Track saphhire
Old 17-05-2011, 05:55 PM
  #241
Brettski mk2
Brettski mk2's Avatar
I sold the stage 3 rear beam and took a standard beam and arms over to scs to get one of there beams,Then with standard style rear arms I at least can fit the bladed a/r/b links and have somewhere the weld the brackets to the arms
Mounted the oil cooler to the n/s space behind the bumper and routed the pipe work up nice
And have been pissing about with a celica breather system that just need a bracket or two to fit nice and a -10 fitting welded on to suit the three pipes on a cossie
Pic on celice st165
Will need to be painted after welding but will fit nice
Old 21-05-2011, 07:00 PM
  #242
Brettski mk2
Need to get the drain bung moved on the bottom to the side and one more -10 fitting welded on but it fits ok
mounted the filter housing and cooler
Anyone able to tell me what size the fittinf is in the turbo? turbo side is 1/8 NPT and the hose side I think is bsp but ....?
Old 21-05-2011, 07:26 PM
  #243
RONNIE AMIS
RONNIE AMIS's Avatar
looks stunning mate well done.
withthe track rod ends, where did you get them from? and what will you use for a bolt and spacer?
interested as i am thinking of doing it
thanks
Old 21-05-2011, 07:52 PM
  #244
Brettski mk2
Hi Ronnie
The bolts are these m14x70mm 12.9
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300367077302&ssPageNam e=STRK:MEWAX:IT
m14 with 14mm hole Rod ends
http://cgi.ebay.co.uk/M14-Female-RH-HIGH-PERFORMANCE-Rose-Joint-14mm-ROD-END-/380276945917?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item588a45b3fd
And my mate made me some spacers up keeping the steering arms the same angle as the lower arm...may need to tweek the spacer hight
Old 21-05-2011, 08:05 PM
  #245
scottyrs
DURHAM RSOC
scottyrs's Avatar
looks great mate! is there any progress on the silver saff you bought off my mate ben?
Old 21-05-2011, 08:17 PM
  #246
Brettski mk2
Hi its nealy finished mate
He needs a rad and rear brake pads,fit the front bumper,bleed brakes up,fit the extaust new front wheel bearings that sort of stuff
He is a bit slow now ...and hes so close to finishing it
Old 21-05-2011, 08:22 PM
  #247
RONNIE AMIS
Originally Posted by Brettski mk2
Hi Ronnie
cool, thanks for the links mate, RE the spacers are they tapered to fit into the arm on the hub?
love the car by the way
Old 21-05-2011, 08:30 PM
  #248
Brettski mk2
I have the alloy uprights and the bolt on arms have M14 hole in so just tapered the top to allow the rod end the move
I ll get a pic of the spacer soon
Old 22-05-2011, 07:40 AM
  #249
Kieron
Kieron's Avatar
Chipping away at it mate. Christ knows where you find the time with a young familiy and all!
Old 26-05-2011, 08:08 AM
  #250
James_RScos
James_RScos's Avatar
Looking good Brett! when will we have lift off pal?
Old 10-06-2011, 02:40 PM
  #251
Brettski mk2
Got the front all on now and it can stay on this time and orded a new wind screen,the dash is off to autoflock for flocking next week.
I have orded a SCS 6 degree beam so when I get that it will be rolling!!!
I need check straps on all 4 corners as when you jack the car up the shocks hang to low and try to pull the front drive shafts out
bit of Carbon
Old 10-06-2011, 02:42 PM
  #252
Brettski mk2
This year some time but funds are low now
Old 10-06-2011, 02:46 PM
  #253
J1mbo
B1mbo
J1mbo's Avatar
morettes look well!!
Old 10-06-2011, 03:03 PM
  #254
scarnny
scarnny's Avatar
Go brett, good to see progress.
Old 10-06-2011, 03:32 PM
  #255
Brettski mk2
Cheers even the same shade of white
Old 10-06-2011, 03:34 PM
  #256
Brettski mk2
Cheers mate,yous finished yet?not seen it ripping though the green
Old 10-06-2011, 04:43 PM
  #257
scarnny
scarnny's Avatar
No not finished yet but did rip it round the block with arbs, goes well to say the least.
Old 10-06-2011, 05:45 PM
  #258
J1mbo
B1mbo
J1mbo's Avatar
Result!
Old 12-06-2011, 10:25 PM
  #259
Big_Mike
Big_Mike's Avatar
Someones been busy!!!! Looks epic
Old 23-06-2011, 08:03 PM
  #260
Brettski mk2
Got the dash flocked by Raj at autoflock looks well
Had to make a new pas pump feed pipe because the grp A roll bar hit the ford one!
And got a full coner built up and sorted
Old 23-06-2011, 08:07 PM
  #261
J1mbo
B1mbo
J1mbo's Avatar
Looks great Brett
Raj is the kiddy when it comes to flocking
Old 23-06-2011, 08:11 PM
  #262
Kieron
Kieron's Avatar
Getting there mate, looks good.
Old 23-06-2011, 09:42 PM
  #263
BigErn
BigErn's Avatar
First time Ive seen this. Gonna be a great piece of kit when its done
Old 24-06-2011, 10:06 AM
  #264
James_RScos
Looking great Brett, really looking forward to more updates
Old 07-09-2011, 09:17 PM
  #265
Juan Nogueira
Juan Nogueira's Avatar
Default Nice
Nice project !! What Shocks are you using ?
Have the ahmed bayjoo/scs rear beam better clearance that adrenaline ? or what is the problem for change from adrenaline stage 3 to scs ?
Best Regards
Old 08-09-2011, 05:19 PM
  #266
Brettski mk2
Best Regards
Hi, there jumbo grp a ohlins
adrenaline stage 3 needed modifications to the body and I don't think the trailing arm are strong enough,there strong enough not to brake just twist and flex in the corners
hth
Old 08-09-2011, 05:39 PM
  #267
RSLUBBY
RSLUBBY's Avatar
Looking good mate get some graphics on it
Old 10-09-2011, 07:34 AM
  #268
Brettski mk2
On the car?would it pull it off or would it look crap
Old 10-09-2011, 07:42 AM
  #269
RSLUBBY
RSLUBBY's Avatar
Have a look at what ive done to mine and make your mind up graphics look great mate. I have a thread under restos on first page i have gone old skool turbosystems safari but with a repsol colour scheme i think it looks mental but not to everyones taste
Old 10-09-2011, 07:45 AM
  #270
Kieron
Kieron's Avatar
Would ruin it imho.
Old 10-09-2011, 09:52 PM
  #271
Brettski mk2
I,m up to my neck in suspension problems now fucking car and nearly want to break it!!
Ohlins shocks are to long so need to lower the car over them to get the shock travel right just as tony from "tcs" told me I would understand what you mean now tony
So I now have to cut the newly painted suspension turrets off and raise them up. should I go wrc top mounts of weld a ring in to the turret and still use the grp a top mount! ....how do you calculate the amount you need to raise them by ...help"Tony"
Fooking hate this car now and when its finished I will thrash the fooking thing round ford fair like a rally stage!!!!kill hate kill hate!!!!laying rubber until I'm told off
Old 10-09-2011, 09:59 PM
  #272
Richie.
aka Turbosailorboy
Richie.'s Avatar
Location: Under the water.... .......in a nuclear submarine
Shit news about suspension
Just bought myself the WRC style stuff to fit to the Escos. Raises the bearing up quite a distance vs the shitty compbrake ones i had fitted.
Old 11-09-2011, 08:09 AM
  #273
Brettski mk2
The wrc mounts and weld on bit cost a bit don't they???What suspension are you using Richie
I have the grp a top mounts
I will cut the top off neat and weld a ring in lift the mount up so the bonnet just clears them
Old 12-09-2011, 05:22 PM
  #274
Brettski mk2
Got told to day that you can get the shocks shortened? anyone had it done. The shocks are irish tarmac so long but stiff.If I use them at my required ride hight I have bugger all travel
Have we got any set up exsperts on here then??
Old 12-09-2011, 05:34 PM
  #275
Brettski mk2
At the ride hight with all the cars weight on them
Unloaded
Loads of travle
Old 12-09-2011, 10:24 PM
  #276
Bloomers
Cornish Fasty
Bloomers's Avatar
Just read the thread start to finish. awesome build, buddy, keep up the good work. beautiful work
Old 12-09-2011, 11:00 PM
  #277
Richie.
aka Turbosailorboy
Richie.'s Avatar
Hi Brett, these are the top mounts You dont want to ask how much they are
As for choice of suspension.......well the current Koni/Ahmed combi are going to have to go in favour of something like B.A.D or similar. Depends if i go to billet uprights on the front as well
Don't make them too big or you will need AG Focus style holes in the bonnet
Old 12-09-2011, 11:18 PM
  #278
Brettski mk2
Where did you get them from the mounts and weld on bits
Pm me the price??
Old 12-09-2011, 11:27 PM
  #279
Richie.
aka Turbosailorboy
Richie.'s Avatar
Pm me the price??
All available from Dewitts
http://www.dewitts.co.uk/
You have pm
Old 13-09-2011, 07:26 AM
  #280
Lo@der
Passionford Thread Killer
Lo@der's Avatar
How have I missed this thread , gonna be a great bit of kit .
Quick Reply: Track saphhire
