740 hp ford sierra cosworth
Anyone heard is this cossie and tuner.
And it's also a high comp cosworth engine whit loads of power.
Engine: RS500 block, RS500 studs, CPS (silicone processed) pistons 91mm, RS500 rods, Polished head derived from the 4x4 model, mechanical rocker arms, last-stage Kent camshafts for mechanical rocker arms CW8. Adjustable Kent camshaft gears. Valves are bigger by 0.5mm, covered with titanium EP-371. 6-litre oil pan. Lightweight crankshaft and flywheel. 2-disc AP Racing clutch. Pectel T6 electrics. 8.5:1 compression ratio. Turbocharger is a mix of KKK and Garrett T72 compressor with 100/72 wheel. The intercooler is the one used on the RS500. The car uses an aluminum radiator and a MOCAL oil radiator as well. The dump valve is made by Bonalume and the external waste-gate comes from the Audi RS2. There are 8 fuel injectors in total with a flow of (4x475cc)+(4x1000cc). WRC gasket.
Exhaust: 90mm pipe.
Suspension: Height-adjustable Bilstein groupA dampers, polyurethane silent-blocks.
Transmission: Gearbox with modified ratios, diff ratio is 3.9:1. 75% limited slip differential.
Brakes: TAROX 6-pot calipers, 321mm disks at the front. Larger disks on the rear.
Other Info: The dyno showed 740bhp and 68 kilos of torque @ 7500rpm with 2,2bar ct and 2,5bar overboost. 0-100 in 3,3secs.
http://www.extreme-tuners.com/projects.html
Exhaust: 90mm pipe.
Originally Posted by Dan
Originally Posted by turbo_boost
Whats up with the front of the car ????
Originally Posted by Rhys
Seen this car a few months ago on here. 3dr with Saff front bumper confuse's the fook out of me when i frist look at it
sure it aint photoshopped?
Originally Posted by Pez71
If you notice, its left hand drive, the Sierra Mk 2 (Sapphire type) was available on mainland Europe as a three door model
Cos mate a standard cosworth rod can handle around 700-720bhp with a safety factor built into that so at a push it may handle 740 but running on that boost and compression ratio it will probably not handle 2.5 bar boost on 8:5:1 it will be on race fuel.
The RS500's were homologated for touring cars so may have stronger internals so may be stronger but the blocks are not stronger than 200 blocks a common made mistake.
Cant say the engine will last long on standard rods, crank and a not linered block.
Been around ages this car but will only have the boost turned up at meets/when showing off on race fuel and tbh will be down on 1 bar boost most of the time even if it is drove on the road.
No hard feelings on the owners if this sounds threatening but Im just trying to state the truth.
RS500 rods are the same as normal cossie rods. The rods are VERY strong as is the crank. The only problem is they are heavy and so you don't want to be slinging them around at much over 8000rpm.
Cool car some of the spec doesn't add up though... and there is NO way it could do 0-62.5 mph in 3.3 seconds in my view.
Extreme Tuners is a Greece based tuning shop. The setup you posted is their very old one. Obviously they haven't updated their website yet.
The car is 4wd now and for a while it ran a HKS T51R KAI turbo pushing 717 at the wheels....
Currently they running in a new engine (VERY HIGH spec) to push probably a GT42R turbo (probably more than 800 at the wheels)
More info soon... (maybe you will see it in a very known british ford mag when the car is ready....)
