E5 MDS 4x4 saph re-build . . . for sale . . .
#245
got these but then sold them gona get some new ones, not quite as mint as id like
offered the anti roll bar ? compression strut up and the paint in chipping off like its nothing, dont think they sand blasted it before powder coating so will be getting done again! stil looks ok tho tricky!
#246
mmm new tyres nice and sticky, more parts from ford-the vents that go in the back side skirt fitting kit, door switches etc etc
and sold my rl7's but wish i hadnt now!!! red stuff pads from my fiesta stil like new
#252
Originally Posted by DazC
Looking good!!
Hope it's going to be as good as the Fiesta was.
#253
Looking good!!
Not worked on mine for ages and ages. It just gets driven every so often and then it tries to kill me.
So on that note, I decided to get it booked in at Adrenaline for a suspension set up and I also need to reduce the braking pressure to the rear brakes.
Thats all that has really happened to be honest. Too busy with every body elses cars/vans/trucks etc... (Currently AJC's Escort!!).
#254
lol fair play!! i dont think ive even seen it yet you know! they certainly seem to be the pple to go to at the mo-for me too i think. what sort of power is it at the mo?
#256
really good project you are doing.
#258
some more bits!!
new konis
a set of ahmeds finest 'track' springs
was going to go with a set of avo coilovers but after reading mike rainbirds article in fast ford i opted for these and a set of his rear beam shims. a very simple idea but hopefully effective
proper turbo filter
spacer for extra oil pressure / temp sensors
massive to mike rainbird for always replying quickly to e mails even for advice and very very quick delivery! top service!
new konis
proper turbo filter
#261
Power is about 180 at the moment if that!! It runs standard ignition advance and 14 psi held (yet runs lean above 5k rpm).
#268
The modified TCA and compression struts set up that you have are the same as the ones fitted by turbo technics to the Twin Turbo XR4x4 Minkers.
There are a few Minker owners on http://fordpower.org.uk/forum/index.php?
#270
There is a slight difference between yours and the set up that Dave on Ford Power shows in detail - that being a flat bar that bolts between the ARB mounts but this could be down to TT modifying the set up maybe?
Where did you get yours?
#271
lol are you planning anythin with the engine or keeping it as it is?
It's always been on the horizon, it's just other people keep wanting things done to their cars. Mine is going to be the last one to be finished if al all!!!
#272
1st part to my hydrolic clutch conversion! was gone get a slave from atm but heard a few things about them and this one came up! its a proper tilton one (like new) and are fu**in expensive new so snapped it up!
just take the centre bit out of box and screw this in job done, just lookin for a suitable inboard master cylinder to use then make some brackets up when cars back will be 100 times better than cable
#275
hopefully national day then get it perfect for show season nxt yr. stil be able to get to pod in it a few times hopefully!! cheers for the comment!
#277
couldnt get to the bank in time for the money il go first thing in the morning to order it and if i cant get it tomo will heve to be tues!! sorry mate i should be more organised!!!
