show me ur zetec on bike carbs
#41
Easy. I bought a complete package from Trigger Wheels, the unit, miles of differant coloured wire, silicon pipe for the MAP sensor. I put the ecu in the cockpit out of the way and the Eddis unit in the engine bay. Following the full instructions supplied a friend made up the harness and fitted it. Then a simple task of plugging his lap top in and setting it up. This worked great but we took it to Hamish Lindseys @HML Chip Tuning for a proper set up on the rollers. A new exhaust system would prove invaluable, but it's a bit pricey even at mates rates...
#42
#43
As you will be aware, the spark is triggered by the flywheel on the Zetec. You will have to fit a trigger wheel somewhere if you cant use the flywheel. Front of crank is easy. If you contact Trigger Wheels as I did (just check their website out) you will get the full info. everything is written in easy to understand terms. They supply all the little plugs and terminals, and a trigger wheel if you need one and you just stick the wires in as per the drawings. So easy, even an old racer like me managed it.
STAFFY OWNER
13-09-2015 08:59 PM
grishenko45
09-09-2015 12:58 PM
