200bhp ka updated 20th feb
my new ka got it really cheap so gonna move every thing over to my sportka as this shell has seen better days and theres quite a bit of rust on her
at the moment its losing water from the thermostat housing how much to replace it?
engine spec
1.6 cvh
modified head
8:7:1 comp ratio
svm320t cam
piper pulley
forged pistons
garret t3
baily dump valve
ramair filter
3" straight through exhaust from turbo
charge cooler
oil cooler
7psi of boost with 16psi on over run switch
fueling...
its got some form of swirl pot
cossie pump
suspension
gaz fully adjustable coilovers
brakes.
cossie fronts
standard rear
wheels
16" escort gti alloys in white
interior
momo steering wheel
frst recaro's
4 point harnesses
will get some daylight pics tomorow
engine spec
1.6 cvh
modified head
8:7:1 comp ratio
svm320t cam
piper pulley
forged pistons
garret t3
baily dump valve
ramair filter
charge cooler
oil cooler
fueling...
cossie pump
suspension
brakes.
cossie fronts
standard rear
wheels
interior
momo steering wheel
frst recaro's
4 point harnesses
Like that mate, shame about the keying
Thermostat housings are kicking around, i seen a polished one for sale £35 delivered. Might just be a gasket though? Have a ganders in the rst parts for sale section
Good luck with the build mate
gonna try give it a clean up tomorow and then take some pics
i just remembered that the charge cooler hose on the top its not a boost hose was loose this is my first ever turbo'd car and i dont really know what or how a charge cooler works.
i love that Ka, im hoping to get my girlfriends off her and in place of the 1.3 hcs engine im putting in a zetec s 1.6. I cant believe the fact some dick has done that to your car, only thing i would say is i prefer the standard front lights (just my opinion). otherwise it looks sweet.
A chargecooler (air-water) does the same job, but in a different way. It is basically a heat exchanger which uses water as an intermediary fluid, (as opposed to air) which is then in turn cooled by its own radiator. Simply put its more or less an intercooler in a box with water being pumped round it, this water is then fed through another radiator to cool it down. Usually used where space is a concern.
Hope thats useful mate, liking the project
On a normal air-air intercooler air passes over the fins and "takes the heat away" as it were (more technically called Isochoric Process if you want to read up more about it)
Nice project you have there. A mate of mine was going to do an RST conversion in his, but ended up with a bolt on turbo jobbie sent over from the states instead....
He made a good few mags with it, but this one is extremely tidy looking. Good luck with it mate!
cheers mate...the engine will be in my other ka by next saturday so theres gonna be alot of updates this week.
TPM961
15-01-2018 10:50 AM
STAFFY OWNER
13-09-2015 08:59 PM
