EDAN Escort S2 Turbo.Update,03/04/11 reverse charge carrier fitted
#242
Originally Posted by puss
Warren wrote:
David this is getting a bit obsessive now, I think you need some help on the subject of ghost postings
Why not try the new thing called mapping your car
You taught me everything i know
just noyiced ive been ghosted aswell
#243
Originally Posted by K3V HA
Dave, simply stunning, i love this car, would you ever sell it?? Prob not, but i would have this off you in a flash, tis simply a piece of art!! I take my imaginary hat off to you!
#244
#245
Originally Posted by MFR_Tim
Top banana
Just read this thread from the start, the car is going to be a show stopper, if not another feature car
Good work chap, keep the updates coming
#246
Been doing a bit more 2day creating a small lip where the front of the dash meets
Smoothing out around the screen
Last few bits
Test fit
Needs building up slightly
Skimming up the edge
All done round here
The next area of attack
Will keep you posted
Last few bits
Test fit
All done round here
#252
looking amazing mate, real trick.
its all about taking your time with filling the longer and more carfully you work, the bettter it will finish out.
good luck with the rest geez
matt
matt
#253
Originally Posted by tonyturbo
is there much more u want to do to this car or are you nearly done with it. its absolute quality without a doubt.
#254
matt
matt
#257
Got some more piccys of the dash that i did today ,got a few mins spare so thought i would post em up. Going to do this bit today and finish off the screen area.Scuffed up the plastic so the glue will bond better.
Cut a thick peice of plastic to cover the hole,used super glue with an activator(very strong).
Added fiberglass matting inside to add a bit more strength.
Bonded in the other piece and bonded the white plastic in the front aswell.Also scuffed the face to receive the filler.
Also while i had a mix filled the little bits on the dash.
All smooth now, no holes.
99.9% done
Happy Christmas to you all
99.9% done
#262
Right been thinking,the dash is deffo going grey flock,in as near shade to the dash is now,but the section that bolts on (around the radio and houses the glovebox)should i have flocked in the same shade of grey or flocked black,wot do you think peeps.
#266
Here are a few pics ,using a sheet of cardboard i made a template of the shape then transferred this to a thick rigid plastic
This was then cut out and sanded to fit perfectly into the hole.
After test fitting it was bonded into position
The holes at the top will receive fiberglass and then the edges will be filled and sanded .
#270
Fucking superstar........
This is pretty fucking amazing stuff!!!
I have to admit I am more than a little bit impressed! You are indeed a highly skilled motherfucker! I can't wait to see the finished result! Keep up the good work!
#273
Right we are nearly done on the dash not much left to do now!!!!
Put some fiberglass in to the holes at the steering colomn.
Let that cure and gave it all a lovely skim of filler.
Rubbed that down and gave another skim, hopfully the last.
Area around colomn
A couple of shots outside ,still to rub down under colomn
All i can say is i am glad that its nearly done ,as its been a lot of hard work.
Area around colomn
#279
Spanner monkey
Dave,
Dash looks awesome, Lewis said he could do better though
You have too much time on your hands I finally washed the cossie on christmas eve, the first time for 9 weeks looked mint after though!! Not now, been out blatting it come over one day, i'm doing the cambelt on thursday if your'e bored????? i'll be round hayley's mum's!! then i need to put my new hoses and inlet / throttle body on!!
