Peugeot 205 with 4wd cosworth engine and running gear.
#2921
cossie fan (unluckerly)
All this shows that bitter old man is absolutely not an engineer. I told that twat he was a cnc operator and a welder that’s it. It didn’t go down well lol but it’s absolutely true. He has no business doing work like this on peoples cars. He needs taking to court by someone. Sad thing is after coming across him a few times on Facebook I think he actually finds how shocking his work is funny when you pull him up on it
The following 3 users liked this post by ajamesc:
#2922
I am going to get a mate over who knows much more than I do before I chop it out. See if we can make a nice fix.
ajamesc (22-05-2022)
#2923
You'll be all the more satisfied mate once it's done right and you know it is, the power your going to put through it, it would've pulled itself apart it'll be mint when you e finished with it
#2924
Thanks, I am certain I will get it right.
smiley (23-05-2022)
#2926
If I can get the caster angle down to a sensible amount without cutting it out then I will be happy
#2927
It’s only metal it can be cut welded and moved about. Just needs knowhow time or money. No doubt your get it sorted.
#2929
I keep telling myself that there is nothing I cannot do and if I don’t have the right tool or machine I will get it done locally.
#2931
once I have shorter suspension struts I can see if I can get the wheel central to the arch. At the moment I cannot get the wheel close enough to the arch to allow the suspension to show me where it needs to be and the adjuster on the shock touches the chassis.
At the moment the caster is quite extreme. I may be able to keep the turrets and play with the top mount, I may swap to adjustable top mounts front and rear anyway.
#2932
The 205 wheel is not all that big normally, add in a gearbox tunnel and you begin to limit the floor space. The harness bar was cut out as I couldn’t get the seat back far enough to fit in the car and it was too low anyway to be safe. I still had an issue with the seat hitting the cage feet boxes and I need to get runners in. The front cage foot was similar as I was cramped for pedal box room and very concerned that I would break my ankle on the box in a shunt. Willie Green got in my track car once and explained just how painful a broken shin is when you wrap it around a cage leg in a bump.
Passenger foot box front.
Drivers foot box front. I have drawn on to the offending bit that seemed to be far too big and my ankle bone rested on it when legs straight. The seat has no other wiggle room but does give dead straight run to the pedals apart from this foot in the way.
#2933
Rear drivers side blocking the seat runner and back of the seat, I drew on the bit that didn’t really need to be there.
#2934
I wondered if there was some floor strength box running through but only Mr Angry the grinder could tell me…worst case I would have to weld them back I .
Nothing in the back one at all…I can just put some 2mm-3mm steel across the hole and box it in.
Front is the same, I can plate it in, no reason that I can understand for it to be there…loads of thick steel still left for the cage leg to sit on.
#2936
I will complete all of the floor welds and bulkhead welds once my new engine mounts arrive, I just want to check the engine and gearbox sit right before I weld it all up for good.
#2937
Legs straight now and no more ankle danger, I can get the seat back and legs out stretched now. Just need to buy a good pedal box now as that wasn’t completed.
#2940
i think just the tops of mine were 120cm2 without the sides of the box. Maybe he made the tops 10x12 to hit that figure but didn’t factor in the box profiles?
#2941
Just checked, I have way more than the 120cm2 left front and rear once the sides are back on. The side I need to add back is 60cm2 alone.
Thanks again for confirming, lazy for me not to have looked it up but wasn’t aware there was that rule anyway.
#2942
If I look at the rear turrets on my escort they have a reasonable flare them (wider at the bottom) likely specifically for clearance They are much wider than yours appear to be. Like these.
this is the pic I found on the web (not mine, credit to them) of rear suspension mount points from (I think) an MSport escort WRC shell. They arent centred on the wheel centre line, but the centreline of the diff output flanges are the centre line of the wheel arch. In full droop the centreline of the hub will fairly far forward of the wheel arch centreline, determined
underside
inside car
hope they are of use.
underside
inside car
#2943
Thank You Jono...that is exactly how I was trying to explain that they should be to allow the damper to be at the correct angle without hitting the turrets. It makes a lot more sense when they are like that and the cones in that way do not make it look silly when the strut is at angle wider than the tower.
#2944
Grabbed a couple of hours today and plasma cut some plate to go in the rear cage base plate. I have also used it to build in the lower harness mount clip on point.
I am going to run 2 options. 1) will be a 3 point retractable harness 2) will be a 4 point clip in for more serious work.
Harnesses can be a pain on the road and a barrier to using the car so the retractable ones will make it easier for when I just want to jump in and go.
#2945
#2946
Thanks, the angles on mine are more extreme than that but I am working on it. I think that if they had made my turrets like that I may not have had the hassle I have had. The other issue with mine is that the chassis had not been notched where the suspension leg needed to go, I have done that now. Mine were not big enough for the reservoirs to move up and down…same Shox as those too.
#2947
[QUOTE=jono_misfit;6830159]I also found this in my collection. Which i think may be someone fitting MK products.
Quote
Top lurking on the forum by the way….4 posts since 2015, 3 on here. Would be good to see some pics of your Escort.
Quote
#2948
More sanding and filling today, this was the largest area of damage on the wing. I cannot feel any deviations to the touch now so probably one more coat of high build and block it back and that area should be done. There are about 7 repair areas on this wing as it popped 4 of the filled rivets where it joins the car, another crack like the one in the pic and then a crack up the door pillar and along the window ledge. Nearly all sorted now….I hate body work.
#2949
Engine mounts arrived from Dewitts, they are more industrial looking than the ones that went missing but i doubt much of them will be seen and I can always add showy ones later, I need to see if the gearbox fits the tunnel as my box is the oppliger long box, I took it up to the car whilst it was there but I don’t know if it was ever offered up. Once I know it fits I can motor on with completing all of the floor welds and finish that bit up ready for rust proof and paint.
smiley (27-05-2022)
#2950
I found another part of the cage not welded but I can get in there with the mig:
Upper door bar.
Upper door bar.
#2951
I have put in the L shape on the front cage leg, drivers side. Angled it back towards the cage to keep it as far away from my ankle as poss.
I left 3mm of the old platform poking up from the floor and welded the base to that, then put a thick weld from the old base to the floor as it had only been tacked on this side,
#2952
This part of the floor will be body colour but using a raptor liner sprayed in there and a grit added for non slip.
i will stitch weld along the sills.
#2953
There wasn’t a weld along this box so that has been done now
Quick release spit…..quick released
The black bar across the front was an old mount for the rad, I will cut this out now and re do.
Ready for a test fit of the engine and gearbox. I am going to have a few days off it now and then push on with the engine mock up.
#2954
someone told me the weld I have zoomed in on is too cold as it doesn’t tie in to the floor…it actually floats above the floor and is not meant to tie to it, it welds the plate I added to the box only. I then welded the floor to the box after.
smiley (29-05-2022)
#2955
I can't believe how bad this thing is. I said all those years ago not to send it to that clown. The time it was away and this shoddy horrific work quality is exactly why.
But, the past is just that, it's good to see you cracking on with it, lessons learned and get it finished. I really feel for you. So many have gone before you in the same situation.
In all honesty i have no sympathy for toby, the amount of advertising and blatantly shoving mk into all our faces for years has back fired.
#2956
Fair Comment. I have openly admitted to my error.
How was your beam you bought from him at the same time? All ok I hope?
markk (29-05-2022)
#2957
Wisdom isnt taught its gained through experience isnt it?
toby is now 300 yrs old 3ft tall and green he is 😂😀
#2959
OMG its been ages since i have seen any progress on this build (just like my own) i have just cough up on all thats been happening since you got it back, im so happy to see that you are making progress with it, it does get you down after a while, we all need a kick in the arse now and again to get motivated and you have just given that to me. i will be in touch very soon mate, thank you for the updates
#2960
The engine side of the mounts were lost whilst away so I had to buy some from Dewitts, the centres must be different to how MK had done the so I had to plasma cut the inner parts of the chassis side to allow the plate to be tapped back 5mm and then weld them up again, this stopped the metal around the bush hitting the chassis mounts.
engine in and gearbox trial fit will be tomorrow….fingers crossed. I have a sneaky feeling there isn’t room for the slave cylinder and I don’t know if my actual gearbox was ever mocked up to the car whilst it was there….time will tell.
Once I am happy with the exact engine position I will put a plate over the bolt hole on the mount as I had to slot it to get the Dewitts mounts in.
I have put a spirit level on the shell and the engine and it does sit dead flat….or atleast will with the gearbox weight on the back as it wants to tilt forward a little now. In this pic you can see the cuts I previously made to the scuttle panel to stop the cam trigger and breather hitting…you can now see how much lower the engine sits. I will fold up some boxes to finish the scuttle, just in case the engine needs to come up a bit.
The following 2 users liked this post by Caddyshack:
james kiely (04-06-2022),
smiley (04-06-2022)
