My WRC Escort Zetec/Cosworth Build
Old 25-04-2008, 01:50 PM
  #121
fezzajsy
fezzajsy's Avatar
Old 25-04-2008, 04:58 PM
  #122
Turbo Zetec
Engine Machinist
Turbo Zetec's Avatar
will hopefully have an update for you lot soon, i've been busy lately doing more porting work! the head is currently at work ready to have the exhaust guides bashed in and seats cut.
if its a nice day tomorrow, i'll be outside working on the car, probably getting the recaros in
Old 03-05-2008, 01:36 AM
  #123
Turbo Zetec
Engine Machinist
just a quick one, my head has now had new exhaust guides mashed in and has been welded again to get rid of any corrosion that might affect the cometic gasket from sealing properly. while i was playing on our SERDI, i decided to give the head 5 angles on the inlets and exhaust seats
also managed to semi-bolt the drivers seat in and bolt the passenger side runners to the seat. i'll hopefully get some more of the interior done this weekend, weather permitting... and if the missus lets me!
i'll get some pics up soon
Old 10-05-2008, 08:42 PM
  #124
ajn-1978
ajn-1978's Avatar
Default bumper .
nice job on car u done, just wondered where abouts u picked up the bumper and wings ? cheers
Old 17-05-2008, 12:03 PM
  #125
Turbo Zetec
Engine Machinist
Some Parts For Sale, See Cossie For Sale Section!
Old 17-05-2008, 12:22 PM
  #126
McGoo 69
McGoo 69's Avatar
looking good mate!! ditch the tints imo but apart from that its very smart!!
Old 02-07-2008, 04:38 PM
  #127
Turbo Zetec
Engine Machinist
right... a complete change of direction for this project! i've ditched the cossie engine and am now going for a big power zetec turbo! my reasons for this are pretty simple really, the cossie parts are getting horrendously expensive now, also they're getting a bit harder to find in descent condition. i can pick up new parts for the zetec from the states, or even from the local scrappy
so far i have picked up a blacktop engine from a FSH low miler mondeo, stripped it down to a bare block and have taken it to work ready for machining.
some parts have arrived already for the build, these are:
JayRacing Billet steel main caps and ARP main bolts
Eagle 'H' section rods and ARP bolts
JE forged pistons
the JE's will be slightly modified for lower CR, as will the head, but not massively
i'm thinking of machining a custom flywheel to take a skyline twin plate clutch, but thats just in the planning stages at the moment.
everything is looking good so far, i hope the new engine will make over 500bhp
Old 02-07-2008, 04:41 PM
  #128
Dan
Dan's Avatar
That will be some Zetec that makes 500bhp!
Old 02-07-2008, 04:49 PM
  #129
Turbo Zetec
Engine Machinist
it won't be the first, or the last i'm sure
by the way, engine cost so far (so you can compare with a cossie build)
Engine Ł100
Main caps + arp's Ł300 (+Ł40 import tax)
Pistons and rods Ł550
so basically, i've got a very strong bottom end for under a grand!
Old 02-07-2008, 05:00 PM
  #130
TimC
TimC's Avatar
What CR are the pistons, and where about did you order them from?
Old 03-07-2008, 10:59 PM
  #131
Turbo Zetec
Engine Machinist
the pistons are supposed to be 9:1 CR, but will be more like 8:1 by the time i'm finished with everything hopefully
right, tonight i've been back to work to machine my billet main caps. we came up with an ingenious way of boring them on our cylinder boring bar... we do have a line borer, but it was deemed easier on the boring bar
first we had to check that the block was sitting true on the machine, so i bolted the old main caps on, then set the guage to check we were central on the ID. ui then moved the guage down into the other mains to check taht they were also straight and true. with a bit of fine adjustment, it was spot on
all set up:
we then had the dilemma that we'd never bored steel before... only ally or iron, so we had to set the machine to take small cuts off at a time, with a slow feed speed and high spindle speed, to try and keep it from smashing a tip, or moving the block. we got it sorted and set it going:
Smokin' . We then made the cuts bigger and bigger until we were 2 thou under final size.
onto the next machine... the line honer! this makes sure that the caps are completely true and all honed to the correct final size.
here's a pic of the machine:
after a few licks with the hone, and a bit of measuring, this was the end result:
Spot on . hopefully i'll be able to bore and face the block tomorrow (all done on the boring bar i used on this). i hope this has helped some people understand what these jobs entail, as i know everyone on here isn't an engineer or mechanic. i'll hopefully be doing some more step-by-step guides as i do more machining
let me know what you think
Old 03-07-2008, 11:04 PM
  #132
Nash
Cake lover!
Nash's Avatar
Very interesting mate, good to see how its done.
Old 03-07-2008, 11:23 PM
  #133
JonnyBravo
JonnyBravo's Avatar
Thats quality mate, good to see someone else using something different
Old 05-07-2008, 11:45 PM
  #134
Turbo Zetec
Engine Machinist
i've ordered my valves today... 1mm oversize on inlet and 3mm on exhaust. they should arrive in the week so i can start porting
then there's the dilemma of which head to use... i CC'd the blacktop head today and it came out at 45cc... 3cc down on what i was expecting . however, the silver top head looks as if it'll be a fair bit bigger... but i haven't cc'd that yet, so i can't tell. i may also CC the st170 head, just to see what i make it .
as far as information on the net goes, the ST head is 40cc and the other heads are 48cc, but obviously i've found that to be false so far.
i'll update in the week when i've cc'd the heads
Old 06-07-2008, 08:05 AM
  #135
adam151082
adam151082's Avatar
wooooooooooow, what an awsome project. i'll def be keepin an eye out for this 1. top work mate
Old 06-07-2008, 08:43 AM
  #136
pa_sjo
Colossal Pervert
pa_sjo's Avatar
It's nice to see someone actually testing/measuring rather than just listening to bullshit on the web Good work chap..
Any particular reason you're running these billet mains? I've never seen a standard one break!
Old 06-07-2008, 06:27 PM
  #137
MAD EVO 4
MAD EVO 4's Avatar
Looking good Martin
Please keep the up dates coming
Old 06-07-2008, 06:54 PM
  #138
luke89
Team HOTHOT!
luke89's Avatar
awsome build, and from what i read so far a hell of a lot of very good info with more coming ! keep up the good work ,
Old 07-07-2008, 04:54 PM
  #139
Turbo Zetec
Engine Machinist
cheers for the comments everyone
neither have i, but the yanks are paranoid about it... so i thought i'd best be cautious and got them as a safety measure the standard ones on the blacktop do seem very small compared to the silver top ones.
i cc'd my silver top head today and found it to have a 48cc chamber... so ideally it would be the one to use, however, the belt setup would cause me more headaches .
i'm going to do a mock build soon and work out the comp ratio properly . there is a fair bit of material that can come out of the chamber and off the pistons before it harms anything.
Old 07-07-2008, 11:06 PM
  #140
Turbo Zetec
Engine Machinist
right, i've been back to work tonight! while i was there, i decided to finish the machining to the block. here's what i did:
firstly, i set the block on the boring bar and clamped it down. the fly cutter was already on the machine, so i decided to face the block first. i had to make sure it was sat squarely on the paralells first by using a dial guage on the fly cutter and moving it across the block face. after a bit of fine tuning, it was set within 1 thou all over
i then set a cut of .05mm (2 thou roughly) and let it go across the face:
finished face on the right, unfinished on the left:
a perfect finish . next, i had to change the machine to use a boring bar:
i then had to set the boring bar in the centre of the bore using the dial guage and finger attachment on the machine (sorry for the blurry picture, my friend dick was at the control of the camera, still, it saves my ugly face from smashing your monitor ):
after it was set, we measured all of the pistons and set the cutter to just below the tolerance set by JE to allow us to hone something out of it. we then sent it down all of the bores:
and here's the block after boring was completed:
next, its onto honing! we're old fashioned and do it all by hand, but it gets the job done, and does it well. here's a pic of the block being honed:
and here is the finished block, 84.99mm bores all round, giving it a final capacity of 1998.2cc :
all this means i can now do a mock build ond work out how much i need to lose off the pistons or out of the head to get to my desired CR
i remeasured the black top head today, made it 44cc this time (i cleaned the face properly). if i intend to get anywhere near my desired CR, i need to lose at least 10cc from somewhere
thats all for now, hopefully my valves will arrive tomorrow so i can start cutting chunks out of my head
Old 07-07-2008, 11:10 PM
  #141
Chip
*** Sierra RS Custard ***
Chip's Avatar
Whats your desired CR?
Old 07-07-2008, 11:14 PM
  #142
JonnyBravo
JonnyBravo's Avatar
Looking good Martin.
I'm sure there was something else you were to do that was a priority though
Old 07-07-2008, 11:15 PM
  #143
Turbo Zetec
Engine Machinist
top secret
nah, i'm going for around 8:1, its in the middle of what can be run. i've asked a very well known ford/mitsi tuner his advice on it and he advised that if he were to build another one, it'd be in the 8's
turbo choice will be gt3076r to keep it fairly sensible
Old 07-07-2008, 11:16 PM
  #144
Turbo Zetec
Engine Machinist
that shoddy vauxhall head hasn't turned up at work yet . though i did mention to andy what you asked me to do
Old 07-07-2008, 11:34 PM
  #145
JonnyBravo
JonnyBravo's Avatar
@ top secret C/R's, not another one LOL, he still won't tell me either
I'll have to give him a ring so he knows what I want doing, don't diss the GM badge to much as you'll be sick when I overtake you
Old 07-07-2008, 11:40 PM
  #146
Turbo Zetec
Engine Machinist
are you talking about gav? i might know his CR , i know andy's too . i get to hear all sorts about these vauxhalls at work .
i hate to tell you this... but your car has a FORD badge
Old 07-07-2008, 11:47 PM
  #147
JonnyBravo
JonnyBravo's Avatar
Must be painful hearing about real engines all day
You may well be right, I've not seen it for so long I've forgotten what it even looked like
Old 07-07-2008, 11:53 PM
  #148
Turbo Zetec
Engine Machinist
i get to hear all the gossip from the other side of the fence . its good really, we bounce ideas and theorys off eachother all day long i'm surprised he's not bored of it by now, although i think he enjoys arsing about with engines even more than i do .
has deek's Ł1200 head made it onto his car yet?
Old 07-07-2008, 11:59 PM
  #149
JonnyBravo
JonnyBravo's Avatar
No idea about Deeks head mate, I only ever see him when we meet up with Steve.
Andy must be a great person to work, proper petrolhead
Old 08-07-2008, 12:04 AM
  #150
Turbo Zetec
Engine Machinist
i just wondered, andy told me about it and the price nearly made me fall over
yup, he's great, as is dick. we all like to have a tinker with the odd engine
Old 08-07-2008, 12:18 AM
  #151
JonnyBravo
JonnyBravo's Avatar
TBH I have no idea what was done to it but I was offered a VERY serious xe head last week and it was considerably more than Ł1200 mental in comparison to Gavs head but I felt its a massive overkill for what I need when Speckys done so well with his.
Clearly Andys heads are doing the business on the let engines, I do however know these other heads have been giving some ridiculous numbers on xe's, I can't comment on Neils work as I only hear about it through others but they should do the job.
Old 08-07-2008, 12:48 AM
  #152
Turbo Zetec
Engine Machinist
i think there's more to be had out of specky's head, aside from the porting, its pretty basic tbh! lets hope gav makes some good figures on his!
just to make you feel better... my head will be costing me the price of a set of valves and possibly some cams and springs... so under Ł600 hopefully
Old 08-07-2008, 12:54 AM
  #153
JonnyBravo
JonnyBravo's Avatar
I'm sure it can go further, wether he needs to is another matter lol
I've just done Ł450 on solids, shims, springs and retainers
Oh well, so much for building something cheap
Old 08-07-2008, 04:32 PM
  #154
Turbo Zetec
Engine Machinist
why? isn't it proven that you don't need special cams or solid lifters to achieve the power you're after?
guess what arrived today....
my valves!:
3mm oversize on the exhaust and 1mm oversize on the inlet:
Many thanks to Autosprint for supplying these to me at the right price and getting them here in double quick time
now the hard work begins
Old 08-07-2008, 04:57 PM
  #155
JonnyBravo
JonnyBravo's Avatar
Valves look nice mate.
Its proven that you can't rev any engine hard on stock springs and hydraulic lifters, the retainers are there simply for safety as if a 100k old one broke I can say bye to my engine or atleast one cylinder. Reliability is the key, Jus the drive to Germany will be more miles than Speckys engine ever does
I'm not building it to be a one trick pony although I don't expect it will be amazing at everything, I just want to enjoy it
Old 08-07-2008, 05:11 PM
  #156
Turbo Zetec
Engine Machinist
fair point, just don't go too crazy reading between the lines, you're after half a KHP aren't you?
Old 08-07-2008, 05:15 PM
  #157
JonnyBravo
JonnyBravo's Avatar
Off gas yes
Old 08-07-2008, 05:17 PM
  #158
Turbo Zetec
Engine Machinist
same as me then... with hopefully 100 of gas on top
Old 08-07-2008, 05:27 PM
  #159
JonnyBravo
JonnyBravo's Avatar
Race on
Old 08-07-2008, 06:23 PM
  #160
Turbo Zetec
Engine Machinist
Race on
i'll win... by the time my car is finished, you'll still be waiting for your shell
Quick Reply: My WRC Escort Zetec/Cosworth Build
