355mm ap discs.
355mm ap discs.
after snapping one in two places at croft last weekend i now need to buy a new pair,anybody know where to buy them preferably cheapest but reliable,thanks in advance.
What sort of 355s?
They come in various widths, mounting type (bolted or floating), number of vanes and PCD (which effects the pad swept area), that's without the type of disc (drilled, grooved, fish-hook grooves)?
Originally Posted by KA ZETEC
mike
this is our brake set up on our race car
Are these fish hook vanes then ?
Paul,
Yes, if you let me have the above info, I can tell you if I have them in stock. If not, then I have two other places I can try (as AP are next to useless and everything is 3-6 week lead time ).
I "think" that is a CP3581-1080/1. However, you need to measure more accurately just to be sure, as the PCD should be 228.6 and the inner edge of the disc should be 255mm? Takes a D51 pad? Also, you can't count, it is 48 vanes .
Grooved, drilled or fish-hook?
The only one I can come up with in your time frame, is the CP5772-6078/9. This is dimensionally identical to the CP3581-1080/1 356 x 32 228.6 PCD and 251.6 inner disc dimension, it just has 72 vanes instead.
Let me know if this is acceptable, and I'll find out a price. Before you ask about the weight difference, I have no idea, as it says N/A in the AP catalogue .
