The plastic ring inside wheels
Old Jan 26, 2006 | 03:08 PM
Olliexr4x4's Avatar
Olliexr4x4
Default The plastic ring inside wheels
Just bought some second hand alloys, they are the correct offset and pcd but the plastic insert in the middle is not the correct size, is this plastic ring important or is it just there to align the wheels when fitting them
Will it be ok to fit the wheels without any ring fitted?
Old Jan 26, 2006 | 03:09 PM
The spigot is there to locate the wheels, but realstically tapered bolts do that anyway, so you should be fine wihtout them, be better if you could find the right size spigot instead though.
Old Jan 26, 2006 | 03:12 PM
3drstretch's Avatar
3drstretch
The spigot ring is there to locate wheel central on hub bolts dont always do this.Some tyre centres will not even balance a wheel with no spigot rings as it is a waste of time if wheel not put on car central.There needed for a reason.
Olliexr4x4's Avatar
Olliexr4x4
cheers for the rapid reply chip
Old Jan 26, 2006 | 03:13 PM
3drstretch's Avatar
3drstretch
And wot wheels are there as i should be able to source correct spigots.
Old Jan 26, 2006 | 03:16 PM
Olliexr4x4's Avatar
Olliexr4x4
They are Team dynamics Buccaneer and I am fiiting them to an Audi 80 the centre bore is 57.1 They will also be going on my XR4X4 when it goes back on the road, so I will prob be after some rings to fit them to that
Old Jan 26, 2006 | 03:29 PM
3drstretch's Avatar
3drstretch
Ollie you have a PM
Old Jan 26, 2006 | 04:00 PM
cossymad's Avatar
cossymad
All wheels need to be located properly as the bolts on their own will come loose, fracture and brake. How ever the rims you have are 57.1 mm centre bore, which will require no rings on an audi, as they are 57.1 mm already, and hence are a direct fit. Wheel bolts/ nuts are designed to pull the wheel to the hub, not to support the weight of the car. Shame on you Chip
Old Jan 26, 2006 | 04:02 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
The one chance I get to truly redicule Chip today, and you beat me to it - bastard .
Old Jan 26, 2006 | 04:06 PM
cossymad's Avatar
cossymad
The only chance I'd EVER get
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
RSBryden
Sep 6, 2015 08:39 PM
hopper350
Sep 4, 2015 12:53 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
