Fiesta Cosworth a few years later!
hi everybody i dont really post on here im usually on fiestaturbo.com but thought i would post on here aswell to get more peoples comments etc. so here goes
i had the car acid dipped at surface processing earlier in the year so i could see exactly what i was left with. the shell come back pretty good tbh but i have replaced both rear quarters front panel and front wings with all genuine panels, the shell has been fully seam welded. the bottom has been etch primed and body sealed and thats as far as i have got atm! although im building up a pile of bits and il let the pictures do the talking.
little spec, obp floor mounted pedal box, area six inlet and exhaust manifolds.. will also be doing all my head work aswell, tial external wastegate, gt35 dual roller turbo, pectel t2 managment, mk5 hubs, zetec s rear beam, wilwood 4 pots "may upgrade to 6 pots" focus rear hubs calipers etc, escort cosworth wheels.. list goes on but cant think right now!
any comments please post them up
cheers.
luke_mk3_st
luke_mk3_st
as for the seam welding if i were to do it id use short 25-30mm bursts with a 25-30mm gap between to allow for cooling and demand on the machine you can see where the welders either no man enough or on the wrong power setting
however it will be fine on this im sure as its still an improvement over the standard shell
i would suspect he didnt bother and that the car will drive 100% straight the heat from a small mig like that on a small part of a panel at a time when a cars already fully spot welded i'd be very suprised if it would distort anything important
cheers for the comments people should have another update shortly
oh ok cool does that make the escos wheels stick out further cos ive got escos wheels for mine and with the standard axle the wheels pretty much stick out to the limit
awsome build tho
awsome build tho
haha tbh when it was getting done i was thinking i cant see this being able to go straight on the frame cus theres gonna be alot missing! but it come back and there was so little rust we was all amazed, was a really good shell. there was only like 4 holes in the whole shell! otherwise it would of gone on stands 1st. cheers.
great thread mate, but should you not have had it dipped in the ecth primer so it can seal all the tiny gaps etc? love what your doing, il pm you pics of thre fiest i bought that had escos wheels on it
thanks mate would appreciate that, and it was suppost to be e-coated but as it was dipped by surface processing they said to me they no longer offer the full emersion e-coat! so i couldnt get it dip protected! so now im just doing my best to etch it and protect it. so really surface processing done me over but have to make the best of a bad situation!
il sort pics asap
ye true! well im using u-pol acid 8 etch primer. seam sealer, stone chip and paint, also as much waxoil as i can! pain in the ass but nothing i can do! thanks mate.
id be pouring etchy down the insides of chassis legs ect a take it they all be stripped to bare metal would be a shame to see this car all finishished then a year down the line its rusting from inside out well done but mate loads of work gone into this allready and a fare bit of cash id defo be getting a bigger welder tho some of the welds dnt look that great and to be honest if you dnt burn the weld into the thing your tryin to weld then theres no point in welding it your just adding weight
cheers.
when i was looking into it alot of people was saying the samething about what are you gonna do if the car comes out with not alot left! i was like id be happy because now i no that im not driving a car thats being held together by rust! my car cost 750inc vat. but cant get it protected anymore so have to get it etch primed somewere.
just a little update done a bit of stone chipping earlier, still got some to do but getting there, also a little bit of etch priming inside, getting there slowly but surely not going as quick as id liked but work is slowing me atm! here you anyway, comments welcome.
i also have a st170 6 speed gearbox forsale 45k miles with inner cv joints/ half shaft. Ł150 . iv got a pro alloy double capacity intercooler forsale, it cost me 265 from pro alloy a wile back now. il take Ł80 for it, also have a airtec alloy radiator this cost me about Ł240 il take Ł150 for it, both of these are in very good condition and i only run them for about 4 months then i stripped the car and they have sat in the garage ever since, they have some cosmetic marks but thats it. open to offers on these. photos to follow. cheers.
ps i have put this here as i cant advertise in the forsale section. if someone wants to advertise it for me and just put a link to this thread in there then i would be greatfull thanks.
few updates, i have mounted evo 8 hks camber and castor adjustable top mounts to the mk3 fiesta, also changed the bulkhead for a mk3.5 powersteering part as you can see. the front turrets have been custom made to accomodate the top mounts theres not finished yet but ul get the idea
also just dropped the engine in to get its position. let me no what you think!
