Painting the engine bay
Old 14-09-2009, 05:08 PM
pacwest
Puller of the Wrench
pacwest's Avatar
Default Painting the engine bay
I'm disgusted with the paint that my engine sits in. So at some point in the next month or so I'm going to tackle this. 3 door sierra
HVLP gun
Mig welder
Sandpaper
3M Scuff pads
Tape
Paper
Kerosene
So clean it up, scuff it down and squirt it. Easy right? What have you done? Did you remove the entire engine and move as much stuff out of the way such as wiring, brake pipes etc.? Or did you just mask everything off and just make it easy?
I'd like to weld up some of the silly assembly holes Ford left on there and make it smooth as well.
Did you just spray some basic high quality paint that matched your body or did you go full base coat clear with correct paint codes for the body as well?
I have time and this car isn't on the road yet, so removing the motor is not a big deal. Opinions?
Old 14-09-2009, 05:26 PM
dingla rs
dingla rs's Avatar
HVLP gun
Mig welder
Sandpaper
3M Scuff pads
Tape
Paper
Kerosene
kerosene as in boiler oil???
engine out degrease bay, weld holes up,fill an sand ,mask up primer ,sand or wet an dry depending on the finish u want. depending on what colour ur car is ,either be base clear or solid colour ,
ps if you us same gun for the priming make sure you strip an clean it before top coat
Old 14-09-2009, 05:55 PM
pacwest
pacwest's Avatar
Kerosene. I think you guys call it paraffin. It's a great thinner/cleaner for grease removal that doesn't hurt electrics or rubber seals.
Old 14-09-2009, 06:01 PM
dingla rs
dingla rs's Avatar
ow ryt was gna say we use kerosene over hear in oil boilers for heating lol get u mean parafin now m8
Old 19-10-2009, 03:49 AM
pacwest
pacwest's Avatar
A bump for any pointers/help.
Kyle Langford
27
05-08-2019 07:54 PM
bigryrs
28-03-2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
21-01-2016 09:54 PM
RSmark84
20
24-08-2015 02:17 AM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: Painting the engine bay
