Ford Sierra is-turbo Norwegian style *dynoed*
#41
Virgin-popper
Update. Oilsandwich in. Was a hell to fit. No room under the inlet, and with the thermoblock fitted, the oil filter rubbed the enginemount.
This was yesterday, today I fitted a new oilfilter
What the car looks like now
Hose on boys
I also changed the plugs, looks like I need a bigger fifth injector before the trackday.
Does this look like a "legal" mount ?
Hose on boys
#42
Virgin-popper
Mounted the catchtank today. Also tried the cossie headertank, but the connections was too big.
Found a ok place to fit the tank, just turned the top around to get the connections right
Hoses hoses
KSR got a strange way to "match" parts
Hoses hoses
#43
Virgin-popper
FMCN.no had a trackday at Vĺlerbanen in norway this sunday.
We, a friend and myself, attended with the is-turbo and had a blast.
First time on track, and with the track soaked in water it was quite a challange. Really good fun all day, and with the new section making the track 3.3km long, everyone seemed to have their hands full.
About half way thru the vid the passangerseat broke, and my mate almost sat in the backseat
End result: Broken headgasket and wobble-brakes. Everything else held up nicely.
Camera didn't have a "backlight" setting, so you can't really see the track in the first heat.
http://www.megavideo.com/?v=J0NRAH4P
#44
I have been thinking what ECU I should use when I'm getting a turbo to my own OHC. I read that you are using original EEC-IV with extra injectors and that's one way I have been considering, because there is good ECUs for controlling extra injectors available with pretty low prize too. But I have been reading some people having problems with the ignition timing when they are using turbo and Ford's EEC-IV, what is causing "knocking" in the engine.
Is your ignition timing as like it is from factory, or have you done some tweaking to it, to get it adjusted?
#45
Virgin-popper
#46
Ok. I have been reading some Finnish Ford Forums and they say that there is some "octane adjust" system in iS Sierras, where there is three different wires and grounding them delays the ignition with 2, 4 or 6 degrees. That's maybe something what I'm looking for. The problem with Ford's EEC-IV is that you can't really manually adjust the base timing of ignition from the distributor itself, ECU always "corrects" the timing to the values it is configured for.
OR... I may also go to Megasquirt.
#48
Virgin-popper
After Vĺlerbanen we had to change the headgasket. Here's some pictures
Kitty helps me sooo much
Head's out
Gooooone
The headgasket didn't have any visual damages, I don't like
New Gr.a gasket on. Didn't take a pic after we fitted the head, but it's on
More to come tomorrow
Head's out
Gooooone
#50
Virgin-popper
Well.. If you need a laugh, this is the thread and the day.
Almost done with the head gasket-swap, a mate was about to mount the waterhose under the inletmanifold. And there we found a faulty hose.. just where all the water was fizzing out when it cooked.. when all the water dissapeared... when we thought the head gasket was fu***d..
You'll get the hint, MOST likely not head gasket.. just a waterhose.. Great At least I now got a Gr.a gasket
#51
Virgin-popper
Dooooone. Tried to fire it up yesterday but the sparkplugs, as you with memory might recall, don't like to stay un-used for weeks like it's been now.
Rushed to work where I used to have a spare-pair(rhyme :P), but my boss had sent them back
I got some original apr6fs, but don't want to start the car just for the starting.. I'm certain that I would've been too tempted to drive it.
So, first thing monday I'm getting a ten-pack ap8fs from work, and will be starting the damn thing up
#52
Virgin-popper
Yet again, the car is foooked.
After changing about everything, sure felt like it, I finally got it started this morning.
Noticed it didn't pull as it should, but it has always been a bit the first 5min.
After work I drove to a mate of mine, just a few miles.
Car got no power, just jumps like a fuelcut and won't pick up speed. When the turbo finally comes it sounds different, like escaping boost. But haven't checked it with startgas yet.
When I got home, drove took about 5mins or so, it smells like burnt oil. So I popped the hood...
Bright red manifold, exhaust turbine and the first 10cm downpipe.. God damn it was soo hot. Oilsmoke for five mins after it turned back to it's original colour :S
Also got pops and bangs while enginebreaking. See movie. I'm thinking timing, but could it bee so easy ?
(sorry for the bad english. Hope you understand)
#53
Virgin-popper
Soo.. The car been dynoed, and I've been surpriced.
Car pulled 218.5hp @ 4962rpm and 363.9nm @ 3267rpm.
http://www.youtube.com/watch?v=fERSKAW6xT4
#58
Virgin-popper
Did some detailing on my new sierra today. Just some light handpolishing with Autoglyms Paint Renovator and Super Resin Polish
hello
Before
Side
Headlights got a makeover
reflections
reflections
Paint's as smooth as ice
hello
Before
Side
reflections
reflections
#61
Virgin-popper
Well, think we'll stop the thread here with a sad-looking picture
I want to thank everyone who participated and helped throughout this thread, and welcome you all to the new project-thread which I will post later.
Thanks again,
Anders Kverneng
Thanks again,
Anders Kverneng
#63
Soo... What's happening with this?
What's sad? I just see a lot snow, my car also looks like that sometimes. But doesn't it just mean that clean the snow off and get driving.
What's the plan? It's sad if a good car goes to waste.
#64
Virgin-popper
The car itself got a bit of rust, and generally somewhat over the top of it's lifespan, so I will dismiss it for a saph body I get cheap from a mate.
So, all the parts will get refurbed and painted, and boltet on to the saph. New manifold is ordered, inlet is being made and additional intercooler etc. will come in a few months.
I would've driven it, but the lack of proper wintertires gives me no option. And that might not be a bad thing remembering it got a welded diff
#67
Virgin-popper
Totally agreeing with you, my former saph cos. felt so much firmer and ridgit(sp)
And, cosworth rear interior fits without any mods
Jack and the Beanstalk
15-08-2015 04:27 PM
09-08-2015 07:03 PM
