My 2wd saff cossie project 28/5/13 PICS!
Old 22-10-2012, 12:42 PM
  #841
J1mbo
B1mbo
J1mbo's Avatar
Sure am mate
Old 23-10-2012, 08:39 PM
  #842
J1mbo
B1mbo
J1mbo's Avatar
More done tonight.
Engine mounts blasted and fitted with new plated bolts as per usual.
Front covers fitted with new seals, as above, blasted and new bolts
Front pulley back from hard anodising and out together with 36-1 trigger
Ring gaps done, pistons fitted to rods, and fitted. Rods torqued and ten studs torqued in.
Some more tomorrow night as aiming for the dyno the weekend.
Jim
Old 23-10-2012, 08:43 PM
  #843
AJC
PassionFord Gold Member (Male)
AJC's Avatar
Very nice
Old 23-10-2012, 08:44 PM
  #844
Sticky.
Sticky.'s Avatar
Slowly getting there mate.
Keep the updates coming.
Old 23-10-2012, 08:46 PM
  #845
J1mbo
B1mbo
J1mbo's Avatar
Cheers boys, flat out now, next couple weeks should see it plumbed up in car, he says lol
Old 23-10-2012, 08:55 PM
  #846
carlo
carlo's Avatar
Nice one jimbo
Old 23-10-2012, 09:08 PM
  #847
v man
Zee Germans are coming
v man's Avatar
any head work pics jimmy or have I missed that one
Old 23-10-2012, 09:18 PM
  #848
J1mbo
B1mbo
J1mbo's Avatar
Check a few pages back, it's a waples head for 500 to 650bhp as I want scope for the future without stripping the engines, has a nice pair of cams, they're big but I'm hoping will work well for where I want my peak power for the gearing I'm on. And just generally make a bit of an animal to be a moron in that's all I need lol.
Cheers carlo
Old 24-10-2012, 03:42 AM
  #849
Gav Diamond
Gav Diamond's Avatar
Looking great jim, nearly as good as my engine, lol
Old 24-10-2012, 07:17 AM
  #850
J1mbo
B1mbo
J1mbo's Avatar
Haha! I think yours I'll be more powerful!
Old 24-10-2012, 07:54 AM
  #851
COCHYN
COCHYN's Avatar
Would have thought you'd use allen hey head bolts on those arms, shocking
Looks mint pal, keep up the good work!
Old 24-10-2012, 09:42 AM
  #852
J1mbo
B1mbo
J1mbo's Avatar
Original fitment ftw
Old 24-10-2012, 09:45 AM
  #853
COCHYN
COCHYN's Avatar
Gay
Old 04-11-2012, 09:26 PM
  #854
J1mbo
B1mbo
J1mbo's Avatar
Well, i havnt been updating much as ive been flat out working late nights to get it on the dyno, my aim was last weekend but didnt make it, so this weekend it was! here is the rest of the photos from the build.
oil jets in and bottom end completed bar oil pump.
head on and cambelt on with front pulleys
dizzy blank
new core plugs
mk motorsport drop bracket
sump looking good as new!
coming together
as usual, all new bolts
wrc breather bolted to the block and sealed in. modeen fitted and pipes made
getting tight!
return to sump done
rs500 water rail and the last wrc breather pipe done
turbo oil feed on
mount
front pulley bolts in
this is the last of the pics of the build.
so saturday the engine got loaded onto the dyno and it started first turn, awesome!
we ran it in most of saturday and set about some of the mapping saturday night. we saw some really strong figures and set about moving cam timing to see where the best compromise of torque, power and response using the superflo dyno options which are awesome, run through tests etc.
i sacrifised a little bit of torque to hold the power higher up but the torque is still awesome and the power and the way it holds it is awesome. im so so chuffed, it really is an amazing engine (should be considering the spec lol!)
anyway enough chat, heres the graphs
so when warm up is done its coming off the dyno, few jobs to finish off, then into the car. the pulleys and cam cover will be changed for the new items etc
Jim
Old 04-11-2012, 09:37 PM
  #855
Gav Diamond
As said before mate, awesome results
Well chuffed for ya, be good to see ours together to see the difference on the road
  #856
ginner
ginner's Avatar
Impressive mate, will be even better when it has a trottle cable clip, sorry bout that ill bring it when I pick mine up
Old 04-11-2012, 09:40 PM
  #857
J1mbo
B1mbo
J1mbo's Avatar
yes deffinately mate
haha no worries, was screwing yesterday for a clip on the dyno and remembered
Old 04-11-2012, 09:41 PM
  #858
james kiely
james kiely's Avatar
that engine really is a work of art jimbo
Old 04-11-2012, 09:43 PM
  #859
J1mbo
B1mbo
J1mbo's Avatar
thanks mate will look even better when all the nice new bits are on
Old 04-11-2012, 11:23 PM
  #860
cossie daz
cossie daz's Avatar
Looks great jimbo
Old 05-11-2012, 06:07 AM
  #861
scoooby slayer
scoooby slayer's Avatar
very nice mate and over 550 hp, what turbo is that ? it looks to come on boost well and make good power.
Old 05-11-2012, 06:19 AM
  #862
Minirotty
Lucifer II - 666
Minirotty's Avatar
Amazing build Jim!
Old 05-11-2012, 08:19 AM
  #863
ClevoCapri
ClevoCapri's Avatar
Looks and goes killer!
Man that will be some fun!
Old 05-11-2012, 08:49 AM
  #864
johnyjn
johnyjn's Avatar
Brilliant power result Jim well done. Did you change your mind about the exhaust cam ?
Is the oil pressure reading correct Jim .
Old 05-11-2012, 09:48 AM
  #865
J1mbo
B1mbo
J1mbo's Avatar
Cheers boys, yes oil pressure is correct john, 3.8 bar. What makes you say about exhaust cam? The inlet and exhaust are both big, bigger than the normal 500 spec we do
Scooby slayer it's a trick t4, marham 247 left hand hexagonal shaft converted to ball bearing.
Old 05-11-2012, 09:57 AM
  #866
RONNIE AMIS
RONNIE AMIS's Avatar
Looks lovely Jim!! Well done mate
Old 05-11-2012, 10:02 AM
  #867
J1mbo
B1mbo
J1mbo's Avatar
Thanks Ronnie
Old 05-11-2012, 10:12 AM
  #868
johnyjn
johnyjn's Avatar
Sorry Jim , I thought you where using a standard exhaust cam . Just asking with the oil pressure because it doesn't rise with the revs .
Old 05-11-2012, 10:28 AM
  #869
johnyjn
johnyjn's Avatar
Did you get my pm about the wheels ?
Old 05-11-2012, 12:20 PM
  #870
Gav Diamond
Oil pressure readings don't mean alot on this mate as each line of data, for example 3000rpm then 3500 rpm and so on and so on is a seperate pull.
Its not one run from 3500 up to 8000rpm its 10 runs.
Old 05-11-2012, 12:23 PM
  #871
J1mbo
B1mbo
J1mbo's Avatar
No chance mate, a Std exhaust cam would destroy this engine IMO, I don't like them but others do
Yes mate I'll reply tonight
Old 05-11-2012, 03:21 PM
  #872
Mad Matt
Rally nut
Mad Matt's Avatar
Great results and the build quality is really impressive !
Old 05-11-2012, 03:23 PM
  #873
bluntys1rsturbo
Boost addict
bluntys1rsturbo's Avatar
that engine looks brilliant love the attention to detail and all the new little bits
also looks like a real strong engine there should upset a few people out there
Old 05-11-2012, 05:16 PM
  #874
andy888
andy888's Avatar
looks shit.................
only kidding its a work of art! be good to see it in the car. my old 3 door was a touring spec engine with T4 etc and loved the kick it gave you! 2.5 bar ftw!!
Old 05-11-2012, 05:18 PM
  #875
J1mbo
B1mbo
J1mbo's Avatar
Thanks boys!
Blunty that is the plan lol!
Andy in the car e spike of boost might be a bit higher but for transiently 32/33 is plenty lol
Old 05-11-2012, 05:36 PM
  #876
BRAMMER
BRAMMER's Avatar
Well it certainly looks the part Jim and produces the power to match
Question Jim regarding boost drop towards the end of the cycle, mine peaked a certain pressure then dropped back towards the end and some on here commented theirs peaked all the way to limit which i know they don't, can you tell me why they drop off is it in the mapping?
Old 05-11-2012, 05:46 PM
  #877
J1mbo
B1mbo
J1mbo's Avatar
Back reassure usually mate, the BP starts to push the wastegate open, I kept putting more preload on and got to a point when I thought that's enough, it's made awesome powerso why keep looking for more
Old 05-11-2012, 05:48 PM
  #878
BRAMMER
BRAMMER's Avatar
Right that pretty much answers it mate
So then Jim what's the deal with the gearbox side of things? would you stay T5 with gearkit or different unit?
Old 05-11-2012, 06:08 PM
  #879
J1mbo
B1mbo
J1mbo's Avatar
Well, the torque is higher than I expected so I do beleive it won't last long, but I have a few ideas in the pipe line
Old 05-11-2012, 06:59 PM
  #880
Mr RS500
Mr RS500's Avatar
T4 Power
proper engine that Jimbo , and going in a proper car
Quick Reply: My 2wd saff cossie project 28/5/13 PICS!
