ZAKSPEED ESCORT 4x4 500+HP (328mm rear discs machined rear spoiler profiles here )
#2365
just be careful making the engine mount arms in ally Andy, the works cars used a steel arm on the exhaust side and a billey ally on the inlet side.
you can just see them here
I had a set of ally arms (sort of gpa copy type along time ago, they cracked at the welds to the plate on the block after a few gravel rallies, I would bore the block plate and weld the bar inside and out.
#2366
thanks for the info mark if the exhaust one becomes a problem then i will redo it in steel .
#2369
tis looking good andy!!
Do you have no steering UJ's inside the car?? Is that why you need the spherical bearings etc??
I suspect i will want to lower my wheel when i strip it and go for low buckets but ive got 2 UJ's in the cabin so i reckon i can easily lower it (and bring it nearer to seat) with minimal changes just cutting off the mount and welding it lower and a bit forward.
#2370
i got no uj's in side the car just the one in the engine bay & a spherical bearing mounted in the bulk head but the first one i fitted broke trying to refit it after i welded the housing in to the bulk head but i have found a better quality sealed spherical bearing which is having a new housing made as i am typing this .
#2371
small update i have made templates of the new engine arms , i now got to drill a 41mm hole through 15mm ally plate at a 45degree angle which i think will be a pain in the arse .
i also bought a new ally floor plate made to my dimensions
#2373
i also dropped the 40mm round bar up to a friend who is going to machine it out so i have a 8mm wall thickness ,then its just a case of getting my other mate around to tig weld it all up .
#2377
i got the bar only for Ł122 so less than half price im happy with that
#2378
update time again engine mounts ready for tig welding
engine plates drilled
arms drilled out & profiled
n/s in place
o/s in place
new bulk head sealed spherical bearing welded into bulkhead
new drivers floor plate
my wrc 909 bladed roll bar turned up today as well
n/s in place
o/s in place
#2379
n/s in place
o/s in place
n/s in place
o/s in place
#2384
i got some 19mm bar drilled & threaded for towing eye,s & to mount the spit to
im fitting one each side on the front legs
i phoned Richie up earlier to see if i can use the spit i made for his K A to find out he weighed it in because he did not need it any more
not the end of the world i will just make another one.
#2386
Richie phoned me up to see if i had a cossy clutch aligning tool ,which i did not but i could get one in five minutes so i went to the van got my nine inch grinder out & chopped the bell housing off of a old mt75 gear box so i could get as long a section of shaft as possible .
the bonus bit is i had to do this for the skyline gearbox conversion
#2389
Top work as ever andy really coming along nicely,
Sorry to say but i think ive found some1 who likes using a grinder more than you
http://67-72chevytrucks.com/vboard/s...239896&page=38
page 38 he decideds to turn a 3door in to a 4door using your fav tool a grinder
cheers jay
cheers jay
#2390
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Many thanks again Andy
Although I find it hard to believe its taken us this long to make one the amount of times we swap and change engines/gearboxes
#2393
cheers jay
cheers jay
im glad you like it Jay
looks like he is doing a good job of it but i still think im better at swinging a grinder around he has only cut the rear 1/4 panels in half .i have done nearly the whole car twice .
yes it is curious how we not got one over the years
#2394
i have wanted to do it for a few years now thats why my trans tunnel is so big ,to make sure the skyline box will fit with out cutting it again after it has been painted
its about time you got around here i have only been building it since october 2009 lol.im very happy you like it Paul now you can see why its taking so long to finish it .
#2395
Great work andy
Have you made gearbox mounts into the tunnel to accept the skyline box or will you modify a cossie one when the time comes?
Do you have the skyline box to mock up the tunnel or have you worked off measurments?
#2396
i have not made the gear box x member yet but it will be bolted through the 100mm vertical bit of the tunnel with a load spreading plate which will then be modified to use the same fixing point for the skyline box .i have worked off pictures & measurements to make the tunnel which will be more than big enough to take the skyline box.
