roll over spit
Old Feb 3, 2012 | 06:28 PM
Northants Ford Fan's Avatar
Northants Ford Fan
Default roll over spit
Hi guys
I'm looking at getting a roll over spit for a mk4 escort project, and was wondering if anyone had any plans plans or cutting list to make one, as I dont really want to spend huge amounts when I can make my own a lot cheaper.
cheers For any usefull info
Old Feb 3, 2012 | 07:44 PM
dingla rs's Avatar
dingla rs
il get you some pics and measurements to mro mate ,2 inch box section and two different sized tube and some angle iron is what you need ,my one was made for a rst
Old Feb 3, 2012 | 07:50 PM
Northants Ford Fan
that would be great if you could mate, as less money spent on spits and bits mean more money to spend on the car its self
Old Feb 3, 2012 | 07:58 PM
langer's Avatar
langer
I asked about one on here before and no one had any lol
Old Feb 3, 2012 | 08:02 PM
dingla rs's Avatar
dingla rs
if you want to by one mk2mania do a kit
Old Feb 6, 2012 | 06:52 PM
dingla rs's Avatar
dingla rs
rite couple sizes for you
the round tube is 4inchs long both small tube and big tube
big tube 2inch wide
small tube 1 1/2 wide
1 1/2 box section ,
legs 46 inches long
feet on the frame are 24inches long
the smaller tube has a nut and washer welded in so you can lock it off
Old Feb 6, 2012 | 07:37 PM
Brian's Avatar
Brian
Me and my mate bought one from here to do our MK3 MK2 Fiesta's http://www.ebay.co.uk/itm/ROLLOVER-J...#ht_6884wt_991
Brian
Old Feb 6, 2012 | 07:39 PM
dingla rs's Avatar
dingla rs
^hole shit brian there bout 25 quids worth of steel there
Old Feb 6, 2012 | 07:43 PM
SMILER258's Avatar
SMILER258
were building one at the moment that uses drum brakes for the spinning and braking system. Just an idea if you build your own.
Old Feb 6, 2012 | 07:45 PM
dingla rs's Avatar
dingla rs
this me other one
Old Feb 6, 2012 | 07:46 PM
Brian's Avatar
Brian
Really, well at the time we couldn't find any where that sold made them and tbh we ant that good at welding something like this together atm we have my mates Mk3 fiesta Rs turbo on it and it seems really good
Brian
Old Feb 6, 2012 | 07:47 PM
dingla rs's Avatar
dingla rs
Brian
not some thing you wana do if you carnt weld ,least its getting used well mate
Old Feb 6, 2012 | 07:50 PM
Brian's Avatar
Brian
My mate's MK3 on the spit
Brian
Old Feb 6, 2012 | 11:17 PM
baz walton's Avatar
baz walton
Rock Out!!
Here's a couple of mine on the spit I made for her.
The holes in the sides of the main frame mean the centre of gravity can be adjusted to suit.
So if the engine or gearbox below, or bonnet and hatch up top,
were still on, the spit still turns over with one hand and cant spin wildly round.
Old Feb 7, 2012 | 08:30 AM
GINGExR2 T's Avatar
GINGExR2 T
I use 2 of these
http://www.ebay.co.uk/itm/Engine-Sta...item4161d49927
They work a treat, i bought them new from Machine Mart, was a while back, but i'm sure they were £50 each.
I did end up cuting the upright in half to make them taller as my Mk4 escort wouldn't go right over.
Ginger
Old Apr 7, 2012 | 08:38 PM
mk2mania's Avatar
mk2mania
this is the type we do , watch a clip at
http://www.youtube.com/watch?v=i3DNXqGivL0
Old Apr 7, 2012 | 09:55 PM
steven mc kay's Avatar
steven mc kay
here is the one my mate got made , i have used it more than him, and he ended up giveing it to me .
its very good as its fitted with rams at both ends so a shell can be lifted of a set of axel stands from a low hight , and then lifted up to a hight that it can then be turned over .its also on wheels so the shell can be moved around the garage . the end that fits into the chassi is also adjustable ..
thanks steven
Old Apr 8, 2012 | 11:46 AM
slammed106's Avatar
slammed106
you may well have this sorted now but i made 1 a while back for my project:
from memory the main T`s at each end are 80x80x6mm thick box..
the pins are 40mm bar..
the box section actually fitted to the shell is 40x60x3mm thick (i think)
the wheels came from 1 of those BIG wheelie bins found in industrial estates.. they use a 13mm nut and bolt and can be removed very quickly in the middle of the night - if you struggle to find somewhere that sell them hahahah
the bar under the car is just 50x50x3 box section... the locking disc was done at a local laser cutters, 10mm steel and they charged £20 to cut it with all the locating holes..
rex647
Mar 6, 2022 06:20 AM
boeb
Jan 9, 2020 05:11 AM
Mikersturbo
Sep 27, 2015 07:43 PM
JamboRS
28
Sep 14, 2015 09:02 PM
