Reasonable labour price for removing/fitting a turbo?
I'm gonna be ringing around tomorrow to get a price for replacing the turbo on my 4x4 saph. I'm supplying the turbo myself but whats a reasonable price for labour?
Can anyone recommend someone who could do this work in north east area?
Boon
Boon
I'm too kak-handed mate.
I did have a look, but the bolts look well awkward to me
It may be easy with good/correct tools, but I just don't have the tools nor the know-how.
Thanks for replies guys, I might have another look at it tomorrow. If it's only an hour's job for a garage, surely i can do it over the course of a weekend ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
As it is, it's seized anyway so wouldn't be able to drive it to a garage - have to get it trailored - so even if i screw it up, i'll be no worse off.
Then when your turbo and elbow are off the car split the turbo from the elbow with the other 4 bolts and there should be 4 locking tab washers aswell to move before you can do this and once its taken off replace with your new turbo.
Then just repeat what you done but in the oposite order and check it all over for any mistakes.
When the new turbo is fitted just make sure you prime the bearing with oil before starting the car, this can be done by disconecting the coil and turning the engine over for 15 seconds.
Job done
TT T38 Power
When the new turbo is fitted just make sure you prime the beaqing with oil before starting the car, this can be done by disconecting the coil and turning the engine over for 15 seconds.
Job done
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
Steve.
Job done
Steve.
Think i need my eyes checking, still that makes it easyer doesnt it ??#
Theres only four bolts instead of 8 in total
The 4WD turbo can be a complete sod to take off in the car you nearly always end end removing the complete manifold to be able to uindo the rear bolts which hold the turbo in place,its OK saying it will only take an hour,in a perfect world this may be true but what happens if you find broken studs that need re alloycoiling or sezed nuts ?? at a garage at say £25 an hour expect a bill for at least £100 + VAT
Didnt realsise you had to take the manifold off on the 4b
Thanks to all for replies. On reflection, I think it's safer all round to leave it to a pro. I'll end up breaking something and causing more damage/expense.
Neil, I live out in the sticks, halfway between Whitby & Guisborough. Where are you mate and do you know anyone local who's good with cossies?
I've posted a couple of pics of the turbo - the invoice I have calls it a "hybrid turbo" and that's it. I realise it's probably impossible, but can anyone identify what it is from these pics as I'd like to replace it with a same-spec item.
![](http://www.imotors.co.uk/temp/boon/turbo1.jpg)
![](http://www.imotors.co.uk/temp/boon/turbo2.jpg)
Cheers,
Boon
Cheers,
Boon
Football Cwazy
i don't take the manifold off when doing a 4x4, granted it's awkward but not impossible. the nut/bolt at the rear is the awkward one but with the exhaust downpipe off you can get at it, bent spanners always help
Thanks bud, had a dig around for some numbers. I can just make out at the bottom (not visible in photos) /B - 48 or something. I've heard this .48 branded about a bit on the forums so guess that's what it is???
Out of interest, how can you tell it's a T34? It would have had a T3 as standard right?
Football Cwazy
sounds like you have a T34.48 then, a good punchy turbo
the main difference you can see is the size of the compressor housing and the 'square' casting on the face,for the i.d. tag
this is a normal 4x4 t3
https://passionford.com/forum/viewtopic.php?t=167971
Thanks Martin, you've been a great help!
It was a punchy turbo until it seized up. Think i'll buy another one just like it. Anywhere you'd recommend to buy from?
TT T38 Power
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
Steve.
Football Cwazy
Cheers Steve, will do mate. Presumably the return pipe should be changed too?
Anyone, would a T34.63 a better buy than a T34.48 ???
Danny@RADesigns is good, he posts on here
1 Post
bent spanner needed - but nothing specialised - about an hour and its off.... more room aswell on a saph as the turbo is a lil bit smaller ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
see my rebuild.....
![](https://img.photobucket.com/albums/v125/apbms1/PB190003.jpg)
![](https://img.photobucket.com/albums/v125/apbms1/PB190004.jpg)
![](https://img.photobucket.com/albums/v125/apbms1/PB190006.jpg)
![](https://img.photobucket.com/albums/v125/apbms1/PB190007.jpg)
![](https://img.photobucket.com/albums/v125/apbms1/PB190008.jpg)
see my rebuild.....
![](https://img.photobucket.com/albums/v125/apbms1/PB190009.jpg)
Martin, I'm gonna go for a .63 seems the best choice for the way I like to drive.
Thanks again for all your help.
I'm running Ahmed chip on 803's, RS500 spec intercooler so should be ok. I'm thinking of moving to greys later in the year so the .63 will definately be better then i think.
Dave, thanks for the pics very informative. LMFAO at that spanner!
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
Hi Mate,
I'm near Marton. Just being nosey really as I saw you were from round this way but I didn't recognise the car.
I tend to do all my work myself, never had the car to a garage round here really. Dave Alwood in Marske knows his stuff, but I've only ever bought parts from him, never had him do any work for me.
I'd have a crack yourself - It's only nuts and bolts, just make sure you prime it properly and get any air out of the cooling system![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
Neil.
Neil.
Originally Posted by bud-weis
i don't take the manifold off when doing a 4x4, granted it's awkward but not impossible. the nut/bolt at the rear is the awkward one but with the exhaust downpipe off you can get at it, bent spanners always help ![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
Hi Neil
I've had the car since Aug 1995 so you may well have seen it around at some point. Done a few 'test runs' along the parkway in my time.
Was good friends with Dave Alwood, but we fell out many moons ago. Shame really, he is quite knowledgeable I think, just a bit of attitude at times.
Cheers,
Boon
Cheers,
Boon
Mine is also a .55
What bhp do you think yours will make at PE next week Beach ?
Steve.
Steve.
Ive gone for 340 as thats what Karl said it should be around but it will be good to see, shame i cant get my block wire ringed in time for that as running 2 bar to the limiter instead of tailing off to 26 would be nice
Only time will tell
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
Right, got the turbo today and made a start getting the old one off. I've loosened the front two nuts no problem, just leaving the back two.
Can I buy one of these 'bent spanners'?
Other option is to go out tomorrow and buy a couple and try bending them meself. But I have no vice or anything, just sounds like i'm gonna lose an eye or something!
Yeh but the front two have come off easy (i know they're the easy ones) so if i could just get a spanner on the back two i'm sure i can manage to do this myself leaving the manifold in situ.
All i need is a "Dave Henshall spanner" or similar and i'm sorted.
Matt Baxter
16-09-2015 08:30 PM
Cameron
14
09-08-2015 06:28 AM
