MY 205 GTI-6 Supercharged Track car
#241
Good work shorty!
The only thing I didn't like were the brake lines running straight to the calipers through the bulkheads. I would have put bulkhead fittings in.
Otherwise, spot on!
Otherwise, spot on!
#242
yeah did think about that, but i meant more connections,
i've put some rubber hose on the part where they go through the front arch's, this needs to be re addresses, but otherwise i think i'll leave them as is
#249
bit more of a update from tonight
gave the engine bay a bit of a clean
all by hand too
and here is the subframe and rack, which i'll blast with the water pressure jet tomorrow
all by hand too
#252
yeah hour and half last to get engine out
and another hour or so tonight giving it a clean and removing the suspect drive shaft
soon i hope, i'll be bitting noddy's arse
#259
if i need a hand?
bit bloody late now
actually could have had a hand , but never like to ask people
i actually needed the engine lift to put the gearbox on
then take it off again as the thust bearing came off
forgot to add, LOOKING for RST, since when has that plan gone ahead?
have you told kath?
bit bloody late now
have you told kath?
#265
nice one spiky, been following this on drivers too
did you do all the wiring yourself? how did you get on?
and what engine mounts did you use in the end?
going to start my gti6 conversion in the next couple of weeks
#266
yeah did it all myself,
wiring was ok, though you need to rund a switch live to one of the grey cables on the gti-6 loom this powers the ignition module relay, without this it wont eve start, as i found out,
the rest is simple match for match
i have a full front engine and rear beam bbm kit 124 delivered
#273
and here is the car ready for it's mot tomorrow
new foam on the roll cage
and new bonnet pins, due to me moving the rad forward a bit, the bonnet catch, was sticking a bit
and for safety
and for safety
#276
Cool as fuck
Been watching this, Just not posting...
Whats it cost you roughly to convert it, cage etc etc??
i'll do quick tot up, thought i may cry
car Ł800
cage Ł300 + Ł100 for fitting cage and seats
some wheels and tyres Ł350
new gti6 engine Ł500
parts to fit new engine Ł300 i guess, maybe less
i also replace suspension links and ball joints steering rod ends Ł50
gti-6 grakes Ł150
new alloy rad Ł40
driver seat Ł100
passenger seat Ł50
harnesses Łbasically free due to sell some bits
dry cell battery Ł35 new power leads Ł20
think thats most things, there's probably a few things i missed, but that just about covers it
#278
Cheap fun then!
hopefully it will be realible
Originally Posted by bigmatt-s2rst
have u got any pics of the roof mate? have u plated over it? what sealant have u used?
cheers
cheers
#280
sound, that ll be one of my first jobs, my roof is pissing in,
car looks good, bet it fookin flies with that motor in, my 1.9 is rapid and its standard
