mk3 escort zetec turbo, poss breaking, 23/10/11 gauging interest
#642
clarke and several people have convinced me to keep it (plus i dont think i could handle what id get for it in bits without the engine running lol) so prob going to remove engine 2mo and look for further damage, will get it stripped down, properly cleaned through and see what im working with . The manifold was made by zetaboostboy, hw should be able to give you the details you need to know
#643
chatter 4 life
#644
well cracked on tonight and took the engine out (is pig now ith the manifolds and downpipe in the way) . i plan to strip it down properly 2mo and assess the damage i thinks its just shells mains etc at this point, crank looks ok thankfully, will have better idea 2mo
#645
Wye Valley Hardcore
There really are some devoted lads on this site. Yours and Luca's engines have gone tits up and are being being re-built and Lee's 16i already in primer after the fire yesterday!
Well done lads.
Well done lads.
#647
great to see u have the enthusiasm to keep it going,projects are a pain in the ass at best of times,but when youve travelled so far,spent sooo much ya gotta finish it,awesome project, will it be at ford fair? also were can i gt a exhaust manifold like that you have
#648
zetaboostboy on here made the manifold. poss, i dont know when it is off my head, hopefully, depending on damage i may try and fix it soonish but who knows yet
#654
engines kind of apart, i took the head off, all was good i.e cams etc. just need to get it on stand and strip mains, as long as crank is good it should just need gaskets, pump, a dip/flush and new shells and mains along with crank polish
#663
engines out and partially stripped, gearbox is sold. i havn't taken off the mains yet as not on stand but looks just to be a polish on the crank, new bigs and mains thankfully and have block dipped/cleaned and new oil pump (again). ive decided to go 6 speed getrag though so will take alot longer to get it back on road as clutch and flywheel is £800, then need to go hydraulic clutch, cutson shafts with a bit of fabricating work.
ive bought the box and mounts but am waiting for them to arrive. bought st170 pedal box for the hydraulic clutch and going to mod my pedal box etc so at some point may crack on again when i can be bothered. another delay being i bought a bmw with a friend for a track/drift/fun car so spent odd bit of time on that and has now limited my space lol.
#673
the speedlines grip soooo much better being wider and will look good eventually when all graphiced up and done what i want to do body wise, i have a fair bit of work to do on it 1st though. i tried making a start tonight by removing the pedal box so i can make a new one to run hydraulic clutch but then we had some freak rain which flooded the garage so spent all night clearing it lol
#675
yep you would have, was on north london pf stand, at a later date when its done and funds allow im after slighlty wider carbon front wings (whilst keeping the standard look and having them painted)
