My 3door cosworth project.* UPDATE* BREAKING
#3366
thats cool Dave it will work what ever and looks close but put a angle finder on it and get as close to 13 degrees as poss you can get a cheap anle finder from cromwells if you have one local top work mate
#3368
#3369
#3371
Definitely needs an undertray to make that work properly IMO.
As lovely as it is, cos of all the lumps and bumps on the bottom, the air will be in a shit state by the time it gets there. Get a flat floor on it
#3380
Jay what bit has got to be 13 degrees & why as im putting a rather large one under the back of my escort .
#3381
#3383
I was just about to ask the same question ! I've just sorted a flat floor for mine and possibly a diffuser if the rear axle and arb isn't in the way ]!
the 13 degrees needs to be the the flat part of the defuser the goes from the rear floor to the cut out on the bumper ! so if you have a flat sheet fixed to the rear subframe then the sheet needs to incline to the rear of the car at 13 degrees up to 2mtr in length the downward fins (venturies) are just used to stir the air to aid more force . At 13 dergrees seems to be average number then it will generate optinum down force so take the floor as level then potract a 13 degrees incline at the rear .Flat floor is another good idea BUT if you have a good aero splitter that goes as far as the front floor and the rear deffuser then it will be a massive difference even without the floor
hth guy's
#3386
Having just seen Ronnie's splitter, I'm now off to the garage to start copying it lol
#3387
Nice one Jeff, like your car a lot !
What arches did the last shell have, I think I was up at glynns when he was doing that shell, didn't that have normal arch trims but just fitted a lot higher ?
#3389
Rich, I'll get the new ones finished before I make any moulds, but its extremely time consuming so I dont know whether its feasible to start making these up for other cars.
I'll start a separate thread on my car as this is Ronnie's post, and I dont want to detract from it - Ronnie's done some really nice work on his car best we keep it about his motor and not mine ! Sorry Ronnie
#3390
Few more pics ,diffuser fitted on ,just need to fix to the 13 degree angle,
cut 1 inch off the front arches which then gave us some nice pre painted rear arch extentions
bit of finish work to do on the join still
#3393
finally back on here lol
nuttynil, it was a complete sill pattern part, i think their easy to get hold of?
since i've been off i've had the wheels re powder coated
also been to joe's for his adjustable clutch conversion, new tps, a tune up, and also to look at my brakes think i melted the seals in the master cylinder on the trackday,
fitted my carbon bonnet vents
also got my mirror's today and i'm so happy with how they look
the twins come to my work today and we fitted them on
also got some stickers as advertising for joe gs motosport
dave painted my splitter for me as it's taken some abuse lately
before
after
will get some better pic's of it all when i've cleaned it
before
after
Got the mirrors already.
#3397
Some nice work there guys.
Canards and rear diffusers are a mine field of technical info, hope they work as intended. We use photographs and video footage as well as Alans arse to see whats going on, as a result of this we changed from a twin bladed rear wing to single deeper one. We still get the downforce we want but with less drag. We ditched our canards (on the old car) because when coupled to the heavy v6 engine we had they actually caused us to have more understeer.
Cars looking racey. Well done to the team.
#3399
front arches look loads better now they are not as wide, and the wheels are filling them nicely!
rear looks quite cool too
is that diffuser made of mdf or some other space age material??
looking good guys
ps are the wheels just on spacers now?
i have some eibach 20mm hubcentric spacers for sale if interested, as im sure you already have long studs fited.
looking good guys
