3dr
Old Oct 22, 2014 | 04:53 PM
  #281
siscossie's Avatar
siscossie
3-door moonstone
Got a new alternator and all is good again, putting 14.08volts in at the battery now
Wrapped all the wires with heat shielding think might make a cover for the back to help protect it from the turbo heat, unless there available to buy seen one on ebay in carbon but it's £80
Next going to drop the oil and change the filter, and refit the cambelt cover
Old Oct 29, 2014 | 06:45 PM
  #282
siscossie's Avatar
siscossie
3-door moonstone
Got the belt cover back on and had to fit a new fan switch just needs a clean front bumper refitting and then a setup
Also got a alternator cover help protect it from the turbo heat
Old Oct 29, 2014 | 10:55 PM
  #283
Cragrat's Avatar
Cragrat
sit boo boo sit
Tidy looking cover Si
dare I ask where from my good man ?
Old Oct 30, 2014 | 05:27 PM
  #284
siscossie's Avatar
siscossie
3-door moonstone
A fellow passionforder looking into having some made mate
Old Oct 31, 2014 | 07:23 AM
  #285
Cragrat's Avatar
Cragrat
sit boo boo sit
question or statement?
Old Oct 31, 2014 | 05:59 PM
  #286
siscossie's Avatar
siscossie
3-door moonstone
I'm gona get some made I think bud
Old Oct 31, 2014 | 06:04 PM
  #287
siscossie's Avatar
siscossie
3-door moonstone
Got a bit more done today bumpers refitted and the grill and had to move the exhaust
Only the new fuel pump loom to fit then think it's ready for a set up
Old Nov 11, 2014 | 09:28 PM
  #288
siscossie's Avatar
siscossie
3-door moonstone
Got a set of os siemens 55's through the post today off danielbetty cheers fela
These should make for a bit more bhp I think has anyone else fitted these and what do they think
Old Nov 12, 2014 | 02:34 PM
  #289
siscossie's Avatar
siscossie
3-door moonstone
Today sorted the plug to the drivers front indicator was faulty so got another one and rewired and braided it and now sorted
Also spoke to Motorsport developments and had a chatt about a set up and mapping session
Pic of new and old plug
Old Nov 12, 2014 | 03:08 PM
  #290
costina's Avatar
costina
Live long and prosper!!
I have blacks running T34.48 Works well
Old Nov 12, 2014 | 05:32 PM
  #291
siscossie's Avatar
siscossie
3-door moonstone
What power and torque u running bud
Old Nov 12, 2014 | 05:49 PM
  #292
costina's Avatar
costina
its the same map james had on his so i would guess 370 with 400 lbft peaks 32 holds 27 ish. Pulls really well in the midrange.
Old Nov 13, 2014 | 07:47 PM
  #293
Looking good matey.
Old Jan 12, 2015 | 05:33 PM
  #294
siscossie's Avatar
siscossie
3-door moonstone
Before I book it in at motorsport developments thought it was time to change the fuel pump loom, as it was struggling to get 12volts at the pump.
After making a new loom and fitting it's now putting 12.6/12.7volts to the pump
Just shows how the wiring can make a difference
Also need to get some new boot struts as mine are shot won't hold the boot up with the 500 spoilers on
Old Jan 18, 2015 | 03:59 PM
  #295
siscossie's Avatar
siscossie
3-door moonstone
Got the car off the ramps today had trouble selecting gears not sure why brand new carbon Kevlar clutch and skimmed flywheel, wondered if pedal not adjusted properly
Took a short vid of it running someone said sounds as if cambelt too tight what do you guys think
Old Jan 21, 2015 | 05:20 PM
  #296
siscossie's Avatar
siscossie
3-door moonstone
Think might have found the problem selecting gears the pedal ratchet won't adjust far enough think it's worn, ordered a new one from graham goode
And got the new boot struts fitted much better now holds the boot up no problem really strong, from SGS engineering there called nitro lift
Old Jan 21, 2015 | 06:07 PM
  #297
cozzy jeff's Avatar
cozzy jeff
I need new struts for mine, what do they cost and is that the part number on the top?
Old Jan 21, 2015 | 06:35 PM
  #298
siscossie's Avatar
siscossie
3-door moonstone
These where £56 posted various choices depending on what strength you need, yep think that's the part number bud
Old Jan 24, 2015 | 10:51 PM
  #299
tjRS500's Avatar
tjRS500
Great to know ... I haven't seen boot struts work yet
Old Jan 28, 2015 | 06:29 PM
  #300
siscossie's Avatar
siscossie
3-door moonstone
There defiantly something wrong somewhere it's driving me nuts clutch fela came and had a look he says it gearbox, so I've pulled the box out and it's going to G.E.A.R.S on Saturday to be checked over.
And the clutch is going back to be checked over too hopefully that should sort it
File Type: jpg
Old Jan 30, 2015 | 06:41 PM
  #301
siscossie's Avatar
siscossie
3-door moonstone
Drained the box and got the bell housing off ready to go to GEARS tomorrow had a look in the top but it looks ok��
Old Jan 30, 2015 | 07:28 PM
  #302
costina's Avatar
costina
At a guess Si its a clutch issue imo
Bad times eh
Paul
Old Jan 30, 2015 | 07:35 PM
  #303
siscossie's Avatar
siscossie
3-door moonstone
A few people have said that too but couldn't get a gear when engine not running so clutch not an issue then
Old Jan 30, 2015 | 07:38 PM
  #304
costina's Avatar
costina
Oh hope you get it sorted.
Regards
Paul
Old Jan 30, 2015 | 08:22 PM
  #305
siscossie's Avatar
siscossie
3-door moonstone
So do I fela getting gearbox and clutch checked
Old Feb 2, 2015 | 06:10 PM
  #306
siscossie's Avatar
siscossie
3-door moonstone
While I had the exhaust off got the tailpipe changed from a inwardly rolled one to outwardly roll much better I think
And after getting the all clear on the gearbox putting it all back in and can now get gears when engine off but really hard to get when running so defo the clutch I think, that means all out again tomorrow ffs
Old Feb 2, 2015 | 06:17 PM
  #307
costina's Avatar
costina
Rolled out looks better mine had a 4"slash cut on it lol changed for a 3 rolled out.
shame on the clutch guess its not disengaging. Turn engine over on the starter and see if rear wheels turn.
Old Feb 2, 2015 | 08:21 PM
  #308
siscossie's Avatar
siscossie
3-door moonstone
I'm ripping it out tomorrow and taking it back its doing my head in now
Old Feb 2, 2015 | 08:29 PM
  #309
costina's Avatar
costina
I'm gutted for ya fella you try something new and end up with loads of grief.
Chin up.
Old Feb 3, 2015 | 06:17 PM
  #310
siscossie's Avatar
siscossie
3-door moonstone
Well it's all out again ready to take back proper fed up now just want it running again
Old Feb 6, 2015 | 07:36 PM
  #311
costina's Avatar
costina
Any luck Simon ?
Old Feb 8, 2015 | 07:16 AM
  #312
siscossie's Avatar
siscossie
3-door moonstone
Yes mate took the clutch back he checked it over and he says he's given me the wrong thickness plate, after a few choice words he made me the right plate. Going to get it all in today hopefully.
Old Feb 12, 2015 | 05:41 PM
  #313
siscossie's Avatar
siscossie
3-door moonstone
Had it all back in again and it's the same I'm ready to kill someone now
Taken it all back and he's looking at it, are the 2wd and 4wd release bearings different if so by how many mm does anyone know.
Need to get this sorted now that's the fifth time it's been out now grrrrrrrrr
Old Feb 12, 2015 | 06:33 PM
  #314
costina's Avatar
costina
They are different by how much im not sure.
Can u not engage gears?
Old Feb 12, 2015 | 06:38 PM
  #315
costina's Avatar
costina
Difference is in the mounting.
Old Feb 13, 2015 | 04:23 PM
  #316
siscossie's Avatar
siscossie
3-door moonstone
can only get gears when engines not running
been back today and hes given me a release bearing fron a capri to try not too sure about that!!!!
Old Feb 13, 2015 | 05:32 PM
  #317
costina's Avatar
costina
go on burtons site and check part numbers before you fit it.
bet you wished you used a ap clutch.
Old Feb 13, 2015 | 07:53 PM
  #318
costina's Avatar
costina
Just checked they have the same part numbers
If it don't work this time. take it back and get a ap plate and helix cover from Matt Lewis
if its ok then don't forget to bed the clutch in like you would brakes.
Fingers crossed
Paul
Old Feb 15, 2015 | 06:20 PM
  #319
siscossie's Avatar
siscossie
3-door moonstone
Cheers fela
Got the box back in today and tried it turning the crank with mate sat in car putting it in gear and it seems to be working, have to get the rest of it together and see.
I got a bearing from motorsport developments aswell there different capri one a lot deeper tried that one first seems ok so far
Old Mar 4, 2015 | 07:43 PM
  #320
costina's Avatar
costina
Any updates?
Ordered my clutch from Matt Lewis should be here soon.
