My new mk motorsport 6 degree beam
Old 14-12-2012 | 10:43 PM
B13 JUS's Avatar
B13 JUS
Default My new mk motorsport 6 degree beam
I asked mark to make a new beam for me as I wanted a few charges to my other.
He's done a fantastic job.
I wanted it to be easy to adjust instead of hitting it back and forth, mark came up with an adjuster like a motorbike back wheel.
I wanted extra support to use coilovers
Also wanted twin rose joints to do away with the ford bush as they are expensive to replace
I had 3dr trailing arms and the arb pick up points are on the opposite side so mark added some more so I can use a escort arb
Double skinned inner arms so should reduce the amount of flex.
Old 14-12-2012 | 10:49 PM
Rsmat's Avatar
Rsmat
300+
Now that looks the dogs bollox mate.!!!!!
Old 14-12-2012 | 10:58 PM
boost mad's Avatar
boost mad
How much extra weight has that lot added ?
Old 14-12-2012 | 11:21 PM
BRAMMER's Avatar
BRAMMER
I really like the looks of these beams
Old 14-12-2012 | 11:23 PM
andy escos's Avatar
andy escos
Quality bit of cratfsmanship as usual .
Old 15-12-2012 | 07:18 AM
MK MOTORSPORT's Avatar
MK MOTORSPORT
hi
probably about a pound ,as the original bush is very heavy ,the rose joint is lighter and the adjuster is alloy and there is a 8mm bolt and a couple of plates so very little really
mark
Old 15-12-2012 | 11:46 AM
richard youll's Avatar
richard youll
may i ask what sort of money that set up would cost of the shelf?
Old 15-12-2012 | 11:58 AM
MK MOTORSPORT
hi
£1250
mark
Old 15-12-2012 | 02:18 PM
charlie luciano's Avatar
charlie luciano
Looks very nice best handling mod that can be done
Luciano
Old 15-12-2012 | 04:14 PM
boost mad's Avatar
boost mad
Originally Posted by MK MOTORSPORT
hi
mark
I meant more the arms Mark, Just curious as they are double skinned !
Old 15-12-2012 | 05:10 PM
focus 4x4's Avatar
focus 4x4
Awesome ! Mark has certainly raised the cross bar with his beam
Old 15-12-2012 | 07:23 PM
MK MOTORSPORT
hi
tube in middle is t45 tube so nxt to nothing and outer is realy only putting back what was removed so i dont think it will be much i will weigh nxt time standard and modded
mark
Old 15-12-2012 | 07:24 PM
MK MOTORSPORT
hi simon
you know you want one lol
mark
Old 15-12-2012 | 10:25 PM
Who that looks mint Justin.Top fab work.Its a shame to paint it all.
Old 04-02-2013 | 09:42 PM
killa_paul's Avatar
killa_paul
hi
£1250
mark
would this be cheeper if you were supplied with a standard rear beam to mod or is this price for moding a custemers beam ..
cheers
paul
Old 04-02-2013 | 09:50 PM
rs_traynor's Avatar
rs_traynor
stage4 2wd cosworth
ill be buying one of these this year
Old 04-02-2013 | 10:21 PM
peter/jedi's Avatar
peter/jedi
I've already got a stage 2 rear beam from another company, had it for about 6 years now. How much would it cost to get this style adjusters fitted to the arms?
PRO-LINE MOTORSPORT
28-09-2015 10:54 PM
DavidK
27-09-2015 03:55 PM
