616HP @ 1.8Bar Vauxhall Nova
http://www.kolumbus.fi/pasi.haapalai...es/dynoday.mpg <http://www.kolumbus.fi/pasi.haapalainen/imagepages/dynoday.mpg>
Was sent this clip by a mate a nova thats ment to have 616hp... Now thats a Nova i wouldnt mind
Found this
Block: Secret
Brains: Hestec with direct ignition
Clutch: 228mm 4-paddle sinter
Pistons: Mahle wrought aluminium
Air filter: K&N 100mm
Con rods: BMW's (secret)
Injectors: MSD 1000cc/min
Fly wheel: Lighten
Camshaft: 2*Group-A
Axle shaft: Karpiola steel shafts
Fuel pump: "Big" Bosch
Wastegate: 2*Pate Racing
Intercooler: 43*65cm
Crankshaft: Lighten
Watercooler: Pasific racing team F1
Exhaust pipe: 4,0"
Transmission: F20 (=Fuse20)
Turbocharger: Holset 72mm/72mm hybrid
BlowOff valve: None
Clutch assembly: Sasch Racing
Exhaust manifold: Snakepit with 50cm pipes
Compression ratio: 6,5:1
Fuel pressure regulator: Bosch
Torque: 610Nm (1,8bar/6700rpm) and 466Nm (1,4bar/6690rpm)
Efficiency: 441kW/600hp (1,8bar/6900rpm) and 332kW/452hp (1,4bar/6860rpm)
Top speed: 270km/h (enough for this size of a car)
0-100km/h: approx. 5,0sec
100-200km/h: 4,5sec (accelerating with 4th gear)
Its got standard GSI brakes too
![](http://www.itlab.fi/firges/Cars_page/corsa_pasma/pictures/corsa11s.jpg)
http://www.itlab.fi/firges/main_page.htm
Block: Secret
Fly wheel: Lighten
Camshaft: 2*Group-A
Crankshaft: Lighten
Exhaust pipe: 4,0"
BlowOff valve: None
Oh and some more pics http://www.kolumbus.fi/pasi.haapalai...ges/image4.htm
check out the screamer pipe
Thats a beast that is... allways wanted to build a 2.0 turbo nova... but 4wd it,
Seen this 1 before its fait mad, that turbo is massiv...
The black 1 is fair evil... www.boost-beast.com , dont click on the english one as there is nothin on there yet, there are some good vids on there to...
![](http://www.boost-beast.com/boost-beast.de-DE/galerie/luckau-03/images/big/luckau03-24.jpg)
Originally Posted by Shamz
Originally Posted by fudgeass
anyone seen that twin engined black one???
was at trax, dont the 0-60 3 secs!
Yeah quickest done that day was a 0-60 in 2.86
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
![Content](https://passionford.com/forum/images/smilies/content.gif)
Originally Posted by Fez
That car is a bit of a legend around here.
http://koti.mbnet.fi/jmtalvio/xxx-corsa.avi
Would like to see how the car reacts around a track
Shamz
