mini fuel type project thing on the 3dr
Decided to update the fuel system on the sierra as basically its 20 years old
also I noticed that previously in its life someone had jacked the car up on the fuel return line
Here’s how I got on............
1st up the wiring was taken care of;
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0115Medium.jpg)
8AWG wire to be run fused at the battery directly to the fuel pump via Relay triggered by the OE wiring.
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/loom1.jpg)
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0142Medium.jpg)
That’s everything taken care of at the engine bay end..............
Now to the boot
Relay mounted in the cover for the jack
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0141Medium.jpg)
Teminals soildered and crimped on for the fuel pump
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0140Medium.jpg)
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0128Medium.jpg)
Whilst under there anyway the tank got a lick of paint
![](https://img.photobucket.com/albums/v489/Sirnixalot/Andys%20Cossie%20Pix/mini-DSC00747.jpg)
Also cleaned up the cradle got a Grp A pump and new filter
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0094Medium.jpg)
Then I needed to mod the cradle so the filter was round the other way to simplify the setup.
Final product
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0119Medium.jpg)
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0121Medium.jpg)
With that lot all bolted together it was time to run the lines
Made the ends up
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0152Medium.jpg)
Dropped the old lines....
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0146Medium.jpg)
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0145Medium.jpg)
Crushed fuel return
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0167Medium.jpg)
.........run the new ones
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0159Medium.jpg)
Random gearbox shot
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0148Medium.jpg)
All connected up
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0175Medium.jpg)
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0186Medium.jpg)
Line at the engine bay end
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0188Medium.jpg)
Will weld the dash fitting onto the rail this week and that should be job done
Now to the boot
![](https://img.photobucket.com/albums/v17/rsnissan/fuel%20pump/DSCF0109Medium.jpg)
Final product
Made the ends up
Crushed fuel return
Random gearbox shot
All connected up
Originally Posted by Dan
Nice Andy, so whats next now you've started then!?
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Rad i know but decided to draw a line losing the "fast road" aspect of the car otherwise i would have the thing striped with a welded cage before long
Cheers Dave the pump was 130 i think got it from Boshman
Cheers Gaz and luke
Cheers Gaz and luke
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
![Content](https://passionford.com/forum/images/smilies/content.gif)
will leave it for a while as i am planning to move and get a bigger garage...........then i can do some proper mods
![Mmmh (I have an idea)](https://passionford.com/forum/images/smilies/1053181870.gif)
Tidy work once again, good to see people getting stuck in and getting on with it
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
that looks spot on m8
where can i get this lot from.? and whats the name of it.? website .?
http://img.photobucket.com/albums/v1...0109Medium.jpg
Thanks for the comments
Chris cheers
will pop in later this evening and let you know
All4it. i got everything from Think Auto
Its called "aeroquip" Aerospace style hose. You will have to spec what you want depending on what you need and how you want to do it. Its simple to use once you get the hang and you can do loads of bits on the car making your own bespoke lines etc
For the fuel lines you will need PTFE lined hose to minimise the smell of fumes
Chris cheers
JoeyBoyden
04-01-2024 02:36 PM
rog
04-09-2015 12:10 PM
