F2 Maxi Build Lucifer II - RL7's and a BIG Turbo!
#1002
#1003
#1008
Been stripping the donor mk6 today, also finished refurbing my bottom arms...
Also bolted up my rear beam -
Hard to take pics of beam from undernieth lol
#1014
Love the flange pmsl
Cheers Jay mate.
been back pu unit today and finished stripping bits I needed from 3dr.
tea brake (pun) lol
Had a good look at 3dr, pretty sold!
n/s side iner footwell has surface rust, needs battery tray and 3 inch weld plate on n/s rear chasis leg.
Other than that its solid so defo a keeper!
just surface rust you can see.
Possible furutre for the old girl? LOL
Removed every last wire from the 3dr today, will start stripping back whats needed soon for L2.
me mate Tony whos a dab hand with wiring has offered to give me a hand as I fancy having a rally style fuse board also.
Also refurbed steering rack today, will get those pics in a bit.
Thanks.
Cheers Jay mate.
tea brake (pun) lol
Thanks.
#1018
A flange butcher? I'll take a pound of fresh flange then please mate
Cheers Matt.
Quick rack refurbed now too with rose jointed TRE's.
#1019
Kev ,Not sure if you know as I didnt, if you have the same rack as mine the spline is different to the standard escort coupling. I bought a WRC coupling from dewits and fabricated/modified my column to suit (before I gof a full works column).
I discovered this last minute lol, hopefully it helps
#1020
Not noticed it was different?
I still have the collum that came out of the original GrpA shell and it was rolloing/steering when I got it, so I'll take a look if that collum is different.
Got a couple of quick raks up unit, I'll have a look at them too, to make sure now you've said.
#1021
#1024
Enjoying working on it again mate, doubt ill get it finished this year but itll only be a couple of things holding me off, the main thing is this year I plan to have it looking like a car lol
Get all misc done like brakes, loom, fueling, lights etc
Two choices on mapping - Harvey for dyno and Reyland for r/r.
Tempted now to go Martin as he is only down road and means i can get engine in, plumb sump in also.
I got the van to play with in summer to keep me occupied lol
#1025
glued on the complicated curved flange.
had to slice the sign board at EVERY box section on one side so it would curve without it being under strain and trying to straigten out.
#1031
Bit pissed off now, after the trip to Kent Cam to have cams spec'd up, I just folded the paper up they gave and put it in the cam boxes, didn't read it untill now.
Gave head to a pal to set my valve clearances up as I haven't the patiants to do it tbh, he rang me today saying Kent haven't provided valve clearances, just the lift and duration etc
Mountune wont share info Matman has offered to look into it for me see if he can help, but now I just feel like binning all the Maxi cams and buying new, but also can't be arsed as it's more expense just because I can't get spec's.
Fed up.
Fed up.
#1033
Not a clue mate, I rang Mountune couple years back and couldn't get any info off um.
Matmans shared his clearances with me, fair play to him for it. But not a clue if all Mountune cams used in the 2K's would use same clearances.
#1035
Few more bits of the jigsaw done! I may not get time to go to unit this weekend though but when I do go next the she will be back on all 4 wheels!!!
Hubs all refurbed -
VibraTech mounts all in for gear box -
Also Jay finished flocking my dash insert for the RaceTech2 digi dash -
Will update if I do get to work on her this weekend.
Hubs all refurbed -
