My Nova 2.0 16v Rebuild WIP - UPDATED 18 - 07 - 06
Here it is as i got it in May 2003
Then i stripped it, converted it to full mk2 spec and it had a full respray in Vauxhall Glacier white
Then i got bored of 1.3 8v power & upgraded to.....
Redtop power
Seam welded the engine bay & a new front crossmember as the old one was a bit rotten
Upgraded the brakes & added 280lb front spring to help with the extra weight of the engine
Wasnt happy with the paint work after a scratched the wings during the 2.0 16v conversion so i stripped it again
Booked it in for its second respray.
& the colour is bmw estoril blue
Bought some recaro's
Fitted a new single wiper
Bought a set of wheels of ebay
Then some tyres
& a couple of months back bought these second hand coilovers, done just over 1000 miles
thats it picture wise for now, but its now up in the air on axle stands having the underside hammerited & new handbrake cable, wheel cylinders etc fitted....
Hope you all like?
Redtop power
Then some tyres
Hope you all like?
looking good matey! not normally a nova fan but good to see uve not stuck 18s on it, body kit and filled it with ICe lol!
it changes its apperance more times than a hooker gets checked for stds!
Dunc
Dunc
Thanks for the positive comments guys
Hammerited the whole chassis, all arch's, changed the suspension, fitted the wheel cylinders, removed the front brakes & put a set of 288mm discs on just so i could get the car moveable....
Originally Posted by essex_boy_escy_si
nice car mate , big engine small car nice little pocket rocket !!! how come u never kept the smoothed boot
Dunc
Not much on the progress this update
Smoothed the boot grab handle
4 coats of paint
Laquered
On the car
Stripped down the engine on sunday just gone to replace all gaskets, seals, belts & pulleys, water pump, oil pump, clutch etc
4 coats of paint
Laquered
On the car
I ordered bits i needed to replace the gaskets & top end seals on my engine
Clutch Kit
Head gasket set
Head bolts
Sump gasket x 2
Timing belt
Water pump
Plugs & leads
All trade through my fiance, Ł191....
Picking these up sunday
Clutch Kit
Head gasket set
Head bolts
Sump gasket x 2
Timing belt
Water pump
Plugs & leads
throttle bodies from rich off matt's engine very nice bit of kit
i am loving the finsih on the rear handle with that colour paint i now know where i am off at the weekend for the trims on the gte
Cleaned the block, head & ancilaries up & painted them over the weekend....
Head isnt bolted down yet, need to get an engine stand.
This was the condition of the water pump, me thinks its never been changed??
Quality, novas with these engines are ace I love borrowing my mates
Originally i was going to say, why white, as it looked better when you first got it Then i saw the new colour
looking good mate, novas done properly are unbeatable for looks, dont go bad either lol,
shame they are never going to be that good handling wise compared to many other cars, thats why i sold my xe nova to make a fiesta,
looks real sweet tho mate, keep it up
Roose Motorsport silicone hose's.
Before pic of wheels...
Diamond cut Mk4 Astra SXi 16" wheels, 195-40-16 Toyo Proxes T1-R.
Needs lowering more, but i've still got half the engine to in/on.
