escos wheels on s2 rst's?
has anyone got any pics of escort cossie wheels on s2 rs turbo's?
have found some for a reasonably price. wanted some rs7's but i'v found some escos wheels for less than half the price of rs7's so im tempted but want to see a few examples first.
thanks,
ben.
thanks,
ben.
Here's a few pictures I found on my pc, they will rub if you lower the car alot but your suspension will have to be very hard to stop it from rubbing but there is more to that as well do remember the cossie alloys are too wide for the rs turbo but do fit better with the series 1 but they do look very nice.
i think they suite them quite well, just worried about any rubbing or hassle with getting pulled over because they stick out.
thanks for the pictures every1
Fleet Manager
just fitted mine about 5 mins ago
they are 20-5 45 16's rub abit due to shit front shocks
what other work is needed? removal of the inner arch??
backs are fine only rub over bumps
they all look really good, im not put off by being pulled over for them now, fuk that, more worried about them hitting my arch over bumps like has been said.
has anyone ever had some of the inside machined off the wheel so as they dont stick out as much?
if you run the correct size of tyre and have the s2 kit fitted then you dont need to worry about them sticking out, aslong as the tread isnt outside arch you'l be fine...
you cant machine the backs of the wheels as there isnt enough metal on them to do it safely.
JK12
33
26-04-2021 12:09 PM
