to turn it....
I be back this afternoon
Thanks for trying to help
Bientot
Trundlelin
Hi
Bientot
Trundlelin
Bonjour all
Thanks DazC for asking for pics...been up the garden to take them... was fiddling with the key /lock/panel to get you a good pic of the workings and there was a loud click....I dont know what moved but the door now shuts!!! Hurrah!...the WD40 I sprayed before Xmas must have worked its way through the cable to the latch and somehow its freed itself. The lock and door works better now than it ever has...
Thanks to all of you who replied to my SOS.... you have restored my faith in helpfulness...
Trundle can now again enjoy her retirement as my SunHouse a la "Georges small places" on Ch4...I have removed the tarpaulin she was under to keep out the rain
Thanks again for all your help!
Kind Regards
Trundle Lin
Kind Regards
Trundle Lin
borboyous
22-08-2015 11:17 AM
