Time Attack ST170 Build - 17/05/11 - More Engine Loom & Dash Stuff
#1085
Ive heard of the stuff your using on your loom it's very flexible and heat/abrasion resistant but cant think of the name for it
Where do you get it from Will?
Cheers David
Cheers David
#1087
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
Depending on how much you need really depends where to buy it from. Some places sell it by the metre, others sell it in reels.
#1088
I'd probably have shrunk and sealed everything only once I knew the loom was tested, everything was definitely the right length, pins properly inserted/locked and so on, makes rework a lot easier.
#1089
Also, i've not yet drilled the hole in the bulkhead so if for whatever reason I have ended up a few mm out, it's easily rectified
#1093
Few quick pics of todays work:
Ident labels arrived for the engine loom:
Power distribution box all fused up:
Fuse and relay box filled:
Then got the dash stuff powered up:
More later hopefully!
#1094
great effort will and iam looking forward to seeing it go , did you know that theres a 60mm and a 70mm diffuser for the jenvey plenum? 70mm was used on a high powered evo engine , they made it about 2 weeks after i ordered mine but said they would swap it which was a bonus
keep up the great work
cheers paul
cheers paul
#1095
Hi Paul,
Yes, the one i'm mocking up my loom on has the 70mm one, ideal really as my throttle body is 68mm!
Anyhoo, did a little more tonight with my mate Spud helping.
Made good use of the ident labels:
Clear sleeved:
Connector terminated:
Et voila:
Same fun and games on crank sensor:
Clear sleeved:
Et voila:
big_Rad
15-09-2017 09:36 AM
kosienutter
31
22-08-2015 09:55 AM
track.focus'd
12-08-2015 05:53 PM
170, fiesta, focus, kit, placement, powerworks, project, rad, rs, st, st170, supercharged, supercharger, superchargers, turbo
