ZAKSPEED ESCORT 4x4 500+HP (328mm rear discs machined rear spoiler profiles here )
Old 30-11-2008, 04:05 PM
  #121
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
BRIGSPORT's Avatar
You missed croft off your list. Will the GREEN machine be there?
Old 30-11-2008, 04:39 PM
  #122
fezzajsy
fezzajsy's Avatar
Old 04-12-2008, 04:29 PM
  #123
andy escos
andy escos's Avatar
hi m8 im not sure if i can afford the petrol to go to croft but who knows ,may be ?.
i am hoping to go on track at coombe though.
Old 07-12-2008, 04:17 PM
  #124
James
James's Avatar
saw this at portreath three years ago, mighty impressive!
Old 12-12-2008, 05:49 PM
  #125
markk
markk's Avatar
Old 26-12-2008, 06:52 PM
  #126
Alan s1
Alan s1's Avatar
WOW thats all I can say
Now im REGRETING SELLING MY THUNDER SALON X PACK
Old 26-12-2008, 07:20 PM
  #127
3i_gaz
3i_gaz's Avatar
that is an awesome thread!! always loved the car, but that thread has made me appreciate the work gone into that car.
awesome mate, good work fella
Old 28-12-2008, 10:15 AM
  #128
kevmk2
kevmk2's Avatar
Wow, you have done some serious work on this
I remember seeing the engine down Joe Stevens a while ago, when i was having my engine built.
I thought i had owned my car for a long time (13 years)
Old 30-12-2008, 09:17 PM
  #129
andy escos
andy escos's Avatar
Default hydraulic clutch conversion
heres how to convert your clutch to hydraulic
the slave cylinder is off a bmw e30 any model all same ,master is a girling 0.625 from demon tweeks.
Old 30-12-2008, 09:51 PM
  #130
Jay,
Sponsor
Jay,'s Avatar
love the clutch convert andy ! i want do the same to shonky , is it really that easy ?
Old 30-12-2008, 10:13 PM
  #131
andy escos
andy escos's Avatar
yes m8 it was quite easy only ball ache was taking box out and strengthening bulk head 4 pedal box but clutch much lighter now well worth the effort
Old 31-12-2008, 06:38 PM
  #132
PAUL_SHEP
PAUL_SHEP's Avatar
AWESOME FELLA, car always looks stunning in the shows, i would go for all green if a colour change is on the cards.
Old 01-01-2009, 05:06 PM
  #133
fezzajsy
fezzajsy's Avatar
Old 04-01-2009, 07:36 PM
  #134
andy escos
andy escos's Avatar
thanks 4 the coments m8 im not doing the body until next year but all green could be on the cards.
Old 10-01-2009, 11:48 AM
  #135
andy escos
andy escos's Avatar
just had my front geometry set up this morning but could not get my castor right tried to set it to mike rainbirds settings but ive ended up with this
toe in 2mm total
camber 2.5. degrees negative
castor 5. degrees
could not get castor due to drive shaft binding with top mount all the way in
so turned top mount to centre line but facing rear wards but then wheels touch arch at back so had to set castor at 5 degrees to centre wheel in arch ,
it feels a lot more stable now but time will tell.
Old 14-01-2009, 12:26 AM
  #136
LINCOLN
LINCOLN's Avatar
Sweet car.
Kawasaki green with anthracite wheels!!
Old 20-01-2009, 08:45 PM
  #137
trevCOSS
trevCOSS's Avatar
looking good Andy, now stop messing about with it and help me fix mine
Old 20-01-2009, 08:47 PM
  #138
purplemonster
RWD PUMA :)
purplemonster's Avatar
nice little clutch convertion ,a little simpler than mine lol
Old 20-01-2009, 09:09 PM
  #139
Jimbo's Cossie
Jimbo's Cossie's Avatar
Very nice mate as always, never forget the time i heard you coming behind me on the way to weston, by the time i looked in my mirror you were in front of me and that wasnt at full power.
huge credit to you mate.
Old 21-01-2009, 06:45 PM
  #140
andy escos
andy escos's Avatar
trev just give us a bell i am your( martini )man any time any place any where pmsl.
Old 21-01-2009, 06:47 PM
  #141
andy escos
andy escos's Avatar
hi jimbo that was with a blown head gasket thanks 4 compliments mate
Old 21-01-2009, 09:14 PM
  #142
andrewg
andrewg's Avatar
the slave cylinder is off a bmw e36 any model all same ,master is a girling 0.625 from demon tweeks.
nice car mate,,, should the bleed nipple not be at the top thou?
Old 22-01-2009, 04:51 PM
  #143
andy escos
andy escos's Avatar
( andrew g )yes mate it &i switched itaround just after i took the picture what a ball ache to bleed the clutch though when its up the right way.
Old 23-01-2009, 05:19 PM
  #144
COLEYST200
COLEYST200's Avatar
Iv just put all this same kit no my 3dr and i never had to tuch the bleed nipple as all i did was was push the slave cilinder back by hand for about 5 min and all the air came dack up on its own
Old 04-03-2009, 07:20 PM
  #145
andy escos
andy escos's Avatar
some pics from when i had my cars 4 wheel alignment session.
Old 05-03-2009, 11:02 AM
  #146
Richie.
aka Turbosailorboy
Richie.'s Avatar
Location: Under the water.... .......in a nuclear submarine
Good old Gupa P
Did the young lad do it Andy ? ? Any surprises ? Time for a rear beam i think
Old 10-03-2009, 10:26 PM
  #147
andrewg
andrewg's Avatar
suppose you only need to do it once but you could put a pipe on nipple side and make it remote
Old 12-04-2009, 02:03 PM
  #148
andy escos
andy escos's Avatar
Originally Posted by Richie.
Good old Gupa P
yes the young lad did do it ,no surprises though & yes i would like a new adjustable rear beam
Old 12-04-2009, 02:40 PM
  #149
graham c
graham c's Avatar
hope mine geo,s ok ha ha, its square with the tape measure ?
Old 19-04-2009, 12:58 PM
  #150
andy escos
andy escos's Avatar
Default new cam trigger conversion
hi all ive been at it again doing more mods this time its cam trigger conversion & thermostatic oil cooler .
took cam shaft out to have it drilled for trigger only to find it was alreadytaped . so that was a waste of time .so i fitted cam back in now i got to pay some one to do my timing . ,so it was on with the oil cooler install ,out with the modine & in with the oil cooler sandwich
i fitted the 16 row oil cooler under the n/s front wing with air being fed from the duct in the front panel
Old 25-04-2009, 11:01 PM
  #151
trevCOSS
trevCOSS's Avatar
hey pikey wheres the aeroquip for the oil cooler, and i'l sort your timing
Old 26-04-2009, 07:10 PM
  #152
andy escos
andy escos's Avatar
ive got 3.5 mtrs of aeroquip in the garage i just need the fittings & thanks for the offer that would be great
Old 05-05-2009, 08:42 PM
  #153
FezzaBoy87
FezzaBoy87's Avatar
keep it green and yellow. im a big fan of the car. looks very serious. very good effort. nice1.
Old 05-05-2009, 08:45 PM
  #154
graham c
graham c's Avatar
am going lemans green andy, wot,s the green on your car called
Old 06-05-2009, 04:24 PM
  #155
andy escos
andy escos's Avatar
hi graham the front is seat yellow & the rear is kawasaki green
Old 06-05-2009, 04:50 PM
  #156
marco polo
marco polo's Avatar
hi andy
what a machine , truely awesome a real credit to you i mean that genuinely
marco
Old 06-05-2009, 04:52 PM
  #157
graham c
graham c's Avatar
that kawasaki green is nearly lemans green as i tryed it up against my bike.
Old 09-05-2009, 09:08 PM
  #158
andy escos
andy escos's Avatar
Originally Posted by marco polo
hi andy
marco
cheers for the comments marco it means a lot coming from you with the cars you had & got thank you
Old 25-05-2009, 12:31 PM
  #159
andy escos
andy escos's Avatar
Default cam trigger fitted
cam cover machined smooth & primed
top coated in vauxhall arden blue pearl &two pack laqour
inlet plenum modified to accomodate twin iscv,sfor anti lag
Size:  58.3 KBin primer with header tank
plenum painted
header painted
just got to fit it all now for cornwall rs show
Old 25-05-2009, 02:13 PM
  #160
jonnyrsturbo
is half man, half amazin'
jonnyrsturbo's Avatar
stunning
Quick Reply: ZAKSPEED ESCORT 4x4 500+HP (328mm rear discs machined rear spoiler profiles here )
