Strange MK5/6 escort question.....
Old 18-01-2006, 09:57 PM
Zetec Andy
Zetec Andy's Avatar
Default Strange MK5/6 escort question.....
is this right that the trackrod end on a MK5/6 escort is as pictured?
Went in the bodyshop today for a little look and where mine meets the ball joint behind the brake disc its bent up quite a bit at the end, are the pictures above correct or have i found my wobbly wheel problem!
Old 18-01-2006, 10:20 PM
Zetec Andy
Zetec Andy's Avatar
Just been told the bit im looking at is probably the lower arm, mine lookes like this...
and should look straight like this...
If its bent like that is it enough to give me a definate wobble every turn of the front wheel?
Old 18-01-2006, 10:21 PM
CabbyRS
CabbyRS's Avatar
how do u mean mate wobbly wheel
Old 18-01-2006, 10:24 PM
Zetec Andy
Zetec Andy's Avatar
image driving on a buckled wheel or an unbalanced rim.
ie. every turn of the alloy you get a tug through your steering wheel.
CabbyRS
CabbyRS's Avatar
thats fucked mate totally anythin other than perfect will cause u a problem
Old 18-01-2006, 10:26 PM
CabbyRS
CabbyRS's Avatar
that must of took a right smack to bend that bottom ball joint like that
Old 18-01-2006, 10:40 PM
Zetec Andy
Zetec Andy's Avatar
it did
Its in being repaired.
Old 18-01-2006, 11:05 PM
Chipperx2
Chipperx2's Avatar
That would definately make the wheel wobble IMO, if thats what your asking? I've replaced a few on my old escort and had one done on my current one as the bushes go and cause an MOT failure quite easily on the mk5/mk6. I've also heard your better going with genuine Ford parts for the lower arms as they're much better quality etc etc
Oh aye that is the lower wishbone arm your looking at
Old 18-01-2006, 11:10 PM
cossiecrew
cossiecrew's Avatar
andy mate as chipper has already said get genuine ford bottom arms as there a common problem on your shape escort they dont last long as it is deffo by ford ones over the cheap shit otherwise youll be changing them again within a few months
Old 18-01-2006, 11:11 PM
Oranoco
Oranoco's Avatar
Just a quick point if the impact done that to the arm the chances are the rim itself could be fooked as well
Old 19-01-2006, 07:53 AM
Zetec Andy
Zetec Andy's Avatar
This repair is coming upto the price of a new escort me thinks
Old 19-01-2006, 09:30 AM
Fudgey
Baby Cheesus
Fudgey's Avatar
top pic is the track rod ends that go on the steering rack, they do go at an angle too
Old 19-01-2006, 09:42 AM
BlueSmoke
PassionFord's crazy fool!
BlueSmoke's Avatar
That could well be your problem Andy. Also, be careful when putting the new arm on that you get it torqued up right as they love to come loose and start moving around.
Old 19-01-2006, 10:26 PM
Zetec Andy
Zetec Andy's Avatar
Had it up in the air today, wheel seemed ok but the tyre didnt
I ran it in gear watching the wheel spin, imagine standing directky over the tyre as its spinning, there tyre was going back and forth wobbling, i hope its just that
Old 19-01-2006, 10:39 PM
Redeye Jedi
Redeye Jedi's Avatar
Recently changed both on mine for MOT. Were fairly easy to remove but a right biatch to get lined up when putting the new ones on! Plus minimal access for hands!
Old 19-01-2006, 10:44 PM
Ginge !
just finding my feet
Ginge !'s Avatar
andy pattern arms are around 20 quid,,,,,,,,,, for ones are 3 times the price
they all wear just as easy tbh too
get QH pattern arms as there not that bad tbh
Dr. Ickxs
15-09-2015 10:15 PM
bassboy
10-09-2015 08:54 PM
imnoteasy
07-09-2015 09:26 PM
Ade
Alloy wheels and ICE for sale
07-09-2015 05:06 PM
wheelwizardrefurbs
05-09-2015 10:52 AM
Quick Reply: Strange MK5/6 escort question.....
