mk3 escort zetec turbo, poss breaking, 23/10/11 gauging interest
#205
sorry i havnt posted up lately, should post up some good updates 2moro, head is now built up with area six uprated valve springs, bottom end is built with a ap 4 paddle clutch and a temporay s1 lsd box, collected my area six profiled newman cam last night which i will dial in in the morning before fitting the engine. ive had a few delays, brake reservoir was leaking so couldnt get brake pressure, ive got new seals which i will fit in the morning (fingers crossed it will be ok and engine can commence).
#206
well, i finally got cams dialled in and the engine in with the new vibratecnic mounts.
Heres a few pics of car and some of engine in :
(excuse the dirt lol)
#216
Originally Posted by Red16
cool
it'd look ace i reckon with the rest of the car stickered up to match the bonnet and wheels painted black
#217
i hadnt put any pics or anything up in a while so i thought i'd showeyou guys a few to see how its progressing
how the engine stands now
modified rover turbo inlet with cosworththrottle body also modified using transit throttle cable
turbo near rad
grs with fans
slowly but surely progressing
turbo near rad
grs with fans
#224
not too much really, just need to sort a few fiddley things, i had a hb960 alternator belt which is a nats cock too longs so have to try a hb450 now lol.
ive also changed plans on my management to emerald k3, so looking to have air injectors, 3 maps, boost controller, full throttle shift, launch control etc too , just need to make up loom for it
#226
cant wait to have it running, i was just reading a thread from garage 19 about running in, its got me thinking how this works when having new engine with cam etc?
#228
should hopefully be in the garage 2mo if the other cars sprayed and out 2nite, and all my bits should be here by friday (hopefully) come round and help if you want dan lmao, il let you have a passenger ride to central weekender in it lol
#232
i got vibratechnics and brand new engine mount, the only movement looks as though its in the tyres when i try rocking the engine lol, is really close though and your right, a brace will need to be made, looking though car wont be out till the weekend now , i need that garage lol
#236
just squeezed the car in the garage for work to commence 2moro and i must say it was hard work getting it in and didnt help the rear brakes are sticking
#239
me pedal box arrived today, many thanks to Nuts R'uS (TONY) for his great help and service, going to start fitting it shortly , last night got a little bit done, most of engine bays new loom made in braid, just needs plugs fitting, boost pipes made up and fitted. had problem getting drive shafts in properly, but think thats due to the adjustable tca's at the wrong legnth
#240
engine looks sweet. it looks light a tight squeeze to get a boost pipe on the T/B in the pics. my rover inlet had more chopped off and it was still a tight squeeze.
