Rounded off Sump Plug
Old Jan 22, 2006 | 06:49 PM
dave_y's Avatar
dave_y
Default Rounded off Sump Plug
The Sump Plug has been rounded off on my S2.
What can i do to get it off?
Old Jan 22, 2006 | 06:51 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Mole Grips first. REALLY tight, as you will only get one chance.
Then, try knocking it round with a hammer and a small chisel. Hopefully if you put the chisel on the edge of the flange of the nut, it will bite in when you hit it.
Nightmare! Good luck!
Old Jan 22, 2006 | 06:52 PM
Moose 130's Avatar
Moose 130
plumbers wrench.
Old Jan 22, 2006 | 06:53 PM
filthyrichie's Avatar
filthyrichie
CHISEL ME SNIZEL ..OR SNAP ON NUT REMOVER SOCKETS THERE AWSUM FOR ANYTHING LIKE THAT
Old Jan 22, 2006 | 06:57 PM
haz87's Avatar
haz87
buy a new sump
Old Jan 22, 2006 | 06:58 PM
The Youth.'s Avatar
The Youth.
weld a nut on it, the heat makes it finger tight!!
done this a few times and they come straight out.
steve
Old Jan 22, 2006 | 07:00 PM
Phil's Avatar
Phil
Jeebus
Drill it out and feel the love for swarf
Old Jan 22, 2006 | 07:03 PM
GARETH T's Avatar
GARETH T
run the engine too get the sump warm,,,, then smash it round with a chisel
Old Jan 22, 2006 | 07:22 PM
dave_y's Avatar
dave_y
loads of suggestions there, will give them a go tomorrow evening. Thanks!
Old Jan 22, 2006 | 07:29 PM
Thrush's Avatar
Thrush
Irritating c........
When the sump nut rounded on my S1 I ran it for a little to get the oil hot enough, then used one of them reverse tap "easy out" thingies - piece of piss
Old Jan 22, 2006 | 07:31 PM
dave_y's Avatar
dave_y
never heard of one of them before?
Old Jan 22, 2006 | 07:32 PM
abdr500's Avatar
abdr500
weld a nut on the heat will lose it of pluys thers a new nut to turn it round i do it all the time
Old Jan 22, 2006 | 07:35 PM
GUZZLER's Avatar
GUZZLER
Dave, were you using a six sided socket? the sixteen sided ones normally slip!
if you get stuck run it to Power Engineering & we'll get it sorted
Old Jan 22, 2006 | 07:37 PM
Christian and Beccy
#1 in Spelling Club
Welding stuff is OK, but most of us don't have a welder in our garage!!
dave_y's Avatar
dave_y
i didn't want to admit it but ithink i was using the wrong type of socket!
Guzzler: I will give you a ring tomorrow as i need to book the car in for the clutch!
Old Jan 22, 2006 | 07:40 PM
DazC's Avatar
DazC
How I used to do it....
Discover the sump plug is rounded,
Use a good 6 sided shallow socket and make sure it's on the plug fully.
If that failed I'd try a 12 sided 1/2 inch socket followed by a 6 sided 1/2 inch socket hammered onto the plug.
If that failed, I'd use a good set of vise grips really tight.
Failing that it was the hammer and chisel.
Old Jan 22, 2006 | 07:51 PM
Thrush's Avatar
Thrush
Usefull tools!!!
They have a self tapping, revers thread on the end, so instead of winding it in clockwise (like you would to tighten) you wind it in anti clockwise. What you do is drill a hole in the bolt slightly smaller than the easy out (so there's enough meat left for the easy out to tap into) and then wind the easy-out in anticlockwise. Cos of the reverse thread it bites into the bolt and tightens inside it, lokcing it self in. Then you carry on "undoing" the easy out (turning anti clockwise) and it grips the nut and un-does it
Usefull of bolts and also for screws that have the slot/cross pattern stripped;
Old Jan 23, 2006 | 05:07 PM
dave_y's Avatar
dave_y
gave up in the end, paid the local garage (scammers) Ł8.50 to get it off!
Old Jan 23, 2006 | 05:42 PM
Ginge !'s Avatar
Ginge !
just finding my feet
theres a socket that is designed for rounded off nuts,,,,,, it works a little like a wasy out, the ends taper in a anti clockwise direction and then it allows it to grip cause it gets smaller,,,,,,,,, but 6 sided sockets are a nust have tool and soo many people dont have em,,,,,, the 12 sided are just to make it easier to locate the tool on the nut
glad you sorted it anyway
gcfcos
59
Oct 6, 2015 05:04 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
youngben
Sep 27, 2015 09:37 PM
