Focus RS : Boost Solenoid : Anyone sell an upgrade ?
Can someone explain what it is and does
is it like an amal valve
Is it a Ford part or 3rd party ie webber ? and do they make an uprated one as this seems to cause alot of issues with peeps and missfires at 5k when running Bluefin map and boost levels
Another way to cure it is something called a boost controller but can you not just by an upgrade to the normal electronic boost controller
all very confusing
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
all very confusing
I don't really know Kev, as this is my first turbo car and I don't 100% understand how everything works. I think the principle is the same as an amal valve. With it being a solenoid I pressume it's an electrically operated valve to control boost. Basically, it's small and rubbish
and an uprated one will be much more reliable. I do occasionally get boost probs, did it tonight slightly, haven't had the car out for a good few weeks but it has been running fine for alot of months upto now. I wouldn't be surprised if it was a Bosch item or similar, don't know really though!
If I was certain it would cure the problem, I would go for the Apexi boost controller. My rear bumper is getting scorched from where it misses and backfires at 4-5k!
i would be very surprised if it was the valve causing the mis/backfire, it may be overboosting or an ignition misfire, the valve is only a solenoid, its duty cycle is varied by the ecu to control the boost pressure, it does this by "bleeding off" varying amounts of air, get the car to a chassis dyno, they should be able to find the fault with your vehicle
Originally Posted by NathR
Wouldn't think that would be a boost solenoid problem mate? Have you tried better plugs?! The boost problem is more of a smooth wavering. ![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
Not good.
Touch wood, mines NEVER missed a beat, still on original plugs and leads, the only prob I've had is the occasional (4-5 times in 2 years) boost prob, which should be sorted by a Blitz controller soon.
dont you think all these probs could just be the base map ie AF ![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
as i said my misfire was in 3rd @ 5 k and it just backfired no boost change and carried on going
matman
09-09-2015 05:45 PM
salsheikh
Alloy wheels and ICE for sale
30-07-2015 08:45 PM
