Mk1 3dr Sierra L model - update -
#161
Got a quote today of £1600 to spray the car inside and out.... Ford gloss black
Is that quite expensive? The car is already stripped and sanded down, only 1 or 2 small dents
#163
Yeah thought so, there doing the engine bay and complete inside also...
Well there lifting the car on the 20th or thereabouts so updates then...
Also got a 89 spec dash, really Mint off cossie09, pic soon
#165
esc mate proper pukka bitta kit 4 around £50, just then need a zetec coil pack and leads, but it can even run the scorpio/rs coil on plugs(some how?) and ull need an after market cps or do what ive done and mount a trigger wheel 2 the face of the crank pulley, as for the cams theres a big differance in them and are a lot better when using carbs, as for the type 9 it bolts straight and except the rs2k clutch plate but i had to cut the middle outta me clutch fork and bring it foward 12mm
#167
think i might take the simpler option and sell the rs2k and buy a 2.0 pinto engine so i can get it on the road faster.....
#168
yeah seen a few running the vis scorpio system... i dont have any knowledge of wiring to that degree so would still need to pay someone to do it, so wouldnt really work out cheap in the long run, but thanks anyway mate.....
#169
trust me its so easy, its 2 wires and 2 plugs abit of vacumn hose and job done, on my last rr mine came in at 153 bhp at f/w and thats bog standard on a twin choke weber, itll cost over a grand to get that out of a pinto, ask around the zetec chaps 4 advice but trust me its piss easy
another thing what inlet manifold are you using for the twin carb? only one ive seen is the burton one at over £200
#170
not twin carbs twin choke as what was on 2ltr pintos, i used a pinto manifold and an adaptor plate, send me your email address and ill fire you sum pixs in the morning,
#171
#177
Is that I4 lump been put in a fiesta??? Looks awesome!
Also, hope not to hijack yout thread tjrs500, but how do you get an rs2k to run on carbs? ignition wise?
#181
#182
Cheers for all the help... Really does look simple... Going to have a hard think about what I'm doing engine wise now.
Just one more thing.., where did u get the cps and trigger wheel?
#184
Has anyone ever modified one of these lower lips to fit along with the whale tail spoiler? Results?
Think it's off a 85 glsi? It is much shorter than the one that was on the car( 1600l ) it fits the bootlid perfectly, both 52.5cm....
#185
Update
Car is now away to the body shop for a full respray inside and out in frozen white. Decided that diamond white was too dated and it would never look good compared to modern white cars
Anyway I will try to get as many pics ad I can of the car in paint.
Cheers for looking
Cheers for looking
#189
ffoc.co.uk
Autoglass, motor factors, breakers yard?
#193
called in today as i got a call saying the car was fully primed. safe to say im delighted it looks great already... the kit hasnt been done yet as there was quite abit of damage so its slowing things down
i decided to go with a bmw white, a happy medium between ford diamond white and frozen white( way to modern on a old car once i seen it in person )
also bought a set of newly refurbed 16'' mondeo si alloys with 2 good tyres for £100, which i didnt think was bad.... not the nicest wheel in the world but money is tight at the minute.
cheers for looking heres a few pics
#200
well done for sticking with it mate i have changed my mind about my last four cars ended up selling or swapping them all lost a fortune and now im back where i started, keep with it and the bits will turn up slowly like mine im still collectiong for a pinto turbo in my sapphire.
cheers steve
cheers steve
