First Project, Escort 1300, Finished! 6/10
#41
Was rebuilding the head today and ive lost a collet, looked everywhere and still cant find it.
Does anyone know where i could one for a HCS engine without going to ford. Thanks!
#47
#48
Shizzle My Nizzle
at least its a ford and not some other make!
#52
#55
Team HOTHOT!
you would use a zetec mount , or a cvh one and mod it , sooo easy got one here , something like a 1.6 1.8 or even 2.0 ltr nothing really hard about it i swapped my enigne over today took me about 3 hrs but then iv done it loadds of times
the wiring loom goes in with 7 wires so you just need to add them and plug and play
#56
Well the engine is all back together now. Got alot done today in the hail and rain, with some help from rostill2007.
Hoping to have it running tonight, just waiting for the battery to charge .
Pictures!!!
New valve stem seals
all valves in
Almost there
And its finished
Also cleaned up the gearbox.
Let me know what you think!
Pictures!!!
all valves in
Almost there
And its finished
#60
Tried to start it again, it turned over but wouldnt fire up. i can hear a hissing noise when its about to go.
anyone got any ideas? Also has anyone got a pic of all the inlet maifold all wired up on a HCS engine, im unsure about one hose and where it goes.
Thanks!
Thanks!
#63
Well i finally got it running, One HT lead was on the wrong plug lol.
Anyway It seems to be running rough atm. is that due to it been standing for so long or?
Also its noisey but the valve clearance is corret.
Anyone got the spark plug gap for a 1.3 HCS engine, some reason the hynes manual doesnt tell you it.
Thanks
Thanks
#64
Shizzle My Nizzle
Thanks
Thanks
spark gap is 1.3mm
#69
Well we redone the valve clearance today after rushing it before lol. there was BIG clearance due to not roatating the crank after each pair of valves anyway all sorted now and running sweet .
Will be lowering it this week
#74
Got the lowering springs today, off someone from here (Lee Ivatt)
Here some shot of it before it was lowered
Got the back springs done then the weather took a turn for the worse
Will post more pics as soon as i can
also started painting the under side, will get pics of that too.
#75
We finished fitting the springs today. Its now 60mm lower
Also started underneath
Before
After
Needs a few more coats and its done.
Comments?
Before
After
Comments?
#76
Shizzle My Nizzle
looks good mate. have you rolled it back and foward a few times as it doesnt look like its settled yet?
you should be able to fit 17"s no prob if u want, as i did when they were on mine.
#77
nah we neva rolled it when we fitted them we will soon tho we thought they jus settle wen it was driven
#78
Shizzle My Nizzle
if u roll it back and forth a few feet the car will sit a true -60mm. looks like its 45-50 at mo. happens cos when you jack the car the suspension swings down then when u drop the car of the jack the wheel will have a positive camber (lean out at top a little) untill the tyres are rolled and the geometry is realigned.
will look great with some nice alloys, i must dig out the pic of mine to give u some more enthuasium
#79
haha
Will get some alloys as soon as funds allow
