mk3 escort zetec turbo, poss breaking, 23/10/11 gauging interest
#723
it actually soulds cool, i loved it till police heard it and wanted me straight away, thankfully my alley couldnt have come soon enought and they couldnt fit lol . It was the short ratio that annoyed me tbh. btw i dropped it to jano yesterday
#725
Wye Valley Hardcore
Top man I'll ring him tomoz and see how much work it needs.
#726
he was saying the box had taken the hit as the starter parts of the casing had been welded , but box done around 1500 miles in my car and only prob was a bearing which i believe to be the layshaft. i loved the noise yet hated the ratios lol.
#734
A bank robbery lol. At some point I should be picking up a new uprated cossie pump, cage and rear coily's, just gota arrange the picking up lol. I'm def feeling my holiday to zante more tbh though lol
#738
i rarely suffer hangovers tbh, i had one the other week but that was from mixing shots in a pint glass lol, i tend to just wake up drunk still lol
#739
The 6 speed won't be nicer on the Mway - that's why i avoided it - have u checked the ratios? 6th gear is lower geared than the RST 5th...
Rick.
Rick.
#741
The other reason being rick is mtx will require the chassis rail cut which I'd loose a lot as I only have 3mm with a ib5 due to being and early 4 spd
#744
YES I KNOW I CANT SPELL
i only have the bracket there for the servo as i went to fit it once but turned out to be in the way so went back to the origional set up of having the master on the drivers side (standard ford) it came with early basic mk3's and didnt run a servo
#749
as they say then you learn somthing new every day lol
#754
hahahhahahaha, few people have said that, il prob never use it as i dont plan on seeing car on the road anytime this year lol, ive sold turbo, want new exhaust, gt30, ported head, solid lifters and double valve springs and flywheel, clutch, new bottom end lol
#755
right, quick update: just popped down the garage and made up the rear gearbox mount/stabaliser, was a bit of a pain up the arse tbh as couldnt get the welder in there easy to spot it and was just making use of what metal i had left lol. will get some pics up later (after my kfc has arrived, been eaten and then sprayed mount etc)
#756
top mount with tube welded in, threaded and bolted up:
rear mount welded up to existing mk3 mount, was akward shape so just used some old bits of plate/bar lol:
mount bolted in and gearbox properly mounted :
next stage is to crack on plumbing in the hydraulic clutch once i get the fittings etc then off to have driveshafts made. sadly money tends to affect things as i need new block bored etc due to the 2 piece shaft
#760
