E5 MDS 4x4 saph re-build . . . for sale . . .
#441
where did you get the poly bushes at for the gear lever cradle at i saw them in a book once but i could never find them since. engines a work of art though nearly to nice to put in!!!!!
#442
#443
Originally Posted by NEEDFORSPEED
yes its a door in primer!!!! all the weldings done, not on rot but on other things but i cant disclose this information so that ajc doesnt know! thanks cossystevo lol!
#447
Originally Posted by lewismk1
Looking brilliant as ever mate really cant wait for this to be back together!
The hard works paying off!!!!!!!
#449
coils arrived today. i cant make my mind up wether to paint the turbo filter or just leave it blue??? will get the hoses made up tomo.
all the stuff came for the loom aswel so started makeing that.i like the pectel braided style ones but really like mike raindirds loom made in heat shrink still all labeled up so thats the way im going.
started by sorting the wires out theres that many inputs/outputs and things ive had to add is quite a head fuck!! twisted all them together with a drill to keep them neat before getting right lengths and finishing off with labels and plugs etc
4 x relays
1 for fuel pump, injectors
1 for nos on/off
1 for coils, iscv, boost solonoid, speed sensor
1 for water injection pump
my head hurts
4 x relays
1 for nos on/off
my head hurts
#455
Originally Posted by DazC
I only hate them because I work on AJC's!! I used to hate mechanical work until I gave up working on AJC's! Still hate servicing AJC's though. Boring job....
#462
done some more on the loom today. offered it all up next to the engine n got it all measured up. heat shrank it all and used the adhesive stuff in the joints. takes alot longer than youd think! alot harder to use than the braided stuff anyway i think!
got a proper dymo labeller with heat shrink. using white rather than the normal yellow. hope it looks ok! ryan uses clear heat shrink over the top aswel but i think it will be ok if i look after it. can always de pin and add at a later date anyway
will hopefully get the plugs on tomo morning if i have time and check everythings ok, hook it up to engine, power up and make sure everythings a ok! if only i could start it!lol not lkong now . . . .
#464
yours n mike r's looms made my mind up to do it like this mate! i spoke to daz c about it and e mailed omex asking them what they made them out off and hey presto!! so cheers lol
#466
they are actually heat shrink labels mate the printer prints striight onto the flat heatshrink. so as long as i dont get them dirty i think theyll be ok. have no use for it now so if you ever need to boro it its there mate
#468
I'd probably still put clear heat shrink on it but that's just me!
#470
#471
well looms finished. double checked it all this morning then got it hooked up to a battery + lap top. to say im happy is an understatement its a proper good bit of kit! although i programmed all the inputs and outputs that im using then the batt went flat on my lap top before i saved it so had to do that again!
#475
bored shitless so i thought id plug it all in to see all the temp sensors etc working and set tps up before i put inlet on (ball ache to getr to screws with it on) everythin spot on!
i want to fire it up!!lol
