F2 Maxi Build Lucifer II - RL7's and a BIG Turbo!
#642
Lucifer II - 666
That's not even half the engines Roy bud lol
#644
Lucifer II - 666
Cheers Tony bud, the paint isn't perfect bud, a few thin places on it that don't show in the pictures.
If it was finished I would get it blown over but I am going to leave it for now.
Maybe give you a shout to look at it when time is right?
#646
Lucifer II - 666
Thanks Tony.
#648
Lucifer II - 666
Finished that mate and got my reward
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
#649
Lucifer II - 666
Started my engine build this week as thought I need to do something constructive towards this car lol
Had my block back last week after sump mismatch piece being made and also had the block sent for reboring to correct bore to suit new pistons.
Currently sat in my utility room at home lol the wifes not not to sure whether me selling the house next year for a move to one with a guarage is going to be a good idea lol
Bored block
![Name: 130320111105.jpg
Size: 50.3 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107031d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-130320111105.jpg)
Checking piston clearances
![Name: 130320111113.jpg
Size: 27.8 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107032d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-130320111113.jpg)
Deciding whether to use IKE or ARROW rods as both have perfect clearances but I think I'll go with IKE just because they're nice and new lol
![Name: 130320111116.jpg
Size: 44.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107033d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-130320111116.jpg)
![Name: 130320111117.jpg
Size: 53.9 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107034d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-130320111117.jpg)
![Name: 130320111121.jpg
Size: 23.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107035d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-130320111121.jpg)
I did recieve my head last week as been completed, massive ports good flow bench readings and larger valves plus solid lifters, couple of things I wernt happy with though so it went back.
Will get pic's up of it as soon as it comes back to me again.
Will plod on atm though, need to dip the block to clean and then I'll start the build up.
Bored block
#651
Lucifer II - 666
Cheers Beef
![](https://passionford.com/forum/images/smilies/roi.gif)
#653
Lucifer II - 666
Is that a pic up line Tony? ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Had another set of earocatches arrive as first set wernt locable but decided to keep both sets so can fir one set to bonnet and one to boot locking both.
![Name: 180320111141.jpg
Size: 103.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107036d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-180320111141.jpg)
Bit of a set back on cylinder head, sent it back for fault I wasn't happy with it and it's not fixable. Another head is boxed up ready to post off to ALD to be reworked.
#654
![](http://i261.photobucket.com/albums/ii74/Minirotty2/180320111141.jpg)
#655
Lucifer II - 666
Ebay mate, loads on there, paid Ł40 a pair.
#656
Lucifer II - 666
Block all clean and painted...
![Name: 210320111155.jpg
Size: 70.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107037d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-210320111155.jpg)
![Name: 210320111154.jpg
Size: 53.8 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107038d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-210320111154.jpg)
![Name: 210320111148.jpg
Size: 51.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107039d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-210320111148.jpg)
![Name: 210320111153.jpg
Size: 47.3 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107040d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-210320111153.jpg)
#658
Lucifer II - 666
Thanks Ross, long time no speak mate. You back in the country yet?
Pulled me ALD L&B KNife edge crank out of storage and it is due fresh oil on it any way and sat it in the clean block.
Don't know if this is the one being fitted yet as I am contemplating putting it in Sams escort maxi engine and using steel crank I have in this!
![Name: 220320111160.jpg
Size: 65.8 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107041d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-220320111160.jpg)
![Name: 220320111162.jpg
Size: 74.6 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107042d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-220320111162.jpg)
![Name: 220320111165.jpg
Size: 79.2 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107043d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-220320111165.jpg)
It's a good looking crank and goes well wih the ALD Lightened and balanced fly wheel.
You can see the modifed block in last pic for the 2L sump to fit.
Either way which ever is used is going to be all balanced together with fly and pully next month as I want to double check all parts.
#661
Lucifer II - 666
Lucifer II - 666
Lucifer II - 666
Home now!!!
![Name: 170420111196.jpg
Size: 76.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107044d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-170420111196.jpg)
![Name: 170420111197.jpg
Size: 74.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107045d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-170420111197.jpg)
![Name: 170420111200.jpg
Size: 67.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107046d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-170420111200.jpg)
Another customers 2.3 lurking in the corner
![Name: 170420111203.jpg
Size: 86.6 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107047d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-170420111203.jpg)
My 2.2 at the rear
![Name: 170420111204.jpg
Size: 73.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107048d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-170420111204.jpg)
So chuffed I have some where nice again!!! even better than befor too as now have concrete floors.
Working on a couple of 2.3 for customers atm though so wont be doing much to L2 atm but hopefully soon will have updates!
Been tidying up my RS2000 spares catalogue also lol
![Name: 100420111192.jpg
Size: 128.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107049d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-100420111192.jpg)
![Name: 100420111191.jpg
Size: 101.3 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107050d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-100420111191.jpg)
My 2.2 at the rear
![Name: 100420111190.jpg
Size: 116.9 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107051d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-100420111190.jpg)
#665
Lucifer II - 666
Bit of a pathetic update tbh but thought I'd update thread any way lol
I went to lock up yesterday to drop some things off and decided whilst there to grab dremmel and cut me bonnet up lol
Fitted one of my bonnet AeroCatches and went back today to fit the second one too.
![Name: 241683_10150219992098116_552038115_7144958_5086593_o.jpg
Size: 33.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107052d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-241683_10150219992098116_552038115_7144958_5086593_o.jpg)
![Name: 242897_10150220014058116_552038115_7145141_5568463_o.jpg
Size: 53.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107053d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-242897_10150220014058116_552038115_7145141_5568463_o.jpg)
![Name: 256658_10150220856338116_552038115_7154570_4060913_o1.jpg
Size: 35.8 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107054d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-256658_10150220856338116_552038115_7154570_4060913_o1.jpg)
![Name: 259078_10150220855983116_552038115_7154564_4477073_o.jpg
Size: 43.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107055d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-259078_10150220855983116_552038115_7154564_4477073_o.jpg)
I really like them and think they add to the agressive look.
I have still been working on parts for the car! new throttle bodies should be ordered in next few weeks as ones I want arent a shelf item.
New inlets have been cnc'd for mine and two other engine I am building for to other forged RS's.
My new cylinder head is finished and ready for collection just not been able to get to get it yet.
New dry sump will be progressed with soon also when I get around to posting parts off lol
Will try do more soon!
#667
Lucifer II - 666
Thanks mate, after posting update here yesterday I spotted something else for sale and had to buy it lol will get pics asap.
#668
Lucifer II - 666
I wasnt happy at the way the aerocatches bolted into the out bonnet skin so I looked into having some plates made for backing then a kind lad on passionford pointed out that they are being sold through demontweaks lol so ordered some!
![Name: 2011-06-14170202.jpg
Size: 61.9 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107056d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-2011-06-14170202.jpg)
Then Ben aka Mcflycossie was refufbing his Brembo's and had some spare stickers he was willing to send to me so I fitted them to my new Brembo's, look mint!!!
![Name: 2011-06-16203934.jpg
Size: 63.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107057d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-2011-06-16203934.jpg)
Now the bit I am chuffed about... managed to get myself this ATL 15 Gallen Fuel Tank with full length braided lines, pump amd filter all with aeroquip fittings and will plumb strate into mine as it was removed from a sadly broken Escort Maxi F2.
![Name: 2011-06-17163302.jpg
Size: 88.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107058d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-2011-06-17163302.jpg)
Will be refurbing the tank before it's bolted into mine though!
More soon
More soon
#669
Lucifer II - 666
Heres a better picture of it in the car, had a chat to me mate Tim today deciding how best to mount it and going to shim off the eccess edges and mount on custom made 2" U aluminium plates.
![Name: 2011-06-18111405.jpg
Size: 88.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107059d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-2011-06-18111405.jpg)
![Name: 2011-06-18112011.jpg
Size: 86.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107060d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-2011-06-18112011.jpg)
I think silver or grey like has been said will be best colour to go for.
#672
Lucifer II - 666
Cheers lads
#673
Fleet Manager
#674
Lucifer II - 666
Surprised your ears didn't bleed marky lol
#676
Lucifer II - 666
Cheers Beef, don't know what colour to do the tank?
Red - as it is?
Silvery/grey?
Black/wrinkle?
Red - as it is?
Silvery/grey?
Black/wrinkle?
#678
Lucifer II - 666
I knew you'd chose that option
#679
Lucifer II - 666
I thought fuck it and decided to get these for myself as I just want the bugger running, was going for different spec t/b's but once running I can change!
48mm Jenvies, still having a new inlet CNC'd up for um as it will be usable on the later spec ones I get.
![Name: 2011-07-07225847.jpg
Size: 97.9 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/107061d1501884623-f2-maxi-build-lucifer-ii-rl7-s-and-a-big-turbo-2011-07-07225847.jpg)
Just have to get myself some compatable injectors now too.
