The Antique (BIG Thanks to AJC)
#44
Re: Winter tidy up...(BODYSHOP Update)
Mr Diva hard at work
The original sump came off 2 days before the Germanys Easter trip for a big wing. Thanks to Lee@Fusion
#45
He is mate, it was just to keep the gasket in place while we put the sump on. But after a few 100miles the shitty cork gasket decided to weep
Hence why the engine came out before Germany, excuse to put the Big Wing on & put a Cometic gasket on. Its been PERFECT ever since
#49
Originally Posted by James_RScos
Paul how long is it going to be at the bodyshop for mate ?? and what are you having done.
Im in no rush to get it back.....i no it will be right as Stu@MSD's old Smokestone has just come out the same paint shop.
#52
Originally Posted by GAZ@RACE-SPEC Motorsport
are they different comp mo's on the car or the same white ones from before?
LITTLE UPDATE:
Recieved my additional loom bits off Ryan today So this can be soldered into the Pectel loom ready for when the Antique comes back.....
#61
Looking really good Paul
Going to be on the lookout for a nice set of 18" RL's for the 3-door soon if you come across any might even part with the 17"s that are in the loft if the right deal comes up
#64
Small Update:
I remembered i had a new set of morettes outer lights in the parts stash somewere, so set out to find them seeing as mine were getting a tired. Found them and replaced them with the new units
New Lights:
New & Old:
All Fitted:
How manky do the old lights look
New Lights:
New & Old:
All Fitted:
#72
Looking good the work your getting done m8
How well can you see at night in your car just using the outer lights m8?????
Yeah,and so they should for fooking Ł75 each!!!!!!!
Priced them up through Mike R the other week,thought wouldn't bother as I 've had 2 lamps broke from chippins in 6 months
Can get the orig Morette fitment Cibies from Demon Tweeks,around Ł25 each
Got the part numbers if any1 needs them
The crystal ones would look
#74
Planning on running mine just on outers,got some carbon intakes to replace inner lights
Might have to buy a HID kit then to be able to see
