belgian xr2i (RS1800 uk)2.0l zetec (13/03/12)megasquirt
Old 23-09-2010, 09:44 PM
  #121
dj_yd
dj_yd's Avatar
than i started the prep for the 2.0 transplant
from this
to this :P
i removed the surface rust, also the jack mount
etchprimer and seamsealer
and final primer
more to come
greets
Old 26-09-2010, 09:03 PM
  #122
dj_yd
dj_yd's Avatar
i painted the front pannel in imperial bleu again
next thing to do is prepping the engine bay for paint
Old 30-09-2010, 09:47 PM
  #123
dj_yd
dj_yd's Avatar
i'v been cleaning and painting things this week
brakelines
the PAS steeringhouse
the brake servo
the shifter
the alternator
and the starter
Old 30-09-2010, 10:07 PM
  #124
andy130
andy130's Avatar
good work mate
Old 14-10-2010, 09:38 PM
  #125
dj_yd
dj_yd's Avatar
Originally Posted by andy130
good work mate
thank you
Old 14-10-2010, 09:39 PM
  #126
dj_yd
dj_yd's Avatar
i'v been doing a lot on the fiesta
i cleaned the inside of the cooling fluid bottle
i think it looks a lot better
before
after
then i cleaned the rust of the mounts from the headlights and painted them
befor
after
and this weekend i spray painted the enginebay , i chose ford frozen white, it looks good with the imperial bue
i realy like it
some heatshield against the firewall
than i started rebuilding things
the PAS steering rack ,cooler and pipes, the brakeservo and brakepipes, the wiper motor,the blower fan,feulfilter, and a part of the loom
i hope to drop the 2.0l in over the weekend
i like it , hope you guy's do to
gReetS
Old 16-10-2010, 09:04 PM
  #127
andy130
andy130's Avatar
looks good mate, take it your a spray painter?
Old 17-10-2010, 08:38 PM
  #128
dj_yd
dj_yd's Avatar
thanks mate
no i'm not , just something i learned thru the years, first i wasn't that good, now i amaze myself how the finishe looks like :d
i don't like to pay people for things i can do myself lol
Old 17-10-2010, 08:48 PM
  #129
dj_yd
dj_yd's Avatar
this week i prepaired the enginebay for the 2.0 zetec to go in
and i modified the plate that sits between the engine and the gearbox, because of the starter location in the mondeo at the rear
the original plate and the little peace that needs welding on the plate
welded and painted
than i could connect the gearbox and the engine(i'm using a old camcover for the instalation)
on it's way to his new home
and the engine is in , but no pictures of it yet
Old 20-10-2010, 07:09 PM
  #130
dj_yd
dj_yd's Avatar
i derusted my GAZ coilovers, and sprayed them, they are only 1 year old, but they where verry rusted , i blame it al on the roadsalt in the past cold winter
and i pollished the front struttops, i'm not sure i'll keep it this way , but it will do for now
hopefully i can start the 2.0l this weekend
Old 02-11-2010, 05:26 PM
  #131
dj_yd
dj_yd's Avatar
last week i'v been bussy
the front susspension back in GAZ shocks and fiesta st brakes
and the 2.0l in :twisted:
i cleaned the front angine mount and painted it
and al build up
i need to clean it , i see dust in the pics
than came the big moment :mrgreen:
first remove the fuse from te feulpump and the sparkplugs, and crank it over a few times
sparkplugs and feulpumpfuse back in
ok here we go
i turn the key and .... hu hu hu hu..... hu hu hu hu
like i was thinking a flat battery
got my parents focus and conected the jumperleads and tried again
it started the first time :twisted:
and than switched it of again, i'm running piper cams and i have to run them in at +- 2500rpm for 20min, i couldn't do this as i had a cooling fluid leak
the next day i fixt the leak and charged the battery and started it again
20min at 2500 for the cams to bed in
than switched it of again and let it cooldown for a night
next day i started it again , to see what the idle whould do
it staled emediatly
the reason was that i dismantled the throtlebody and i had tho adjust the butterfly a bit , now it idle's at 1000rpm and 900rpm
i'v done the first miles and it runs verry wel , i'v not driven it hard just taking it easy and run it in for a few 1000miles
i'm happy that it does what its supposed to do knowing i did it al by myself and i'm just a elektrician and never had a mecaniks training.
i'm verry pleased
gReetS
Old 17-11-2010, 11:56 AM
  #132
Mk3 fezza More Door
Mk3 fezza More Door's Avatar
just out of intrest are the rear spacers made for the mk3??
Old 03-04-2011, 07:21 PM
  #133
dj_yd
dj_yd's Avatar
no , there for a puma , fiesta mk4, mk5 and focus mk1
Old 03-04-2011, 07:22 PM
  #134
dj_yd
dj_yd's Avatar
a few weeks back i was doing the last running in miles on the 2.0 and than this happend
the back end lost traction and afte a few times trying to correct it i whent in the ditch :x
i had no injuries thats the good thing , but the fiesta is something else
this is how it looked like
the place off impact
the next day when i was over the first shock i started stripping it
the front suspention is al fine , also is the engine , maybe the left rear wheel is bent on the axel, i have to check later, the chassis is ok , only the body has a few big dents
Old 03-04-2011, 07:23 PM
  #135
dj_yd
dj_yd's Avatar
i took the gearbox and engine out again
and i modyfied the radiator support so the st170 manifold has a little more room
the new support
before
after
Old 03-04-2011, 07:24 PM
  #136
dj_yd
dj_yd's Avatar
the new support in
a new front pannel
and a new wing
the front back as it should be
Old 03-04-2011, 07:25 PM
  #137
dj_yd
dj_yd's Avatar
and the last thing i did was removing the left rear, next is building it back up
test fit
greetz
Old 03-04-2011, 08:00 PM
  #138
xr2imetalhead
xr2imetalhead's Avatar
really impressed with your progress top marks. shame about the accident though you must have been gutted but well done for hanging in there and sorting out the damage !!!!
Old 27-04-2011, 09:16 PM
  #139
dj_yd
dj_yd's Avatar
i will post the last updates on the fiesta
i got the inner wheelarch at the rear back in shape and i welded a new peace on the outside
and than welded a new Quarter panel on
all nice gaps
and because i couldn't find a quarter panel from a mk3,5 i had to chop it and weld a new peace in for the filler flap from a mk3,5
the correct peace for a mk3,5 fillerflap
where it should be
and the mk3,5 fillerflap in place
that's it for now
greetz
Old 09-05-2011, 08:31 PM
  #140
dj_yd
dj_yd's Avatar
the body is primed, just sand it wet and than some imperial blue
greets
Old 05-06-2011, 08:50 PM
  #141
dj_yd
dj_yd's Avatar
the last days i'v been bussy
i preped it all ready for paint
i made myself a "paintbooth" with some plastic and 2 filters , 1 drawing air out , the other one blowing fresh air in
in the back you see a clean filter
and then soe paint and clear
the strange lines you see is the plastic reflecting
and the filter did his job
the wheelarches from the bodykit
the boothlid
and the enginebay back in frozen white
there is a little bit of dust here and there , all in the clearcoat, so i can pollish it out
the bumpers , spoiler and the middle section from the bodykit are next
grtz
Old 22-06-2011, 05:05 PM
  #142
dj_yd
dj_yd's Avatar
i now have everything painted , only the sideskirt from the kit to go.
the spoiler had some cracks in the paint, so some new paint
there was a crack in the rear bumper, at the hole where the toweye sits, i did some plasticwelding and its all good now
the front bumper is "total loss" , a new one in place
the filler hole cover painted
the rear build back up
and this weekend i got the engine back in and running nice
a new rad
a nice engine bay
a few things to do, i have to source e new rear axle and some small details to go
Old 17-07-2011, 05:40 PM
  #143
dj_yd
dj_yd's Avatar
i got a new rear axle on and a new wheelhub and the wheel is going in the correct direction
she's back on the road now
from this a few months back
to this now
it needs a good clean and pollish but i'm happy with it
grtz
Old 17-07-2011, 06:18 PM
  #144
Fantastic turnaround job there
Old 19-07-2011, 02:59 PM
  #145
dj_yd
dj_yd's Avatar
thanks mate
Old 21-07-2011, 07:29 AM
  #146
rinus_2005
rinus_2005's Avatar
Glad you got it repaired, looks good man!
Old 13-03-2012, 10:23 PM
  #147
dj_yd
dj_yd's Avatar
it has been a long time that i updated this topic
so here we go
i orderd a megasquirt kit in the usa and started building it, I also made a ford EECIV to megasquirt adaptor so that i didn't need to cut the original loom and make the megasquirt plug and play.
this is the circuitboard that i made(ignore the EECV on the board)
drilled the holes
i ripped a old EECIV in peaces for the EECIV 60pin connector and mounted it to the circuitboard that i made
it fits in the ford ecu case
the megasquirt loom to the adapterboard
ready
Old 13-03-2012, 10:24 PM
  #148
dj_yd
dj_yd's Avatar
the megasquirt ecu i build
2 coil drivers for ford wasted spark coil
36-1 triggerwheel with VR sensor at the stock place
ford mondeo 225cc injectors
stock tempsensors for coolant and manifold air
modified circuit for stock ford idlevalve
MAP sensor on the ecu
extra driver circuit to drive the tach from the ecu
the megasquirt 2
the botem , the map sensor in the left corner
fully build
mk3ste
17-10-2021 10:09 AM
arkeye
Ford Focus ST
20-02-2016 01:22 PM
SMILER258
28-09-2015 09:04 AM
mondeomark
28-09-2015 06:28 AM
Andypandy260
23-09-2015 10:28 PM
Quick Reply: belgian xr2i (RS1800 uk)2.0l zetec (13/03/12)megasquirt
