Zetec Powered Drag RWD Escort
#124
This is one serious piece of machinery mate
I loved the fiesta but this is just totaly over the top, can you please do it in Orange camouflage not yellow, it has to be orange to stand out properly.
Also if you bring it to the U.K. can you get a passenger seat fitted as I would love a passenger ride in this with you at the wheel..
Awesome
Awesome
#125
Awesome
Awesome
#134
Make sure you thoughly wash and scrub the crank webs well with parafin or solvent with a scotch brite pad
When they polish the journals the metal filings/ debris stick to the webs like glue but can come off if you rub it hard
If you dont give it a good scrub it could come off and cause exesive wear further down the line as the metal particles contimate the oil
Had to do that with mine, you will be amazed how much metal dust comes off with a good scrub
#135
thanks your help
#138
I found here one set uprated valve springs..curiosity I measured them..
i buy the new motor newmans cams the springs (190lb)..
this springs buy several years ago dbilas..
the dbilas springs stronger as the newmans.... About twenty percent..(190vs220)
#140
the ones that I'm using from piper are rated to 242 lbs, so even more than newman or dbilas, but stil they are not preventin valves from floating at more then 7000 rpm and 1,5 Bar of boost.
http://www.pipercams.co.uk/pipercams...n=8&engine=265
#141
strongest that I could find are made by ferrea 305 Lbs, but I'm not sure if our silver top Zetecs ar the same like american focus has.
http://www.ferrea.com/sportcomp-spri...ve-springs.php
#142
here the ferrea RACE TURBO DUAL spring..
S10041 Dual Spring - Turbo 18.23 mm 13.40 mm 75 lbs 195 lbs
(75 the install rate and 195 the open press)
you car not valve floating....i run standard valve spring (street car and 1.5bar) there was no problem..my friend run 1.8 bar with gt2876R drift car...there was no problem...
So what?
#143
We measured the weight of the car..
95 percent of the standby
I see that the car will be about 900 kilograms with me ready the race...(Now that's a Fiesta)
suspension is not set !
without me
with me
without me
with me
#145
Are you talking about zetec engines in those cars? my valves don't float during the run, they float during burn out and my lifters pump up. I'll install 258 lbs springs now and we'll see who is right
#148
What can be so heabvy there? you have backhalved body, with no weight at the back, light weight wheels, plastic front and windows... strange... I guess MTX box is heavier, dry sump ads a bit of weight, charge cooler must be heavier than traditional IC, and the roll cage.
