Water cooled turbos
People do that to minimise the tempeature on the way back to the engine.
Turbo lives longer with it connected.
I would connect it, and if you are still worried about return temps, fit a heater matrix rad or similar after the turbo before the return.
Originally Posted by XRT_si
I recently read (like yesterday) that turbos are watercooled to help the cooling down process so you dont have to wait in the car after a rag...though never heard it before
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Jay, on a seperate note, bit busy at work for chatting on the phone at the moment pal, will call you later.
It has water ports on it that are not and have never been connected.
(I got the turbo second hand only 6 months old)
I do warm up the turbo and cool it down properly though by driving
off boost gently for the last few miles or so on a journey.
Besides, on my engine it isnt working as hard as it was designed to do.
i spoke to a company that makes turbo's and they said that the water cooling is only there from the factory to help them cool down when theyve been switched off as water absorbs the heat from the metal
not saying there right but thats what they said to me
we've had loads of cars come in without water running though them and they have been fine.........
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
Norris Motorsport
Don't forget folks, if you're running a ball bearing core as found on many turbos such as the Garret GT range you MUST run water cooling else its Goodbye turbo!!
Traditional journal bearing turbos such as the garret T series can run without water cooling provided you run both a good quality oil and allow the turbo to cool down after a good beating. Failure to do this will cause the thrust bearing to self destruct literally (due to excessive heat and poor oil)!
Norris Motorsport
People seem to take it off because they think their engine runs much cooler without it.
If that is the case it simply highlights that their cooling system is in dire need of help!!! If people honestly think that water returning though a -6 pipe (8mm in laymans) to the header tank has a large effect on engine running temp they really do have radiator issues!!!! (i.e. fooked radiator syndrome)
In racing applications it is often removed as it is seen as another soucre of unecessary leaks NOT because it causes hot running!!!!
and it does make the car run cooler by means of stability in the cooling system. when the car is running at normal road type use the turbo core is no hotter than the oil/water running through it, when under competition conditions on a 10 mile stage for instance the core will run at a temp way higher than any water system can possibly handle and therefore any water being fed into the hot core will instantly change matter. thus giving a vapour lock straight to the header tank
Norris Motorsport
Well we will have to agree to disagree mark. On our hill climb car which runs a T34 at its maximum boost (no restrictor for us) we monitor water temps returning from the turbo and I can assure you it is not at boiling point!!!
In addition without this water cooling we cannot even complete a days racing without destroying the thrust bearing! (It literally melts with heat!)
This is with an high flow oil feed to the turbo so we have eliminated any lubrication issues so for us water cooling is essential!!
DEYTUKURJERBS
I think its pointless TBH, big boost will kill it quicker than no water cooling will, as long as u let the car cool down properly.
Even in the blinkered world of 200SXs most have realised they may as well run the turbos water cooled.
A lot of the drift guys run BB turbos with no water cooling too
Thought that was a baaaad idea, and i wouldnt, but theyve had no issues yet.
Norris Motorsport
Mark I dare say the water flow rate though the turbo probably makes the difference! We use a larger water impellor on a 2wd water pump setup and whilst i can't give you exact flow rate figures I suspect that the water is not in the turbo core long enough to boil on our setup but on yours it is!.
Football Cwazy
Originally Posted by Kevin Sharp
one of my water pipes on my t4 fractured about 4 years ago so i just did away with the water cooling, seems fine ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
on a road car i'd say if you have it and it's working fine then keep it, maybe even fit a turbo rad?
Ford Focus RS Parts for Sale.
02-06-2016 06:46 PM
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
19-08-2015 06:25 PM
