Tim Garringtons WRC V8, Engines back in and bulk heads nearly completed! 03/05/11
#123
Lucifer II - 666
You can't tell how big that V8 is in the pics so I got the wife to sit on it ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
![](http://i139.photobucket.com/albums/q311/minirotty1/26092010710.jpg)
She thinks it's pretty
#125
Lucifer II - 666
Na, Tim made them, makes a cracking cuppa tea our Tim
#128
Im hopein it will be around 500/600 rwhp but will have to wait and see what this supercharger can cope with, Ive already seen the next supercharger i would like then 800+ bhp but that my be to much for the road will have to decide when on the road,can change boost by changin crank drive pulley got a few but need to get couple more the will have full range so can swap and change as needed.
#130
Lucifer II - 666
MORE
bonnet shut
![](http://i1002.photobucket.com/albums/af148/timbhp/gokart/005-1.jpg)
bonnet open
![](http://i1002.photobucket.com/albums/af148/timbhp/018-3.jpg)
![](http://i1002.photobucket.com/albums/af148/timbhp/019-4.jpg)
![](http://i1002.photobucket.com/albums/af148/timbhp/025-4.jpg)
it fits
Originally Posted by timbhp
![](https://passionford.com/forum/images/smilies/smile071.gif)
bonnet open
it fits
#133
Lucifer II - 666
They came like that from Ford Racing, looks like a crackle blue powder coating.
#139
Lucifer II - 666
Lucifer II - 666
Lucifer II - 666
OK
#144
Hi all not much progress with the car lately so hopefully over the Xmas hols will get some more done ,
have decided to re cut bulkhead and move engine back further to give better weight distribution plus this will allow more room for charge cooler rad and few more bits
#146
Lucifer II - 666
Think he means the one you've fitted mate not the one you're selling.
#151
Lucifer II - 666
Lucifer II - 666
It's being built for the road and track mate. Tim is also very experianced with RWD Escort V8's so to him uping the power to this is only natural lol
He will be able to adjust the BHP by swaping s/c pullies and then use the power where and when it is ever needed.
His diff has been made so he could hit the 200MPH if he so wished.
#155
thats insane, i bet a build like this cost a fair bit :O
top job mate. the v8 looks right a home.
to think that i have people telling me my escor at 250bhp will be a hand full HA
#156
Lucifer II - 666
info...
Hi all been working on car but not wanted to put up any posts up as have been trying to get log book changed at dvla to change engine size and number, but dvla wanted a report and a lot of other info about what engine,size ,fuel ,what manufacturer,were did it come from,and so on.
But now log book back with correct details so all is ok,
so will be updating thread with lots of pics soon
spent some time thinking things through and talking to my people about the prop shaft, and came to a big decision to cut out bulkhead again and move engine a lot further back to shorten prop and make it more balanced on the handling front
thats it for now pics up soon
#158
Lucifer II - 666
Ok a few pics to bring things back up to date
this was how the bulkhead was to get things to fit,but thought long and hard about weight distribution,and talked to the company who are making my prop and they thought i could stand a chance of twisting the prop with some hard launches,
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011012.jpg)
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011018.jpg)
so got the old plasma cutter out to remove some of the bulkhead
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011019.jpg)
then a bit more
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011021.jpg)
before trying engine and box back in i needed to get rid of clutch cable and fork, so got a tilton hydraulic conversion kit
made up bracket to stop it rotating and shortened nose on box and turned down threaded sleeve , after making measurements to allow the correct clearance for cover and bearing
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011025.jpg)
this is how much i cut of nose
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011029.jpg)
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011027.jpg)
all fitted with hoses connected very nice and compact conversion
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011030.jpg)
thats it for now will put some more pics up soon
then a bit more
And...
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011039.jpg)
pic from front you can see front of engine now in line with struts
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011043.jpg)
in this pic you can see steering is close to alt which is a small 55amp Mitsubishi unit visited local auto electricians and searched his shelves to get the right size and mountings
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011042.jpg)
then needed to find some mount's for engine so found some e type jag mount's one on left std on right uprated comp one
so will use 2 for engine and one for gear box mtg
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011044.jpg)
making gear box mtg practising with tig welder
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011049.jpg)
after fitting engine found i needed to take a small amount of the big wing sump to allow manifolds and collectors to fit between sump and chassis
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011050.jpg)
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011051.jpg)
new plates made and tig welded back in place
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011053.jpg)
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011054.jpg)
after welding up filled up with cleaning fluid to check for any leaks and all was fine so washed out and put baffels
back in
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011055.jpg)
then painted ready for re-fitting
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011057.jpg)
and while the engine was on mts measured up for prop gave dimensions to local company along with mustang
front yoke section, next day had a call to say it was done and balanced
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011047.jpg)
![](https://i1081.photobucket.com/albums/j360/TimsescortV8/escort%20build/29march2011048.jpg)
