3dr
Old Aug 7, 2014 | 09:24 PM
  #201
adam151082's Avatar
adam151082
That dash looks mint, nice find.
Old Aug 8, 2014 | 03:08 PM
  #202
siscossie's Avatar
siscossie
3-door moonstone
Ye it's pretty good think it might be a tad darker than mine but certainly better than the one that's in
Old Aug 10, 2014 | 07:16 AM
  #203
siscossie's Avatar
siscossie
3-door moonstone
Got a bit more done yesterday heads off and most of ancillarys off
Had a bit of a scare a while ago one of the cam bearings collapsed found all the bits bar one, thank god I got a magnetic sump plug found this when I took it out
Start stripping the block today found a company called CG motorsport for the clutch and there local looks like some good gear, gonna go down and have a chatt.
Old Aug 15, 2014 | 08:08 PM
  #204
siscossie's Avatar
siscossie
3-door moonstone
Got the block out just got to strip it down and change all the gaskets and seals
Old Aug 15, 2014 | 09:20 PM
  #205
Cragrat's Avatar
Cragrat
sit boo boo sit
It just gets better n better that old shed of yours Si
Old Aug 16, 2014 | 05:19 PM
  #206
BRAMMER's Avatar
BRAMMER
Let the spending commence - i'll just sort that job out whilst motors out lol all the best with it your starting at the right time anyway before the cold arrives
Old Aug 16, 2014 | 06:38 PM
  #207
siscossie's Avatar
siscossie
3-door moonstone
Got the block painted tonight
Ordered a carbon ceramic clutch having it specially made by cg motorsport should cope with all the power and future upgrades, he's also doing one for the mk2 escort project aswell.
Thinking of getting a upgraded baffle plate for the sump while it's out, what sealant on the sump are you felas using and do you just seal the ends or run it round the whole thing.
Old Aug 16, 2014 | 06:39 PM
  #208
siscossie's Avatar
siscossie
3-door moonstone
Cheers bud any updates on yours fela
Old Aug 16, 2014 | 06:41 PM
  #209
siscossie's Avatar
siscossie
3-door moonstone
Your right there bud already blown my budget, maybe thinking of hydraulic clutch conversion are they easy to do how was yours
Old Aug 16, 2014 | 08:12 PM
  #210
BRAMMER's Avatar
BRAMMER
They are easy-ish providing you have all the parts ready
http://www.ebay.co.uk/itm/AP-Style-R...3D150773662324
http://www.ebay.co.uk/itm/BRAKE-CLUT...item417844ccc3
or Girling which kits come with
http://www.ebay.co.uk/itm/Girling-Ma...item25640ee699
Slave cylinder
http://www.ebay.co.uk/itm/CLUTCH-SLA...item2ecf1ed877
Small female fitting for the clutch release arm for the slave rod to push in to
and the bell needs modding but you need to get it as close to the transmission housing as possible
Old Aug 16, 2014 | 08:19 PM
  #211
siscossie's Avatar
siscossie
3-door moonstone
Slave cylinder
Cheers fela will have a look into this, thanx for the info
Old Aug 18, 2014 | 05:36 PM
  #212
siscossie's Avatar
siscossie
3-door moonstone
Picked up my new carbon Kevlar clutch I've had made by CG motorsport today looks pretty good.
Also got a 6 paddle clutch kit for the mk2aswell, will get pics up soon
Old Aug 20, 2014 | 02:52 PM
  #213
siscossie's Avatar
siscossie
3-door moonstone
Started to reassemble the block sent pulleys for powder coating
Old Aug 21, 2014 | 05:53 PM
  #214
siscossie's Avatar
siscossie
3-door moonstone
Started on the inlet manifold tonight a clean and some new vaccum pipe fitting
Old Aug 21, 2014 | 06:38 PM
  #215
costina's Avatar
costina
Live long and prosper!!
Very nice, had the pleasure to park next to you at ford fair
What kind of power will that clutch handle as im having trouble with mine.
Regards
Paul
Old Aug 21, 2014 | 06:54 PM
  #216
siscossie's Avatar
siscossie
3-door moonstone
Regards
Paul
He says it will be good for at least 400bhp but he know people who are doing more with no trouble, went for this one so it easier to drive rather than a paddle
Old Aug 21, 2014 | 06:58 PM
  #217
costina's Avatar
costina
Expensive? trouble is with mine is the torque which is around 400 lbft I got a new gen motorcraft clutch with a refaced fly and its not happy
Old Aug 21, 2014 | 07:07 PM
  #218
siscossie's Avatar
siscossie
3-door moonstone
I'd give them a ring there really helpful and he knows his stuff, they will be able to build one to suit your car, or suggest what you need.
Old Aug 23, 2014 | 06:29 AM
  #219
siscossie's Avatar
siscossie
3-door moonstone
I've ordered a autospecialist inlet manifold should be here weds, decided that was the best way to go. So need to get the trumpet part blasted now to match has anyone got any pics of one fitted?
Old Aug 23, 2014 | 06:02 PM
  #220
costina's Avatar
costina
Looked at there site but really unsure tbh after an incident with techniclutch i am very cautious.
What power you running Si ?
Paul
Old Aug 23, 2014 | 07:57 PM
  #221
siscossie's Avatar
siscossie
3-door moonstone
It's 355.7bhp at the minute should be a bit more with the new inlet and a few other bits.
They are really good they had my two clutches ready in two days, they said they had a lot of people who have had a nightmare with techniclutch, easy to deal with and reliable.
Old Aug 23, 2014 | 08:03 PM
  #222
siscossie's Avatar
siscossie
3-door moonstone
Got the sump fitted today and got the fuel pressure reg cleaned
Stripped the inlet manifold need to get it blasted
Get the pulleys back on Tuesday need to get the clutch on now
Old Aug 23, 2014 | 08:04 PM
  #223
Cragrat's Avatar
Cragrat
sit boo boo sit
RSty is about done matey (has been for a little while,been too busy working to even drive the bloody thing!!) just an issue with the back brakes and engine to run in
Spesh is gonna hopefully sort it this week so I can get it to the classic car show at ripon next sunday,good to see you if ya make it blue
Old Aug 23, 2014 | 08:08 PM
  #224
siscossie's Avatar
siscossie
3-door moonstone
Sounds good will try to get there mate, don't think mine will be ready ha ha.
Old Aug 23, 2014 | 08:09 PM
  #225
Cragrat's Avatar
Cragrat
sit boo boo sit
Lazy fucker!!!
Old Aug 25, 2014 | 03:32 PM
  #226
siscossie's Avatar
siscossie
3-door moonstone
Little bit more done today new fuel pipes to the reg and rail and got the flywheel fitted will get clutch on tomorrow
Old Aug 26, 2014 | 07:15 PM
  #227
siscossie's Avatar
siscossie
3-door moonstone
Clutch fitted tonight had a quick half hour in the garage
New inlet arrives tomorrow
Old Aug 26, 2014 | 07:22 PM
  #228
These engines are a piece of piss to work on. Keep up the good work.
Old Aug 27, 2014 | 05:15 PM
  #229
siscossie's Avatar
siscossie
3-door moonstone
Just got home to a large parcel
Got to pic the trumpet part of the inlet up from the powder coaters tomorrow and the pulleys so should be able to start putting it together.
Old Aug 27, 2014 | 05:16 PM
  #230
sridgett's Avatar
sridgett
The only way is dagenham
Just like xmas in your house mate.lol
Old Aug 27, 2014 | 05:46 PM
  #231
siscossie's Avatar
siscossie
3-door moonstone
Ye just as expensive too ha ha
Old Aug 30, 2014 | 07:18 PM
  #232
siscossie's Avatar
siscossie
3-door moonstone
Got pulleys back from powder coaters got a couple fitted
And got a pin for the clutch fork to pivot on
Old Aug 30, 2014 | 08:39 PM
  #233
costina's Avatar
costina
Si, Just a tip make sure your alternator bracket still has a good ground now its been painted
Looking good,
paul
Old Aug 31, 2014 | 06:34 AM
  #234
siscossie's Avatar
siscossie
3-door moonstone
Looking good,
paul
Cheers for the tip bud will make sure it's cleaned off
Old Aug 31, 2014 | 07:58 AM
  #235
fezzajsy's Avatar
fezzajsy
Coming along nicely
Old Aug 31, 2014 | 02:47 PM
  #236
siscossie's Avatar
siscossie
3-door moonstone
Fitted the clutch fork pin easier then expected straight in
Old Aug 31, 2014 | 02:52 PM
  #237
siscossie's Avatar
siscossie
3-door moonstone
Old Aug 31, 2014 | 04:20 PM
  #238
siscossie's Avatar
siscossie
3-door moonstone
Got the inlet trumpet section back from the powder coaters
Old Aug 31, 2014 | 07:33 PM
  #239
Nice new parts.
Old Sep 1, 2014 | 06:04 PM
  #240
siscossie's Avatar
siscossie
3-door moonstone
Tonight's task to get the block back in after a bit of a tussle it eventually went in
Decided to sent the inlet plenum for polishing so can start to reassemble all the bottom end stuff while waiting for that
