Brake Bias Valves - Info & Advice please
Car is an FRST, there is no weight in the back and im running ST170 discs so therefore I need to fit a rear-bias valve and am in need of some advice. Am I right in saying that all you need to do is run a single rear line from the master cylinder and the valve is situated in the line? The front system is not changed at all.
Also the standard non-abs master cylinder has two outlets front and rear ie 4 in total. Would I be better in running an ABS master cylinder which has only one outlet each for F&R?
What is the better bias valve to go for, screw type or lever? Also Tilton or AP?
yeah, 1 line, then split it for the rear 2. put the bias valve in the engine bay somewhere
you need non abs cylinder, 2 for the front, 1 for the rear, then block the last one up with a bolt
Are you not better putting the bias valve between front and rear and having it adjustable from inside the car so it can be adjusted for different conditions? Or does this just work with bias pedal boxes? I am not up on all this abs talk so am genually interested to hear what the difference is for this application you lads are talking of?
CheeRS
Dave...
CheeRS
Dave...
CheeRS
Dave...
CheeRS
Dave...
Oh right, err I think? I have a mechanical adjustable bias in my Mk2 direct onto the pedal adjuster bar, but my Mk1 has a Wilwood adjustabe valve fitted to the trasmission tunnel which is linked into the hydraulic system. Again this is adjustabel from in the car whilst driving.
Still no idea about how the modern stuff is set up?
CheeRS
Dave...
CheeRS
Dave...
CheeRS
Dave...
CheeRS
Dave...
Originally Posted by S1
BIAS pedal boxes dont need a bias valve
Your thinking along all the correct lines S1
Obviously your going to need to re-plumb it front-front and rear-rear.
From 1 outlet on the m/c split the fronts, from the other outlet send it to the back, through a screw type adjuster then split it for the backs.
You can then reduce the pressure to the backs to stop it overbraking.
Im not a fan of the lever type, they sometimes dont have the notch in the right place and what you want is in betweeen two notches.
Go for a screw type one, but both them makes you mentioned are over priced - my mate sells them unbadged on ebay for £39.
Yes the Mk2 has the thready type adjuster which is dead easy to set and understand as it just moves left to right and puts more pressure on the required piston. My Mk1 actaully has a valve that swaps hyraulic pressure between the front and rear calipers as required, better get my hands dirty and see where it all goes eh.. LOL!
What does your mate trade as on e-gay? I will most probably be running the brake lines this week so need one by the weekend.
http://cgi.ebay.co.uk/BRAKE-BIAS-PROPORTIONING-VALVE_W0QQitemZ8031973700QQcategoryZ72205QQrdZ1QQc mdZViewItem
Ben26
27-08-2015 08:56 PM
Jack and the Beanstalk
09-08-2015 07:03 PM
Red_bull
09-08-2015 08:34 AM
