12.6 second XR2T------THE END------
Old 13-03-2005, 04:50 PM
  #41
M K
M K's Avatar
cheers mate
will send me dash of soon to be flocked like yours
just waiting for some 1 to get me the dash as i wanna keep mine in while a spare is done then just swap over
Old 14-03-2005, 05:39 PM
  #42
M K
M K's Avatar
i fitted the brakes on saterday an took a few pics to show the comparisons between the standard 1's & the new 4 pots,,,
i bled them sunday but they need doing again so cant comment on there capability yet but ive been told by others who have them that they are superb
callipers comparison
disc comparison
another comparison
4 pots & 283mm disc's fitted
all fitted including wheels
will bleed them again when i get a chance & let you know how good they perform
Old 14-03-2005, 06:03 PM
  #43
M K
M K's Avatar
also some pics of some of the cossie management parst that have been collected over the past couple of months
the end is getting nearer,,,lol :blub:
P8 ECU & DARK GREENS
GROUP A COSWORTH ALS THROTTLE BODY
IGNITION AMP & ISCV (to be modded for als)
FRST INJECTOR RAIL & FUEL PRESSURE REG
COIL PACK FOR DIZZYLESS IGNITION
EFI INLET MANIFOLD (to be modded for cosworth tb)
COSSIE ENGINE LOOM (still need ecu section of loom)
1.8CVH PARTS TO BE MODDED FOR THE COSSIE CPS(alternator bracket not in pic)
AND AN EFI CYLINDER HEAD WHICH WILL BE PORTED & POLISHED ETC FOR SPEC OF CAR
ALSO GOT 3 BAR MAP SENSOR & A FEW OTHER PARTS BUT NOT COLECTED THEM YET
may also have the cossie T34 TURBO later on 2nite (figers crossed) lol
Old 14-03-2005, 07:25 PM
  #44
rich p xr2t
rich p xr2t's Avatar
CHICKEN, do u think the 1800 cvh bottom pully will fit with the inner wing b'in so close. even after u have machined the pully?
Old 14-03-2005, 07:40 PM
  #45
M K
M K's Avatar
i was thinking the same but no 1 has told me otherwise,,,,,,, if it doesnt then i will have my original pully profesionally modded so that i can use it instead,,,,,
the price i paid for the 1.8cvh stuff im not too bothered either way,, gadget just advised he 1.8cvh set up as he said it looks more factory fit which is what im after
which set up are you planning to use???
Old 14-03-2005, 07:49 PM
  #46
rich p xr2t
CHICKEN, ive been told by a few people that the 1800 pully wont fit even after u have had it machined. im gonna get my turbo pully modded
Old 14-03-2005, 08:25 PM
  #47
M K
M K's Avatar
oh well its no hassle either way bud
Old 15-03-2005, 07:10 AM
  #48
BillyCabrio
BillyCabrio's Avatar
Location: Dartford, Kent - Home of the two way one way system.
Loving them brakes Marc, sweet as!
Old 15-03-2005, 10:19 AM
  #49
D19 STE
D19 STE's Avatar
Brilliant pics mate I have a set of those wilwoods going on my MK6 escort soon
Old 15-03-2005, 04:22 PM
  #50
M K
M K's Avatar
cheers guys
more soon
Old 15-03-2005, 05:02 PM
  #51
AndyNo1
AndyNo1's Avatar
Top work fella
Old 15-03-2005, 05:07 PM
  #52
Old 15-03-2005, 05:20 PM
  #53
Willem
Willem's Avatar
Great looking car m8, u did a very nice job there
Old 15-03-2005, 05:29 PM
  #54
M K
M K's Avatar
Old 15-03-2005, 05:45 PM
  #55
1900cvh
1900cvh's Avatar
looking good mate !!!!
When do u think u will have it back on the road ,with the ALS ?????
Old 15-03-2005, 06:02 PM
  #56
M K
M K's Avatar
the car is still on the road running the standardish series 2 engine at the mo,,,, as im not gonna take it off the road till i have everything,
i want it off the road for as little as poss but im aiming to have the new engine, turbo, gearbox & management running the als etc by end of april-may
i shall keep you inormed matey,,
are you gonna be running als too???
Old 15-03-2005, 06:12 PM
  #57
1900cvh
1900cvh's Avatar
O yes mate ALS all the way !!!
Old 15-03-2005, 07:05 PM
  #58
M K
M K's Avatar
Old 16-03-2005, 12:59 PM
  #59
Strippedfez
Strippedfez's Avatar
Oh my-That is one mint project from start to finsh!!
The car is totally stunning, i love the rs 7 spokes on it!!!!
Old 16-03-2005, 02:41 PM
  #60
chiz
chiz's Avatar
superb mate, gotta love the turbod xr2s......
will look amazin on compos
loved in rat mode with primer and that, superb!"!!
Old 16-03-2005, 05:04 PM
  #61
M K
M K's Avatar
cheers guys
just bought me T34 TURBO so pics of that soon
Old 26-03-2005, 05:50 PM
  #62
M K
M K's Avatar
just a small update of some bits ive sorted (no pics tho as i forgot )
after having my duflex poly bushes sitting in me garge for over 8 months still in their wrappers :blub: , i decied that id pull my finger out & get em fitted,,,
so a couple of weeks ago (i know i forgot to update it back then,,lol) i fitted the front strut top mounts which are a fiddly fooker to fit but not too bad, rear spring bushes, then last weekend i fitted the rear anti roll bar mounts along with the panhard rod bushes,
got very confused with the rear swing arm bushes as i was sure they'd sent me the wrong ones, but then read some 1 elses post on here about having to remove the metal sleeve the old mounts ae inside,,,so i will fit those 2moro as there the only 1's left to do now
2day tho i fitted the rest of the front bushes which were the tie bar bushes & lower arm bushes, along with a new set of lower ball joints for good measure
had a mare with the ball joints as 1 would not go in fully & as i hadnt check'd it it was touching the disc when i went to go for a test drive ,
so jacked the car back up & used the trolly jack & a piece of wood to push the ball joints into the hub fully,,, went to tighten the nut back up & the fooker snapped on me
so out came the odd's & sod's box to find a replacement till i go to fords in the week & all is sorted
no more grinding & the car is as stiff as a board now & feels awesome,, i would recomend poly bushes to any 1
the old bushes i removed especially the tie bar bushes were fooked & soft as sponge :shock: :shock: :shock: ,,,,
but thats not a problem with the ne 1's.
also for a while now ive had a realy bad knocking coming from the bottom end which i havent got round to sorting but today i noticed the alternator belt was a tad slack so i tightened that & then noticed the bolts holding the alt to the bracket were all loose so i tightened them up too & now the noise has stopped
so is been & eventfull weekend for the old turbo
more updates soon
& pics of the new t34 for the soon to be new set up
Old 27-03-2005, 09:46 AM
  #63
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
nice one chickeroo-poo
get pics up of that T34
Old 29-03-2005, 06:55 PM
  #64
M K
M K's Avatar
the gearbox is dead
After spending the weekend laying under the car fitting the poly bushes that ive had laying aroung for mnths,, ,, & fitting the new ball joints i took the car for a blat around to chris fosters & to the high street,then i gave it full beans off a round about on to a dual carriage way & bang went the gearbox
lasted year & a half & cost me Ł20 to have a series 1 lsd put in the standard xr2 box so i cant complain
so its now laid up in the garage with a dead gearbox & a leaking rad
NOW THE SERIOUS SPEC BEGINS!
i now have all my parts i was told to gather for my cossie management along with my T34 etc,,,
now ive found the engine im after for the car & will be in negotiations with the owner later this week so fingers crossed if i can put a deposit down & he can hang on to it for a bit longer then i shall post the spec up soon,,,,along with the gearbox that il be getting at the same time
then the car will be heading off to pro alloy for the rad & intercooler to be made so i have enough room for the t34 as im a bit tight for space on the set up im using now,,,,
then its management time & off to see gadget,,,, but 1st things 1st
so its getting serious now & the car will no longer be on the road till the new spec is sorted so watch this space for updates on the new spec
(i can hear my wallet crying already )
Old 29-03-2005, 07:22 PM
  #65
1900cvh
1900cvh's Avatar
Cant wait mate , should be sh*t hot when it all done !!!!!
Old 29-03-2005, 08:51 PM
  #66
BillyCabrio
I dont envy your wallet mate
Old 30-03-2005, 04:33 AM
  #67
M K
M K's Avatar
nor do i but its all good fun,,,, im not leaving this car till its 1 of the fastest fwd mk2's out there
Old 30-03-2005, 05:50 AM
  #68
Cant wait to see it done
Old 30-03-2005, 10:25 AM
  #69
BillyCabrio
Head to head with Rolls then
Old 01-04-2005, 06:00 PM
  #70
rich p xr2t
CHICKEN, well 2nd matey
Old 01-04-2005, 08:28 PM
  #71
luke89
Team HOTHOT!
luke89's Avatar
good luck with the new spec sounds a like its going to be mad
Old 01-04-2005, 08:36 PM
  #72
TNE
TNE's Avatar
Old 02-04-2005, 04:51 AM
  #73
M K
M K's Avatar
time will tell mate???
Old 02-04-2005, 11:11 PM
  #74
squizxr
squizxr's Avatar
good luck chick!!!!
see, quitting smokin has hel ya sve shit loads of money
Old 10-04-2005, 03:45 PM
  #75
rich p xr2t
CHICKEN, ave u done ur bottom pully yet mate?
Old 02-05-2005, 06:12 PM
  #76
M K
M K's Avatar
rich - not done me pully yet but that is whats to be done next as i will see if it fits while ive got the dummy block in there to play with,,,,,so il let you know?
right its gone a bit slow all of a sudden now but im starting the process of removing the old engine,,
just left the block in there for the mo as it will be used as the dummy along with an old head while i have the inlet manifold made
which i will post a pic up in a week or 2 once it has been done,, but believe me you WILL like it
so just a couple of pics to show how she is sitting at the mo,,,,lol
still gotta strip out the rest of the loom & all the brake servo & cylinder as its all going
more info & pics next week hopefully
Old 03-05-2005, 01:14 AM
  #77
Charlie Chalk
Unknown.
good luck with it mate
Old 03-05-2005, 07:19 AM
  #78
Cant wait to see the manifold
Old 10-05-2005, 04:07 PM
  #79
rich p xr2t
M K, any more pics mate? wot inlet manifold r u using mate?? r u goin fiesta in the park on sunday????
Old 11-05-2005, 09:45 PM
  #80
M K
M K's Avatar
SLOW PROGRESS
but starting to get very expensive now as the spec gets more serious every day
rich p xr2t - the inlet manifold is a custom made job by a friend, il post pics & spec as soon as the finished article is ready in a few weeks
but in the meantime here is my new turbo
spec as follows -
GROUP A T34, CUT BACK BLADES, 360 deg BEARINGS, .63 ZORST HOUSING, 247 MARAM SHAFT etc,, all enabling me to run agressive anti lag long with the inlet spec im having & proper specced zorst valves for the head to cope with the excessive heat etc,, enjoy
shaft is stamped with the 247 maram code but forgot the pic
still fitted with a trumpet for air flow restriction i believe as the neck is very narrow (correct me if wrong)
also started stripping the interior to refit flocked dash etc inspect floorpans
but all looks good so far
more soon
Quick Reply: 12.6 second XR2T------THE END------
