Sierra cosworth 24v turbo! home built and mapped
Old 15-11-2010, 01:34 PM
  #321
chaffe
Turbocharging Technician
chaffe's Avatar
Originally Posted by m4tt274
ive seen 275bhp on vectra injectos and the same spec
and 260 a couple of times
so i think with biggger injectors 300 bhp shouldnt be to difficult with a good map
not sure the vectra injectors are big enough for that, i looked into it, max 240bhp on them, unless the fuel pressure was screwed up big time?
Old 15-11-2010, 04:08 PM
  #322
m4tt274
m4tt274's Avatar
that green capri mk1 with the 24v in pulled 278 fly on vectra injectors as i recall
Old 15-11-2010, 05:05 PM
  #323
tjRS500
tjRS500's Avatar
dont see why i shouldnt see more than 300bhp then if u can get that on a lesser spec'd boa matt.
not taking a dig im just stating.
Old 16-11-2010, 07:27 AM
  #324
chaffe
chaffe's Avatar
196cc/min flow rate? must be running the injectors at 100% duty cycle? certainly absoloutly no more bhp available with those injectors, when you do yours i woulod go with something bigger mate im using 306cc/min redtop turbo ones, prob flow enough for 360bhp at std fuel pressure, 400bhp at 4 bar fuel pressure.
Old 16-11-2010, 02:19 PM
  #325
m4tt274
m4tt274's Avatar
i will be using differant injectors mate, havent looked into which ones yet, but should manage.
ive not seen any BOB's produce big power N/A yet but thats more because there haven't been many yet.
i could be tempted to put BOA heads on a BOB block to get the higher compression, but not sure if it would work :/
Old 16-11-2010, 03:28 PM
  #326
tjRS500
tjRS500's Avatar
Not really worth the hassle. U may aswell go full bob if your considering swapping. Better base to start with, I have been in a few boas and the difference is night and day power and noise wise
Once u go Bob u will never go back mate
Old 16-11-2010, 03:56 PM
  #327
m4tt274
m4tt274's Avatar
i was the opposite actually, i didnt like the bob. it sounds too smooth and flat + its ugly as hell!
a low compression engine producing 200bhp is better than a high compression engine producing 200bhp :')
Old 16-11-2010, 04:30 PM
  #328
tjRS500
tjRS500's Avatar
All I Care about is that it's faster.
They are both great engines,
If I was turbo'ing id go for boa,
But a well tuned n/a bob is in a different league imo
Old 17-11-2010, 07:07 AM
  #329
chaffe
chaffe's Avatar
The difference between a turbo boa and an NA one is night and day lol was out in my car last night, 5 psi atm, still fucking rapid lol. I tried a bit of left foot braking to load up the engine for mapping and it just spun the rears lol
Old 17-11-2010, 07:08 AM
  #330
chaffe
chaffe's Avatar
When going with aftermarket management a problem might arise in controlling the variable cam timing on the bob ( think it is variable?)
Old 17-11-2010, 09:57 AM
  #331
Damocos
Damocos's Avatar
No its only got a 'VIS' A variable intake system, it opens and closes a flap within the inlet manifold to spread the torque at certain revs. Aftermarket management will have a control to do that
Old 17-11-2010, 10:01 AM
  #332
Damocos
Damocos's Avatar
So its good then Mine's all done but with chrimbo looming i aint got the funds to get mine mapped:-( Im not that good with the laptop either and cant seem to sort the basics out to make it run properly....... Mind you the screamer pipe does sound the tits
Old 17-11-2010, 10:13 AM
  #333
chaffe
chaffe's Avatar
Yeah mate, the turbo works lol, ive got an internal gate now as i changed my turbo. Need to enlist the help of a mateto tune my car as its quite a task working the laptop and driving at the same time lol.
Old 17-11-2010, 10:14 AM
  #334
chaffe
chaffe's Avatar
Or throw it in the bin
Old 17-11-2010, 10:15 AM
  #335
chaffe
chaffe's Avatar
Old 17-11-2010, 10:22 AM
  #336
Damocos
Damocos's Avatar
Thats what i did with mine when i Turbo'd it
Old 21-11-2010, 02:45 AM
  #337
bigryrs
RSHoleinator
bigryrs's Avatar
The lum!
Old 23-11-2010, 03:09 AM
  #338
crumpet
crumpet's Avatar
wideband looks so diy haha this thing nearly ready yet bud?
Old 23-11-2010, 03:18 AM
  #339
bigryrs
RSHoleinator
bigryrs's Avatar
think its ready for an mot mate but not 100% sure
Old 23-11-2010, 03:36 AM
  #340
crumpet
crumpet's Avatar
wicked, why you up anyway?i suffer with insomnia whats your excuse? lol
Old 23-11-2010, 04:21 AM
  #341
bigryrs
RSHoleinator
bigryrs's Avatar
offshore on nightshift lol whats your excuse lol
Old 23-11-2010, 05:44 AM
  #342
chaffe
chaffe's Avatar
Yeah its going for a test on fri, thats cos the wideband is diy! works a treat mate
Old 23-11-2010, 05:47 AM
  #343
chaffe
chaffe's Avatar
whats with the avatar lol
Old 23-11-2010, 07:08 AM
  #344
crumpet
crumpet's Avatar
never seen a 24v turbo before, you NEEED to get som decent vids of this when its sorted pal, you sortin the mapping yourself?
Old 23-11-2010, 07:15 AM
  #345
chaffe
chaffe's Avatar
yeah man, was out for a naughty tuning session last night, working mainly on the cruise and light throttle part of the map, so it can be driven to the mot testing station. The map is well rich on boost and very safe timing wise, @ only 5psi boost it pulls sooo hard lol, my original plan was about ten psi, but after last nights 3rd gear pull i may settle for a nicley tuned 7!!! i would think it would be 50bhp/cylinder at that.
Old 23-11-2010, 07:16 AM
  #346
crumpet
crumpet's Avatar
touch wood, are the boa's good for 300+ then? i wonder what it woul be like at 7-10 psi against a stage 3 cossie!...we shall see
Old 23-11-2010, 07:29 AM
  #347
chaffe
chaffe's Avatar
Yeah, people are getting 220bhp from them with just a remap NA, 300 bhp and 400lbft torque is no problem! ill will have good torque and low down grunt, what exactly is "stage 3"?
Old 23-11-2010, 07:30 AM
  #348
crumpet
crumpet's Avatar
stage 3 is from 320-360 on average, stage 3 t3 or t34 turbo, greens, 3 bar map, chip, exhaust, air filter, -31 and thats about it
Old 23-11-2010, 07:33 AM
  #349
chaffe
chaffe's Avatar
i see, I wonder what stage im at lol, stage 2.9 24v?
Old 23-11-2010, 07:36 AM
  #350
crumpet
crumpet's Avatar
haha people will think your just a 4x4 cossie by the looks of it, you should of left the exterior sleeper style on 15" steels with hubcaps lol!
Old 23-11-2010, 07:37 AM
  #351
chaffe
chaffe's Avatar
yeah that would be funny! had a few sleepers so fancied something a bit more "showey" though
Old 23-11-2010, 07:43 AM
  #352
crumpet
crumpet's Avatar
and fair play to you for doing so pal, mallard saphs look ace! i would love a abergine one parked next to yours
Old 23-11-2010, 07:45 AM
  #353
chaffe
chaffe's Avatar
that would look gucci, theres a challenge for you now!
Old 23-11-2010, 07:50 AM
  #354
crumpet
crumpet's Avatar
haha what ever colour car i get im leaving it , doin underside resto and engine bay resto and thats it, if i was to get a saph and had money to waste id want to do it aubergine, nightfire red or a really deep metallic brown, money not needed to be spent though lol
Old 24-11-2010, 01:00 AM
  #355
bigryrs
RSHoleinator
bigryrs's Avatar
avatars quality
Old 24-11-2010, 07:41 AM
  #356
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Good luck with the MOT
Will you get the car on the rollers once you have mapped it ?
Steve
Old 24-11-2010, 07:55 AM
  #357
chaffe
chaffe's Avatar
Steve
Thanks, should be a pass, emmisions is 1.2%co, 200 ppm hydrocarbons, and lambda 1, Yeah course its going on the rollers mate, ill post up figures when i get them.
Old 25-11-2010, 05:41 AM
  #358
bigryrs
RSHoleinator
bigryrs's Avatar
Mot tester will be commenting on how shiny the rst pipe hanging oot its arse is!
Old 25-11-2010, 06:46 AM
  #359
chaffe
chaffe's Avatar
its covered in black reek, just the way i like it
Old 25-11-2010, 05:14 PM
  #360
bigryrs
RSHoleinator
bigryrs's Avatar
Get the metal polish oot! nice and shiny lol just like the autospecialists gear you love
Quick Reply: Sierra cosworth 24v turbo! home built and mapped
