EDAN Escort S2 Turbo.Update,03/04/11 reverse charge carrier fitted
#1725
Update time,removed the lower section of the number plate bar ,this was then rebonded back up to meet the top.
![Name: bonnetinpaint227.jpg
Size: 68.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99245d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-bonnetinpaint227.jpg)
![](https://img.photobucket.com/albums/v481/TWINSEDAN/Puss/bonnetinpaint228.jpg)
![Name: bonnetinpaint229.jpg
Size: 46.6 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99246d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-bonnetinpaint229.jpg)
![Name: bonnetinpaint230.jpg
Size: 66.9 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99247d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-bonnetinpaint230.jpg)
This will have fiberglass matting on the back side of the joints to give it strenght.
The white bits are plastic just to help the joints stick before the fiberglass is added.
![Name: bonnetinpaint232.jpg
Size: 61.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99248d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-bonnetinpaint232.jpg)
Starting to take shape,under the bar at each side where it starts to go down ,a filler piece will be made up for both sides to run to the bottom.
![Name: bonnetinpaint231.jpg
Size: 68.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99249d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-bonnetinpaint231.jpg)
On the uprights ,a filler piece has to be made and smoothed in.
![Name: bonnetinpaint234.jpg
Size: 50.2 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99250d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-bonnetinpaint234.jpg)
![Name: bonnetinpaint235.jpg
Size: 65.3 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99251d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-bonnetinpaint235.jpg)
![Name: bonnetinpaint236.jpg
Size: 73.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99252d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-bonnetinpaint236.jpg)
This is how it stands at the moment ,really pleased with it so far
![Name: bonnetinpaint233.jpg
Size: 72.6 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99253d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-bonnetinpaint233.jpg)
#1728
Looking good as always Dave
Its the same as how i did my old S2 bumper a couple of years ago, but you have cut more away
Will you be smoothing over/away the number plate patch?
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
#1735
#1742
Ok time for another update(with lots of piccys)been doing 10 mins here and there on the bumper when i get a chance.
Started to make the lower filler pieces ,making a template to shape.
![Name: bonnetinpaint237.jpg
Size: 44.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99254d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-bonnetinpaint237.jpg)
![Name: bonnetinpaint238.jpg
Size: 64.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99255d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-bonnetinpaint238.jpg)
Will then use this 4mm thick rigid plastic cut to shape.
![Name: bonnetinpaint239.jpg
Size: 70.7 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99256d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-bonnetinpaint239.jpg)
Shape then marked out on the plastic and cut out.
![Name: bonnetinpaint241.jpg
Size: 69.8 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99257d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-bonnetinpaint241.jpg)
This is then bonded into position and the same process used for the other side.
![Name: frontbumper004.jpg
Size: 54.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99258d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper004.jpg)
![](https://img.photobucket.com/albums/v481/TWINSEDAN/danfeb06/frontbumper002.jpg)
Then the top sections are marked out in the same way .
![Name: frontbumper008.jpg
Size: 50.6 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99259d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper008.jpg)
![Name: frontbumper009.jpg
Size: 38.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99260d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper009.jpg)
Plastic is now keyed up both sides with some 180grit paper(lower pieces are done aswell)
![Name: frontbumper010.jpg
Size: 34.9 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99261d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper010.jpg)
These are bonded into position,also keying the area on the bumper where they sit.
![Name: frontbumper012.jpg
Size: 41.8 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99262d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper012.jpg)
![Name: frontbumper013.jpg
Size: 35.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99263d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper013.jpg)
![Name: frontbumper014.jpg
Size: 59.9 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99264d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper014.jpg)
![Name: frontbumper015.jpg
Size: 46.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99265d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper015.jpg)
![Name: frontbumper016.jpg
Size: 41.2 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99266d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper016.jpg)
![](https://img.photobucket.com/albums/v481/TWINSEDAN/danfeb06/frontbumper017.jpg)
![Name: frontbumper018.jpg
Size: 43.2 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99267d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper018.jpg)
![Name: frontbumper019.jpg
Size: 62.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99268d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper019.jpg)
Also along the joints on the inside i decided to bond some more reinforcers on before the fiberglass matting goes down .
![Name: frontbumper029.jpg
Size: 59.3 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99269d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper029.jpg)
These also bridge the gaps where the bumper was cut.
![Name: frontbumper030.jpg
Size: 55.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99270d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper030.jpg)
![Name: frontbumper031.jpg
Size: 62.6 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99271d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper031.jpg)
Just a few pics of it outside as it stands ,next stage fiberglass
![Name: frontbumper022.jpg
Size: 84.1 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99272d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper022.jpg)
![Name: frontbumper023.jpg
Size: 52.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99273d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper023.jpg)
![Name: frontbumper026.jpg
Size: 109.8 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99274d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper026.jpg)
#1744
Team HOTHOT!
good work , what glue you use to stick that plastic as it looks like it melts it
im making sime skide skirts atm ( shorting them ) and have just fiberglassed them together , but i have cut one to short so need to get another bit of plastic back in there so would like to use a strong glue
thanks
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
thanks
#1759
Ok time for another update on the bumper .
Got the fiberglass matting applied and this has really given it strenght now .
![Name: frontbumper043.jpg
Size: 64.5 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99275d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper043.jpg)
![Name: frontbumper044.jpg
Size: 63.8 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99276d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper044.jpg)
![](https://img.photobucket.com/albums/v481/TWINSEDAN/danfeb06/frontbumper045.jpg)
Also thought i would enlarge these holes slightly.
![](https://img.photobucket.com/albums/v481/TWINSEDAN/danfeb06/frontbumper038.jpg)
![Name: frontbumper039.jpg
Size: 43.2 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99277d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper039.jpg)
![](https://img.photobucket.com/albums/v481/TWINSEDAN/danfeb06/frontbumper040.jpg)
![Name: frontbumper041.jpg
Size: 20.6 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99278d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper041.jpg)
A repair was needed here.
![Name: frontbumper042.jpg
Size: 53.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99279d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper042.jpg)
All bonded just needs fiberglassing now
![Name: frontbumper046.jpg
Size: 43.4 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99280d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper046.jpg)
Ground down the joint on the front ,still needs feathering with a d.a. then i will apply the filler.Also wanted to brace the lower section ,as it was out of line and also a bit flexible.
![Name: frontbumper037.jpg
Size: 75.8 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99281d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper037.jpg)
![Name: frontbumper047.jpg
Size: 42.6 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99282d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper047.jpg)
![Name: frontbumper048.jpg
Size: 49.0 KB](https://passionford.com/forum/attachments/restorations-rebuilds-and-projects/99283d1501884623-edan-escort-s2-turbo-update-03-04-11-reverse-charge-carrier-fitted-frontbumper048.jpg)
Nice and strong now
Nice and strong now
