white 2wd cossie project
Old 18-10-2012, 08:38 PM
  #41
turblower
turblower's Avatar
hallo mate,looking rally good,i was wondering where you got the exhaust manifold?cheers
Old 18-10-2012, 09:22 PM
  #42
Puss2
Formerly know as Puss
Puss2's Avatar
Looks awesome with the 18" th2s. Would love some for mine but have the 17" ones for now. Good luck with the build
Old 19-10-2012, 08:47 PM
  #43
SaphCos4x4_Dan
loves a good ham shank
SaphCos4x4_Dan's Avatar
xs power... its just a cheap shitty one to get me up an running tbh and is probably worse than a std one lol, but i can use the dimensions and location of the flanges to have a proper equal length one made by my mate
Old 19-10-2012, 09:26 PM
  #44
SaphCos4x4_Dan
right well i got a bit bored in work today so started a bit of sanding/polishing...
first i made a start on the new plenum that was covered in deep scratches and was looking a bit tatty
then i thought while ive got it apart i'd make a start polishing my inlet trumpets...
.... it proved to be a lot more hard work than i anticipated. i really need to invest in some more power tools for doing this
Old 19-10-2012, 09:36 PM
  #45
SaphCos4x4_Dan
and you can see really see the difference after i gave the headlight a good freshen up
Old 25-10-2012, 06:12 PM
  #46
PHILMC1978
PHILMC1978's Avatar
Originally Posted by SaphCos4x4_Dan
managed to get a little bit more stripped and cleaned today... its hard trying to find time to get stuck in while im at work as there is.. well.. err work to be done
removed the scuttle pannel
blower moter
wiper motor
then started to clean the bulkhead up a little bit....
then a little bit more... still loads of little knooks and crannies to get at yet
Car looks very well bud, i am doing a similar job with my 4x4 Sapphire and
looking for a little advice if you could help out????
I have removed all the black underseal etc from the underside of the car and wanted to paint it white but i am unsure of what product to use....
White schutz with waxoyl, Ford diamond white then clear waxoyl, white stonechip???
Any advice would be much appreciated!!
Good luck with your resto
Old 25-10-2012, 07:11 PM
  #47
Fezman1
Fezman1's Avatar
Once the underside is cleaned back and prepped;
use a zink rich primer,
seam seal
another coat of primer
stonechip (3m or upol gravitex)
then finish with diamond white
Old 25-10-2012, 08:09 PM
  #48
Received 1,044 Likes on 998 Posts
Looking good.The wheels are mint.
Old 26-10-2012, 08:48 AM
  #49
SaphCos4x4_Dan
seam seal
When you say cleaned back and prepped, do you mean strip the original underseal off too?
I'm at this point as well... Mine had an aditional layer of black underseal on which I got off with a spray bottle of petrol and about 15 hours labour lol
My plan was to stone chip then paint over that
Dan
Old 26-10-2012, 10:03 AM
  #50
SaphCos4x4_Dan
Got a bit of refurbishing done over the last couple of days...
Old 26-10-2012, 10:09 AM
  #51
SaphCos4x4_Dan
And finished....
Trumpets smoothed...
Old 26-10-2012, 10:22 AM
  #52
SaphCos4x4_Dan
This is the gripper diff I got for it....
Old 26-10-2012, 11:35 AM
  #53
Sticky.
Sticky.'s Avatar
What did you use to clean the headlights? They ame up a treat.
Old 26-10-2012, 11:39 AM
  #54
SaphCos4x4_Dan
Gave them a coat of satin black mate
Old 26-10-2012, 09:08 PM
  #55
PHILMC1978
PHILMC1978's Avatar
seam seal
Thanks FEZMAN, i'll go with what you have suggested and post the results,
cheers bud!
Old 26-10-2012, 09:12 PM
  #56
PHILMC1978
PHILMC1978's Avatar
Dan
What a pain in the aRSe stripping the black underseal!!!
2 tins of Gunk and two days of my brothers life!
I was planning to white stonechip then diamond white over also???
What colour you doing rear beam, petrol tank etc??
Phil ( near sunny Blackpool )
Old 26-10-2012, 10:47 PM
  #57
nuttynil
RS nutta
nuttynil's Avatar
Nice rebuild ,remember this shell .your lucky got a nice workshop to get it sorted.neil
Old 26-10-2012, 10:51 PM
  #58
SaphCos4x4_Dan
I'm thinking il just do the beam black, petrol tank looks brand new
What about you?
Old 26-10-2012, 10:54 PM
  #59
SaphCos4x4_Dan
Where do you know the shell from mate?
Yeah I'm pretty lucky I can do it at work for the time being... But il shortly be renting a unit with my mate where il have 24/7 access
Old 20-11-2012, 05:18 PM
  #60
SaphCos4x4_Dan
bit of a small update... my brakes arrived today curtecy of mad ade
330mm discs and 4 pot brembos
also bought some more parts and il add pics as they arrive
Old 20-11-2012, 06:38 PM
  #61
I would love a set of them for my cossie.
Old 20-11-2012, 06:48 PM
  #62
SaphCos4x4_Dan
you need to be quicker in the for sale section then
Ford Focus RS Parts for Sale.
02-06-2016 06:46 PM
charlierothwell
Ford KA
05-11-2015 06:56 PM
09-10-2015 07:38 PM
CrOwSoN15
14
03-09-2015 12:21 PM
FlashRS
13
31-08-2015 06:02 PM
Quick Reply: white 2wd cossie project
